CALL DOES NOT ROUTE OUT THE LOCAL GATEWAY
rferriolo
Local calls will not route out the local Gateway of branch1 to the PSTN or from the PSTN back to branch1, however they will route out either CorpHQ or branch2 backup gateways. When I go into the route group configuration for branch1, and remove the backup gateways, I get a fast busy tone when I dial the local number. I know the MGCP Gateway at branch1 is functioning because when I dial 911 and run debug ISDN Q931, the call routes properly through branch1, so I have a call routing problem. I ran DNA and it came back as ROUTE THIS PATTERN and all of the number translations looked accurate, so I didn't have to check for any block patterns. I'm not getting any errors on the calling party phone display. When I deleted the route pattern for the branch1 site and forced it to use the global route pattern, I received a debug output on branch1. I do not know a debug command (such as debug voip dial-peer or debug ccsip messages) to use for an MGCP Gateway to see if the call is actually reaching the Gateway.
I have checked the following:
the route pattern configuration
the translation pattern configuration
the called party transformation pattern configuration
the route list configuration to make sure the correct route group for branch1 was selected
the route group configuration to make sure that the branch1 Gateway was first in the order of selected devices
the route pattern configuration to make sure the correct route list for branch1 ist selected
the Gateway configuration to make sure it's using the device pool for branch1 and to make sure the called party transformation CSS for the branch1 Gateway is applied
the device pool configuration to make sure it's using the route group branch1
Any assistance would be greatly appreciated
Ron
13 Replies 13
Manish Gogna
Hi Ron,
You need to test with just the local gateway in the Route Group. Run the following debug on the gateway "debug isdn q931" to see if the call reaches the gateway. If not, please share the detailed callmanager traces for a test call
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
The traces will show if the call is indeed going through the correct route pattern or not.
Also, try creating a specific route pattern ( like 912123456888 ) for a specific number and make a test call, this will rule out most of the overlap issues.
Let us know how it goes.
Manish
Hi Manish:
I was able to resolve the OUTBOUND calling issue to the PSTN by prexing a '1' in the CALLED PARTY TRANFORMATION PATTERN for both Branch1 & CorpHQ sites (\+1.206! and \+1.512!), however dialing INBOUND is still an issue. When I dial INBOUND from the PSTN for Branch1, the call is being routed though CorpHQ and when I dial INBOUND from the PSTN for CorpHQ, the call is being routed though Branch1. To avoid confusion, I removed the backup gateways from both route groups. In the debug going to Branch1, it is getting a DESTINATION OUT OF ORDER...
THIS CALL SHOULD BE ROUTING THROUGH CorpHQ
Branch1#
ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x008F
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Display i = 'Seattle US Phone'
        Calling Party Number i = 0x4180, '2065015111'
                Plan:ISDN, Type:Subscriber(local)
        Called Party Number i = 0xC1, '2065011001'
ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x808F
        Cause i = 0x809B - Destination out of order
____________________________________________________________________________________________
THIS CALL SHOULD BE ROUTING THROUGH Branch1
CorpHQ#
ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x008E
                Standard = CCITT
        Facility i = 0x9F8B0100A117020107020100800F41757374696E2054582050686F6E65
                Protocol Profile =  Networking Extensions
                0xA117020107020100800F41757374696E2054582050686F6E65
                Component = Invoke component
                        Invoke Id = 7
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = Austin TX Phone
        Progress Ind i = 0x8583 - Origination address is non-ISDN
CorpHQ#
        Display i = 'Austin TX Phone'
        Calling Party Number i = 0x4180, '5126026222'
        Called Party Number i = 0xC1, '5126022001'
ISDN Se0/0/0:23 Q931: Received SETUP  callref = 0x808E callID = 0x0006 switch = primary-ni interface = User
ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x808E
        Channel ID i = 0xA98381
                Exclusive, Channel 1
ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x808E
        Cause i = 0x8081 - Unallocated/unassigned number
ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x008E
ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x808E
Hi Ron,
Your Route Group and Route pattern settings will only affect the outbound calls, it does not affect the inbound calls from PSTN. When you call from PSTN the callmanager does not decide which gateway will recieve that call. It is configured on the gateway first and correspondingly the incoming CSS and significant digits etc are configured on the gateway page on CUCM. We can troubleshoot why the calls are failing ( like unallocated number and destination out of order codes ) but why the call is being routed to a specific gateway from PSTN is something that you need to check with your service provider.
Manish
Hi Manish:
This is a lab with a Cisco 2811 configured as a PSTN router, therefore, I am the service provider. That gives me the ability to debug both ends. I can send you the debug ISDN Q931 outputs if you want to take a look.
Ron
rferriolo
Hi Manish:
When I run DNA, it is using the proper Translation Pattern 9.[2-9]XX[2-9]XXXXXX, however it is using the global route pattern \+1! and  it should be using the Branch1 specific route pattern which is \+512!.
Also I have included the debug output...
