Boss/Secretary on CUCM 8.5
Jean Lofrano
Hi voice team!
I would like a simple configuration that:
- The secretary answer all calls with destination to her boss;
I did the BFL configuration and it is working, right now I need one more funcionality above.
thanks.
ronpatel
Level 8
Level 8
You can use shared line between Boss and Secretary and have busy trigger to say 4. This may fulfill your requirments.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Leonardo Santana
You can use IPMA!
Take a look on this link:
http://blog.ine.com/tag/ipma/
Leonardo Santana
*** Rate All Helpful Responses***
Shared Line is the easiest and fulfils 99% of such requirements.
Chris
Yeah.. most of my customers either:
1) Do a shared line
or
2) Call-forward-all the manager to the secretary, and give the secretary a BLF for the manager's line. Set the 'Call Forward Override' service parameter to true so that the secretary can transfer calls to and call the manager directly (bypassing the CFA).
IPMA is too complicated in terms of config/support and training for most customers.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
