back to back pri connectivity for SRST gateway
sayantanisarkar
I have a lab set up for SRST location and MAIN location.
in which i have two voice gateway one for each location. In both voice gateway i have connected pri back to back as i have only one pri.
when phones goes to srst mode , i can make calls but as pri is connected back to back , i need to dial each number twice as it is hitting two e1 ports.
is there any way to rectify this issue.
Sayantani Sarkar
Jonathan Schulenberg
Ensure that 'direct-inward-dial' is on the receving gateway's incoming POTS dial-peer. This will prevent it from giving secondary dial-tone and use the DNIS of the SETUP IE to route (or fail) the call.
Please remember to rate helpful responses and identify helpful or correct answers.
Hi Jonathan
'direct-inward-dial' command i hv already put in incomin dial peer.
In actual case I am dialling outside number twice
Can you post your configs?
Chris
mkchandak
On outbound pots dial peer if you have specific digits being matched, they wouldn't be sent out. Make sure you have forward digits configured on outbound pots dial peer.