Ron
Cisco Unified Communications Manager Dialed Number Analyzer Results
Results Summary
Calling Party Information
Calling Party = 5126022001
Partition = PT_Internal-DNs
Device CSS = CSS_US_Phones
Line CSS = CSS_US_LOCAL
AAR Group Name =
AAR CSS =
Dialed Digits = 95126026222
Match Result = RouteThisPattern
Matched Pattern Information
Pattern = \+1! ------------------------- (it is supposed to be matching the route patten  \+512!)
Partition = PT_TP-to-PSTN-RP
Time Schedule =
Called Party Number = +15126026222
Time Zone = Central America Standard Time
End Device = RL_CorpHQ-w-Backups
Call Classification = OffNet
InterDigit Timeout = NO
Device Override = Disabled
Outside Dial Tone = NO
Call Flow
TranslationPattern :Pattern= 9.[2-9]XX[2-9]XXXXXX
Positional Match List = +15126026222
Calling Party Number = 5126022001
PreTransform Calling Party Number = 2001
PreTransform Called Party Number = 95126026222
Calling Party Transformations
External Phone Number Mask = YES
Calling Party Mask =
Prefix =
CallingLineId Presentation = Default
CallingName Presentation = Default
ConnectedParty Transformations
ConnectedLineId Presentation = Default
ConnectedName Presentation = Default
Called Party Transformations
Called Party Mask =
Discard Digits Instruction = PreDot
Prefix = +1
Called Number = +15126026222
Route Pattern :Pattern= \+1! ------------------ (it is supposed to be matching the route patten  \+512!)
DialPlan =
Route Filter
Filter Name =
Filter Clause =
Require Forced Authorization Code = No
Authorization Level = 0
Require Client Matter Code = No
PreTransform Calling Party Number = 5126022001
PreTransform Called Party Number = +15126026222
External Phone Number Mask = NO
Prefix =
Called Party Mask =
Discard Digits Instruction = None
Prefix =
Route List :Route List Name= RL_CorpHQ-w-Backups
RouteGroup :RouteGroup Name= RG_CorpHQ-w-Backups
External Phone Number Mask = Default
Prefix =
Called Party Mask =
Discard Digits Instructions =
Prefix =
Device :Type= SIPTrunk
End Device Name = CorpHQ_SIP_GW
PortNumber = 0
Device Status = UnKnown
AAR Group Name =
AAR Calling Search Space =
AAR Prefix Digits =
Call Classification = Use System Default
Calling Party Selection = Originator
CallerID DN =
Device :Type= MGCPT1PRIPort
End Device Name = S0/SU0/DS1-0@Branch1
PortNumber = 0
Device Status = Registered
AAR Group Name =
AAR Prefix Digits =
CallingLinePresentation =
ConnectedLinePresentation =
Number Of Strip Digits =
CallerID DN =
Device :Type= H323Gateway
End Device Name = 177.1.254.3
PortNumber = 0
AAR Group Name =
AAR Prefix Digits =
Inbound Fast Start = Enabled
Outbound Fast Start = Disabled
Tunneled Protocol = None
Calling Party Presentation = Default
CallerID DN =
Alternate Matches
Partition :Name= PT_TP-to-PSTN-RP
Pattern
Pattern = \+!
Pattern Type = Enterprise
Pattern Priority = Urgent
CallManager Device Type = AccessDevice
PatternPrecedenceLevel = ExecutiveOverride
Branch1#
ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0003
                Standard = CCITT
        Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
                0xA10F02010106072A8648CE1500040A0100
                        Invoke Id = 1
                        Operation = InformationFollowing (calling_name)
                                Name information in subsequent FACILITY message
        Calling Party Number i = 0x0081, '5126022001'
                Plan:Unknown
Branch1#, Type:Unknown
        Called Party Number i = 0x80, '5126026222'
                Plan:Unknown, Type:Unknown
ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8003
ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8003
        Cause i = 0x8281 - Unallocated/unassigned number
ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0003
ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8003
Hi Ron,
Please try creating the same TP: 9.[2-9]XX[2-9]XXXXXX with different partition that can be accessed by only Branch1 phones and change the called number tranformations as below
Prefix = + [instead of +1]
with this, the called number can be tranformed as Called Number = +5126026222  and it can now match the route patten  \+512!
//Suresh Please rate all the useful posts.
Hi Suri:
I did as you suggested. I created another local translation pattern 9.[2-9]XX[2-9]XXXXXX and added it to a Branch1 only partition. I also removed the '1' from the translation pattern and from the Calling Party Transformation Pattern. When I make a call from the branch1 phone, the call is routing out the wrong Gateway 'CorpHQ' and is selecting dial-peer 12, which is configured for a national number and it is prefixing a '1' to the called party number. The call also hangs up immediately with the following error: Cause i = 0x8290 - Normal call clearing. In the DNA output, it is still selecting the global route pattern rather than route pattern that was created for branch1...
