09-19-2023 08:07 AM
Is it possible to unassociate Controlled Device 1,2,3,#,# & Access Control Group 1,2,3,#,# using BAT?
I've exported user(s) and removed the values in Controlled Device & ACG; uploaded it as a User Custom file and ran it, but the user(s) account did not get updated meaning the Controlled Device & ACG still has the original values.
I was able use the same file to enable Mobility & Home Cluster, just can't get the controlled device and access control group to drop its values.
Appreciate any input.
09-19-2023 08:30 AM
AFAIK you cannot do that via BAT. It will add or change things, but not remove. You would need to do it through AXL, meaning that you'll need to program against the API to do the deletion.
09-19-2023 09:47 AM
It might maybe - maybe - work if you put <NULL> in the field instead of leaving the field blank. You could check by looking at a user with no Controlled Devices to see if the field is blank or <NULL>.
But I would tend to agree with @Roger Kallberg that this can't be done via BAT.
Maren
