Barge Solution
Customer needs Barge solutions as below:
Phone - A
Phone - B
Phone - C
When phone - A and B are in call; the phone - C needs to barge the phone - B,
Conversation between Phone B&C should not hear by phone A during barge, can it possible or please let me know any workaround is there?
7 Replies 7
Jaime Valencia
Barge is by all means a conference. There's no way to use barge and have someone not listen.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Do we have any other workaround to achive the same in CUCM without barge.
No, what you're looking for sounds more like something that requires a Contact Center product.
java
java
What about whisper intercom?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsintrcm.html
During whisper, the recipient receives the initiator voice, but the initiator does not receive the recipient voice. Callers on any other active calls with the recipient do not receive the initiator voice.
that's right
Intercom do the trick
Jonathan the requirement is, when the assistant and external customer is in call, manager want to listen assistant & customer in silent mode, when manager give suggestion to assistant, the customer should not listen their internal discussion.
Can the intercom can be used for the above solution, could you please light me.
I would say you are back in Contact Center feature land there - silent monitor is a function of UCCX, but it is listen-only. Intercom is also one-way, until the called person hits the button to speak back and at that point the original (customer) call goes on hold I think.
You could prompt the agent to do stuff using desktop chat whilst doing a silent monitor (or perhaps by using the intercom function to speak to the agent - though I don't know if this would have some sort of negative interaction with UCCX).
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