Ron
_____________________________________________________________________________________________
//-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=15126026222, Called Number=15126026222, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=15126026222
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
//-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
//-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=5126022001, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
//-1/B6232F47806E/DPM/dpAssociateIncomingPeerCore:
   Calling Number=5126022001, Called Number=15126026222, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=100
//-1/B6232F47806E/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=915126026222, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=915126026222
   Result=Success(0) after DP_MATCH_DEST
//-1/B6232F47806E/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=12
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
   Calling Number=915126026222, Called Number=915126026222, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
   Calling Number=915126026222, Called Number=, Voice-Interface=0x0,
  Result=SUCCESS(0)
     1: Dial-peer Tag=12
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 5126022001
ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x0092 callID = 0x8013 switch = primary-ni interface = User
ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0092
                Standard = CCITT
        Channel ID i = 0xA98383
                Exclusive, Channel 3
        Calling Party Number i = 0x2181, '5126022001'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '15126026222'
ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8092
ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8092
        Cause i = 0x8290 - Normal call clearing   ------------------------------- THE CALL HANGS UP IMMEDIATELY
ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0092
ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8092
   Calling Number=91[2-9]..[2-9]......$, Called Number=, Voice-Interface=0x0,
   Calling Number=^2065011...$, Called Number=, Voice-Interface=0x0,
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
translation-profile outgoing MakeSubscriber
destination-pattern 911
no digit-strip
port 0/0/0:23
dial-peer voice 11 pots
destination-pattern 9[2-9]..[2-9]......$
port 0/0/0:23
dial-peer voice 12 pots
translation-profile outgoing MakeNational
destination-pattern 91[2-9]..[2-9]......$
port 0/0/0:23
forward-digits 11
dial-peer voice 13 pots
translation-profile outgoing MakeInternational
destination-pattern 9011T
port 0/0/0:23
prefix 011
dial-peer voice 100 voip
description == Inbound/Outbound SIP PSTN GW From/To CUCM Pub
translation-profile incoming Prefix9_InFrom_CUCM
destination-pattern ^2065011...$
voice-class codec 1
session protocol sipv2
session target ipv4:177.1.10.10
ip qos dscp cs3 signaling
Hi Ron,
You received unallocated and unassigned number from PSTN, that means either the number at PSTN does not exist or the format you are sending is not acceptable by PSTN (i.e called number digit and it's type)
For ex:- you are sending called number as 10 digit which infact is your local number and i think in this case PSTN would be expecting 7 digit with called party type as "subscriber" and not "unknown".
Also share DNA result with the modification suggested by suresh.
Incoming calls:-
None of the incoming call is working with branch1?
If so then please share debug isdn q931 and debug mgcp packets for incoming call.
Nishant Savalia
Regards, Nishant Savalia
In addition to the debug isdn q931, I ran debug mgcp packets, however there is no mgcp output in the debug below. Please see the DNA OUTPUT. The call is still trying incorrectly trying to route out of CorpHQ. I created another
CorpHQ#
ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x0098 callID = 0x8019 switch = primary-ni interface = User
ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0098
                Standard = CCITT
CorpHQ#
ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8098
ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8098
ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0098
ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8098
DNA RESULTS
Results Summary
Line CSS = CSS_US_NATL
AAR Group Name =
AAR CSS =
Match Result = BlockThisPattern
Pattern =
Partition =
Pattern Type =
Time Zone =
Call Flow
Prefix =
Called Party Mask =
Prefix = +1
Alternate Matches
Note: Information Not Available
In DNA, number "95126026222" shows block this pattern. why? please check your configuration.
Outgoing Call
I would suggest to remove translation pattern and define exact called number route pattern which is pointing to your branch1.
At this time you collect debug isdn q931 and debug mgcp packets.
Incoming Call
Please share debug isdn q931 and debug mgcp packets separately for the incoming call.
Note:- Do mention separately incoming and outgoing call in notepad.
Nishant Savalia
Hi Nishant:
The call is now attempting to ROUTE in the DNA results. It is also attempting to route out of Branch1 which is correct. Please see the ISDN Q931 debugs on  Branch1 & the PSTN for an OUTBOUND call to the PSTN.
Also see 2 separate debugs for calls INBOUND from the PSTN. One for number 5126026222 & the other for 2065011001 (DEBUG ISDN Q931 & DEBUG VOIP DIALPEER)
Many thanks,
Ron
BRANCH1 OUTBOUND DEBUG TO PSTN
Branch1#
%SYS-5-CONFIG_I: Configured from console by console
Branch1#
ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0005
                Standard = CCITT
                        Invoke Id = 1
                Plan:Unknown
        Called Party Number i = 0xA0, '5126026222'
                Plan:Unknown, Type:National
ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8005
ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8005
ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0005
ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8005
PSTN INBOUND DEBUG FROM BRANCH1
PSTN#
ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0006
                Standard = CCITT
ISDN Se0/1/0:23 Q931: Received SETUP  callref = 0x8006 callID = 0x0055 switch = primary-5ess interface = Network
PSTN#
ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8006
ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8006
ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0006
ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8006
PSTN CALL INBOUND TO BRANCH1 '5126022001' DEBUG
PSTN#
   Calling Number=15126026222$, Called Number=, Voice-Interface=0x0,
PSTN#
   Calling Number=15126026222, Called Number=, Voice-Interface=0x4AC91FA4,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20003
PSTN#
//-1/00809C638176/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=5, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=5
   Result=Partial Matches(1) after DP_MATCH_DEST
//-1/00809C638176/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
   Calling Number=, Called Number=51, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=51
   Calling Number=, Called Number=512, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=512
   Calling Number=, Called Number=5126, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=5126
   Calling Number=, Called Number=51260, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=51260
   Calling Number=, Called Number=512602, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=512602
   Calling Number=, Called Number=5126022, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=5126022
   Calling Number=12065015111, Called Number=, Voice-Interface=0x4A1D5320,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20001
//-1/024AFC0B8179/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
//-1/024AFC0B8179/DPM/dpMatchPeersMoreArg:
   Calling Number=12065015111$, Called Number=, Voice-Interface=0x0,
PSTN#
//-1/02FB6035817E/DPM/dpMatchPeersCore:
//-1/02FB6035817E/DPM/dpMatchPeersMoreArg:
PSTN#
   Calling Number=, Called Number=51260220, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=51260220
   Calling Number=, Called Number=512602200, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=512602200
   Calling Number=, Called Number=5126022001, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=5126022001
   Result=SUCCESS(0)
     1: Dial-peer Tag=201
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Calling Number=5126022001, Called Number=5126022001, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
   Result=SUCCESS(0)
ISDN Se0/1/1:23 Q931: Applying typeplan for sw-type 0xD is 0x4 0x1, Calling num 5126026222
ISDN Se0/1/1:23 Q931: Sending SETUP  callref = 0x0081 callID = 0x8002 switch = primary-ni interface = Network
ISDN Se0/1/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0081
                Standard = CCITT
        Facility i = 0x9F8B0100A117020103020100800F41757374696E2054582050686F6E65
                0xA117020103020100800F41757374696E2054582050686F6E65
                        Invoke Id = 3
ISDN Se0/1/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8081
ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8081
ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x0081
ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8081
   Calling Number=^5126022...$, Called Number=, Voice-Interface=0x0,
PSTN CALL INBOUND TO CORPHQ '2065011001' DEBUG
PSTN#
//-1/75B271B78183/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2
PSTN#
//-1/75B271B78183/DPM/dpMatchPeersMoreArg:
   Calling Number=, Called Number=20, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=20
   Calling Number=, Called Number=206, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=206
   Calling Number=, Called Number=2065, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2065
   Calling Number=, Called Number=20650, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=20650
   Calling Number=, Called Number=206501, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=206501
   Calling Number=, Called Number=2065011, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2065011
   Calling Number=, Called Number=20650110, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=20650110
   Calling Number=, Called Number=206501100, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=206501100
   Calling Number=, Called Number=2065011001, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2065011001
   Result=SUCCESS(0)
     1: Dial-peer Tag=101
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Calling Number=2065011001, Called Number=2065011001, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
   Calling Number=2065011001, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
   Result=SUCCESS(0)
ISDN Se0/1/0:23 Q931: Applying typeplan for sw-type 0x3 is 0x4 0x1, Calling num 2065015111
ISDN Se0/1/0:23 Q931: Sending SETUP  callref = 0x0082 callID = 0x8003 switch = primary-5ess interface = Network
ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0082
                Standard = CCITT
ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8082
DNA RESULTS
Results Summary
AAR Group Name =
AAR CSS =
Pattern = \+1512!
Time Schedule =
End Device = RL_Branch1-w-Backups
Call Flow
Prefix =
Called Party Mask =
Prefix = +1
Route Pattern :Pattern= \+1512!
DialPlan =
Route Filter
Filter Name =
Filter Clause =
Prefix =
Called Party Mask =
Prefix =
Route List :Route List Name= RL_Branch1-w-Backups
RouteGroup :RouteGroup Name= RG_Branch1-w-Backups
Prefix =
Called Party Mask =
Prefix =
PortNumber = 0
AAR Group Name =
AAR Prefix Digits =
CallerID DN =
Alternate Matches
Pattern
Pattern = \+!
Pattern
Pattern = \+1!
Your outbound call is being released from PSTN. Check your PSTN configuration.
I think PSTN is expecting 7 digit number as called type subscriber from branch 1 as it's local number for branch 1.
Inbound Call
For Branch 1:- Please check the significant digit at MGCP gateway configuration in CUCM. It should be of length as your extension length.
For Branch 2: Share your running config of branch 2 and snap shot of the gateway registered page (i.e page which shows your gateway registered).
Also share your debug voice ccapi inout from branch 2 while making inbound call from PSTN.
Nishant Savalia
Hi Nishant:
  • Please see the attachments for the Gateway pages
  • The significant digits for inbound calls for all 3 gateways is '4'
  • Please see the running-configs of the 3 gateways and the PSTN
  • Please see the debugs for the INBOUND calls
Many Thanks,
Ron
The following INBOUND call from the PSTN to 2065011001 is now working, however it is supposed to be routing through CorpHQ and is instead routing through Branch1. Please see 'DEBUG VOIP CCAPI INOUT' & 'DEBUG ISDN Q931'
Branch1#
ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x0096
//22/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x16, digit_event=0x0, enable=FALSE, consume=FALSE)
//22/5A001212800B/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=22
//22/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49E07FD4, callID=0x16, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
//22/5A001212800B/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x49E07FD4, Call Id=22
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
//22/5A001212800B/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=22
//23/5A001212800B/CCAPI/ccGetCallStatistics:
   Call Stats=0x4A5346FC, Call Id=23
//22/5A001212800B/CCAPI/ccConferenceDestroy:
   Conference Id=0xC, Tag=0x0
//22/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xC, Source Interface=0x49E07FD4, Source Call Id=22,
   Destination Call Id=23, Disposition=0x0, Tag=0x0
//23/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xC, Source Interface=0x495BABA4, Source Call Id=23,
   Destination Call Id=22, Disposition=0x0, Tag=0x0
//22/5A001212800B/CCAPI/cc_generic_bridge_done:
//22/5A001212800B/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
//22/5A001212800B/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
//23/5A001212800B/CCAPI/ccCallDisconnect:
//23/5A001212800B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x495BABA4, Tag=0x0, Call Id=23,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
//-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
:cc_free_feature_vsa freeing 4821DDE8
vsacount in free is 1
//22/5A001212800B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49E07FD4, Tag=0x0, Call Id=22,
:cc_free_feature_vsa freeing 4821DEC8
vsacount in free is 0
ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x8096
ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0096
ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0097
                Standard = CCITT
//-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49E07FD4, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D000000002f5368f000000F580000097)
//-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
:cc_get_feature_vsa malloc success
cc_get_feature_vsa count is 1
:FEATURE_VSA attributes are: feature_name:0,feature_time:1210179280,feature_id:24
//24/74820328800C/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
//24/74820328800C/CCAPI/ccCallSetContext:
   Context=0x4A524790
   Interface=0x495BABA4, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
cc_get_feature_vsa count is 2
:FEATURE_VSA attributes are: feature_name:0,feature_time:1210179056,feature_id:25
//25/74820328800C/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
//25/74820328800C/CCAPI/ccCallSetContext:
   Context=0x4A524580
//25/74820328800C/CCAPI/cc_api_call_connected:
   Interface=0x495BABA4, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
//24/74820328800C/CCAPI/cc_api_call_proceeding:
   Interface=0x49E07FD4, Progress Indication=NULL(0)
//24/74820328800C/CCAPI/cc_api_call_connected:
   Interface=0x49E07FD4, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
//24/74820328800C/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x4A2E7368, Call Id=24
//24/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x18, digit_event=0x1, enable=TRUE, consume=FALSE)
//24/74820328800C/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=24
//24/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49E07FD4, callID=0x18, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
//24/74820328800C/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x49E07FD4, Call Id=24
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
//24/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4A2E757C, callID1=0x18, callID2=0x19, tag=0x0)
   (confID=0x4A2E757C, callID1=0x18, gcid=0-0-0-0, tag=0x0)
//25/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4A2E757C, callID2=0x19, gcid=0-0-0-0, tag=0x0)
//24/74820328800C/CCAPI/ccConferenceCreate:
   Conference Id=0x4A2E757C, Call Id1=24, Call Id2=25, Tag=0x0
//24/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xD, Source Interface=0x49E07FD4, Source Call Id=24,
   Destination Call Id=25, Disposition=0x0, Tag=0xFFFFFFFF
//25/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xD, Source Interface=0x495BABA4, Source Call Id=25,
   Destination Call Id=24, Disposition=0x0, Tag=0x0
//24/74820328800C/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xD, Destination Call Id=25)
//25/74820328800C/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xD, Destination Call Id=24)
//24/74820328800C/CCAPI/cc_api_caps_ind:
   Destination Interface=0x495BABA4, Destination Call Id=25, Source Call Id=24,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
//25/74820328800C/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49E07FD4, Destination Call Id=24, Source Call Id=25,
   Caps(Codec=0x4, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
//25/74820328800C/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=9314)
//24/74820328800C/CCAPI/cc_api_caps_ack:
//24/74820328800C/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x49E07FD4, Call Id=24
//24/74820328800C/CCAPI/cc_api_voice_mode_event:
   Call Id=24
   Call Entry(Context=0x4A524790)
//24/74820328800C/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xD, Call Id1=24, Call Id2=25
//24/74820328800C/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
//24/74820328800C/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=24
ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8097
   Nominator=0x1000, Params=0x4A2E6E68, Call Id=24
ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x8097
        Progress Ind i = 0x8088 - In-band info or appropriate now available
//24/74820328800C/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=24
//24/74820328800C/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
The following INBOUND call from the PSTN to 5126022001 fails and is supposed to be routing through Branch1 and is instead routing through CorpHQ. Please see 'DEBUG VOIP CCAPI INOUT'
CorpHQ#
//-1/A31ADF52800B/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=5126026222
   cisco-anitype=4
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=5126022001
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
//-1/A31ADF52800B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x49F42894, Call Info(
   Calling Number=5126026222,(Calling Name=)(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=5126022001(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
//-1/A31ADF52800B/CCAPI/ccCheckClipClir:
   In: Calling Number=5126026222(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=5126026222(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
:FEATURE_VSA attributes are: feature_name:0,feature_time:1241383960,feature_id:13
//13/A31ADF52800B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=5126026222(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=5126022001(TON=Subscriber, NPI=ISDN))
//13/A31ADF52800B/CCAPI/cc_process_call_setup_ind:
   Event=0x497D0010
//-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 5126022001
//13/A31ADF52800B/CCAPI/ccCallSetContext:
   Context=0x4A131A54
   >>>>CCAPI handed cid 13 with tag 1 to app "_ManagedAppProcess_Default"
//13/A31ADF52800B/CCAPI/ccCallProceeding:
//13/A31ADF52800B/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
//13/A31ADF52800B/CCAPI/cc_api_get_transfer_info:
//13/A31ADF52800B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49F42894, Tag=0x0, Call Id=13,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
:cc_free_feature_vsa freeing 49FE0410
PSTN#sh run
Building configuration...
Current configuration : 13975 bytes
! No configuration change since last restart
version 12.4
no service pad
no service timestamps debug uptime
no service timestamps log uptime
hostname PSTN
boot-start-marker
boot-end-marker
card type e1 0 0
card type t1 0 1
logging message-counter syslog
no aaa new-model
clock timezone EST -5
clock summer-time EST recurring
network-clock-participate wic 0
network-clock-participate wic 1
no network-clock-participate aim 0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip domain name att.com
ip name-server 177.1.100.110
ip multicast-routing
no ipv6 cef
isdn switch-type primary-ni
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol cisco
sip
  bind control source-interface Loopback10
  bind media source-interface Loopback10
  header-passing
voice translation-rule 101
rule 1 /^\+.*/ //
rule 2 /^501.*/ //
rule 3 /^1206.*/ //
rule 4 /^00.*/ //
rule 5 /^0011.*/ //
rule 6 /^206/ /1206/
rule 7 /^1512.*/ /\0/
rule 8 /^011\(.*\)/ /\1/
voice translation-rule 102
rule 1 /^1\(2065015111\)$/ /\1/ type any subscriber plan any isdn
rule 2 /^1\(2065015555\)$/ /\1/ type any subscriber plan any isdn
rule 3 /^1\(2065015151\)$/ /\1/ type any subscriber plan any isdn
rule 4 /^1\(5126026222\)$/ /\1/ type any national plan any isdn
rule 5 /^31670357575$/ /&/ type any international plan any isdn
rule 6 /^31207037333$/ /&/ type any international plan any isdn
rule 7 /^31107047444$/ /&/ type any international plan any isdn
rule 8 /^911$/ /&/ type any unknown plan any unknown
rule 9 /^15126022.../ /&/ type any unknown plan any unknown
rule 10 /^31207033.../ /&/ type any unknown plan any unknown
rule 11 /^....$/ /&/ type any unknown plan any unknown
voice translation-rule 103
rule 1 /^206.*/ /&/ type any subscriber plan any isdn
rule 2 /^1/ // type any national plan any isdn
rule 3 /^00/ // type any international plan any isdn
voice translation-rule 201
rule 1 /^\+.*/ //
rule 2 /^602.*/ //
rule 3 /^1512.*/ //
rule 4 /^00.*/ //
rule 5 /^0011.*/ //
rule 6 /^512/ /1&/
rule 7 /^1206.*/ /&/
rule 8 /^011\(31.*\)/ /\1/
voice translation-rule 202
rule 1 /^1\(5126026222\)$/ /\1/ type any subscriber plan any isdn
rule 2 /^1\(2065015555\)$/ /\1/ type any national plan any isdn
rule 3 /^1\(2065015151\)$/ /\1/ type any national plan any isdn
rule 4 /^1\(2065015111\)$/ /\1/ type any national plan any isdn
rule 9 /^12065011.../ /&/ type any unknown plan any unknown
voice translation-rule 203
rule 1 /^512.*/ /&/ type any subscriber plan any isdn
voice translation-rule 301
rule 1 /^\+.*/ //
rule 2 /^20.*/ //
rule 3 /^0\([1-8].*\)/ /31\1/
rule 4 /^011/ //
rule 5 /^0031/ //
rule 6 /^703..../ /3120&/
rule 7 /^00\(1.*\)/ /\1/
voice translation-rule 302
rule 1 /^31207037333$/ /7037333/ type any subscriber plan any isdn
rule 2 /^7033\(...\)$/ /0207033\1/
rule 3 /^911$/ /112/ type any unknown plan any unknown
rule 4 /^31\(670357575\)$/ /0\1/ type any national plan any isdn
rule 5 /^31\(107047444\)$/ /0\1/ type any national plan any isdn
rule 6 /^12065015555$/ /&/ type any international plan any isdn
rule 7 /^12065015151$/ /&/ type any international plan any isdn
rule 8 /^12065015111$/ /&/ type any international plan any isdn
rule 9 /^15126026222$/ /&/ type any international plan any isdn
rule 10 /^12065011...$/ /&/ type any unknown plan any unknown
rule 11 /^15126022...$/ /&/ type any unknown plan any unknown
rule 12 /^....$/ /&/ type any unknown plan any unknown
voice translation-rule 303
rule 1 /^703.*/ /&/ type any subscriber plan any isdn
rule 2 /^010/ // type any national plan any isdn
rule 3 /^1/ // type any international plan any isdn
voice translation-rule 1000
rule 1 /.*\(1...$\)/ /206501\1/
rule 2 /.*\(2...$\)/ /512602\1/
rule 3 /.*\(45..$\)/ /020757\1/
voice translation-rule 1001
rule 1 /^1206...5...$/ /+&/
rule 2 /^1512...6...$/ /+&/
rule 3 /^31.0...7...$/ /+&/
voice translation-profile 1-HQ-Change_DNIS-Check_ANI
translate called 101
voice translation-profile 1-HQ-Proper_Types
translate calling 102
translate called 103
voice translation-profile 2-BR1-Change_DNIS-Check_ANI
translate called 201
voice translation-profile 2-BR1-Proper_Types
translate calling 202
translate called 203
voice translation-profile 3-BR2-Change_DNIS-Check_ANI
translate called 301
voice translation-profile 3-BR2-Proper_Types
translate calling 302
translate called 303
voice translation-profile SIP-NORMALIZE-DNIS-ANI
translate calling 1001
translate called 1000
voice-card 0
dspfarm
archive
log config
  hidekeys
controller E1 0/0/0
clock source internal
pri-group timeslots 1-3,16
description == Voice Circuit to Branch2
controller T1 0/1/0
cablelength long 0db
pri-group timeslots 1-3,24
description == Voice Circuit to CorpHQ
controller T1 0/1/1
description == Voice Circuit to Branch1
interface Loopback0
ip address 177.1.254.254 255.255.255.255
ip address 177.1.254.250 255.255.255.255
interface Loopback11
ip address 177.1.254.251 255.255.255.255
interface FastEthernet0/0
description ==TO INTERNET==
ip address 192.168.1.150 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description === To HQ
ip address 177.1.19.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
description == PRI Circuit to R3-BR2
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn protocol-emulate network
isdn incoming-voice voice
isdn negotiate-bchan resend-setup
no isdn outgoing ie network-facility
isdn outgoing display-ie
no cdp enable
interface Serial0/1/0:23
description == PRI Circuit to R1-HQ
no ip address
encapsulation hdlc
isdn switch-type primary-5ess
no cdp enable
interface Serial0/1/1:23
description == PRI Circuit to R2-BR1
no ip address
encapsulation hdlc
isdn supp-service name calling
no cdp enable
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
control-plane
voice-port 0/0/0:15
translation-profile incoming 3-BR2-Change_DNIS-Check_ANI
description == Voice PRI to Branch2
voice-port 0/1/0:23
translation-profile incoming 1-HQ-Change_DNIS-Check_ANI
description == Voice PRI to CorpHQ
voice-port 0/1/1:23
translation-profile incoming 2-BR1-Change_DNIS-Check_ANI
description == Voice PRI to Branch1
description == All inbound calls from HQ BR1 BR2 into PSTN
direct-inward-dial
dial-peer voice 101 pots
description == Subscriber Calls from PSTN into CorpHQ
translation-profile outgoing 1-HQ-Proper_Types
preference 1
direct-inward-dial
port 0/1/0:23
forward-digits 10
dial-peer voice 102 pots
description == National Calls from PSTN into CorpHQ
preference 1
destination-pattern ^12065011...$
direct-inward-dial
port 0/1/0:23
forward-digits 10
dial-peer voice 103 pots
description == International Calls into CorpHQ from PSTN Coming from NL Ph
preference 1
destination-pattern ^0012065011...$
direct-inward-dial
port 0/1/0:23
forward-digits 10
dial-peer voice 104 pots
description == + Calls into CorpHQ from PSTN Coming from Mobiles
preference 1
destination-pattern +12065011...$
direct-inward-dial
port 0/1/0:23
forward-digits 10
dial-peer voice 201 pots
description == Subscriber Calls from PSTN into Branch1
translation-profile outgoing 2-BR1-Proper_Types
preference 1
destination-pattern ^5126022...$
direct-inward-dial
port 0/1/1:23
forward-digits 10
dial-peer voice 202 pots
description == National Calls from PSTN into Branch1
preference 1
destination-pattern ^15126022...$
direct-inward-dial
port 0/1/1:23
forward-digits 10
dial-peer voice 203 pots
description == International Calls into Branch1 from PSTN Coming from NL Ph
preference 1
destination-pattern ^0015126022...$
direct-inward-dial
port 0/1/1:23
forward-digits 10
dial-peer voice 204 pots
description == + Calls into Branch1 from PSTN Coming from Mobiles
preference 1
destination-pattern +15126022...$
direct-inward-dial
port 0/1/1:23
forward-digits 10
dial-peer voice 301 pots
description == Subscriber Calls from PSTN into Branch2
translation-profile outgoing 3-BR2-Proper_Types
destination-pattern ^7033...$
direct-inward-dial
port 0/0/0:15
forward-digits 7
dial-peer voice 302 pots
description == National Calls from PSTN into Branch2
destination-pattern ^0207033...$
direct-inward-dial
port 0/0/0:15
forward-digits 10
dial-peer voice 303 pots
description == International Calls into Branch2 from PSTN Coming from US Ph
destination-pattern ^01131207033...$
direct-inward-dial
port 0/0/0:15
forward-digits 9
prefix 0
dial-peer voice 304 pots
destination-pattern ^31207033...$
direct-inward-dial
port 0/0/0:15
forward-digits 9
prefix 0
dial-peer voice 305 pots
description == + Calls into Branch2 from PSTN Coming from Mobiles
destination-pattern +31207033...$
direct-inward-dial
port 0/0/0:15
forward-digits 9
prefix 0
dial-peer voice 1000 voip
description == Calls into AT&T SIP ITSP for VC Week1 Lab1
rtp payload-type nse 99
rtp payload-type nte 100
voice-class sip localhost dns:sip1.att.com
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 5000 voip
service aa
destination-pattern A5000
session target ipv4:177.1.254.254
incoming called-number A5000
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
num-exp 1888....... 911
num-exp 1900....... 911
num-exp 1976....... 911
num-exp 1777....... 911
num-exp 1444....... 911
num-exp 0800....... 911
num-exp 0900....... 911
sip-ua
telephony-service
no auto-reg-ephone
max-ephones 1
max-dn 10
ip source-address 177.1.254.254 port 2000
caller-id block code *67
system message You WILL PASS this Exam!
voicemail A5000
max-conferences 8 gain -6
call-forward pattern .T
dn-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Sep 01 2012 15:29:37
ephone-dn  1  dual-line
number 12065015111 secondary +12065015111
label Seattle, US +1 206 501 5111
description INE PSTN Phone
name Seattle US Phone
ephone-dn  2  dual-line
number 15126026222 secondary +15126026222
label Austin, US +1 512 602 6222
name Austin TX Phone
ephone-dn  3  dual-line
number 31207037333 secondary +31207037333
label Amsterdam, NL +31 20 703 73 33
name Amsterdam NL Phone
ephone-dn  4  dual-line
number 12065015555 secondary +12065015555
label Hurley Mobile +1 206 501 5555
name Hurley's Mobile
call-forward busy A5000
call-forward noan A5000 timeout 16
ephone-dn  5  dual-line
number 12065015151 secondary +12065015151
label Hurley's Home +1 206 501 5151
name Hurley's Home
call-forward noan A5000 timeout 12
ephone-dn  6  dual-line
number 31670357575 secondary +31670357575
label Sawyer's Mobile +31 6 70357575
name Sawyer's Mobile
ephone-dn  7  dual-line
number 911 secondary 112
label US/EU Emer/FreePhone/Prem
name Emergency Services
ephone-dn  8  dual-line
number 15126026262 secondary +15126026262
label BLinus Mobile +1 512 602 6262
name Benjamin Linus Mobile
ephone-dn  9  dual-line
number 31207037373 secondary +31207037373
label DHume Home +31 20 703 73 73
name Desmond Hume Home
ephone-dn  10  dual-line
number 31107047444 secondary +31107047444
label Rotterdam, NL +31 10 704 74 44
name Rotterdam NL Phone
ephone  1
device-security-mode none
mac-address A456.3040.0DAA
type 7975
button  1:1 2:2 3:3 4:10
button  5:6 6o7,8,5,4
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous level 0 limit 20
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
no login
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
scheduler allocate 20000 1000
ntp source Loopback0
ntp master 10
ntp server 64.90.182.55
end
CorpHQ#sh run
Current configuration : 6353 bytes
version 12.4
no service pad
hostname CorpHQ
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone PST -8
clock summer-time PDT recurring
network-clock-select 1 T1 0/0/0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 177.1.11.1 177.1.11.14
ip dhcp excluded-address 177.1.11.21 177.1.11.254
ip dhcp excluded-address 177.2.11.1 177.2.11.14
ip dhcp excluded-address 177.2.11.21 177.2.11.254
ip dhcp pool CorpHQ-Phones
   network 177.1.11.0 255.255.255.0
   option 150 ip 177.1.10.10 177.1.10.20
   default-router 177.1.11.1
   dns-server 177.1.100.110
ip dhcp pool Branch1-Phones
   network 177.2.11.0 255.255.255.0
   default-router 177.2.11.1
no ip domain lookup
no ipv6 cef
voice service voip
fax protocol cisco
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
rule 1 // // type any subscriber plan any isdn
rule 1 // // type any national plan any isdn
rule 1 // // type any international plan any isdn
rule 1 /^[2-9].........$/ /9&/
rule 2 /^1[2-9].........$/ /9&/
rule 3 /^011/ /9&/
voice translation-profile MakeInternational
translate called 3
voice translation-profile MakeNational
translate called 2
voice translation-profile MakeSubscriber
translate called 1
voice translation-profile Prefix9_InFrom_CUCM
translate called 10
voice-card 0
dsp services dspfarm
archive
log config
  hidekeys
controller T1 0/0/0
description == Voice Circuit to PSTN
interface Loopback0
ip address 177.1.254.1 255.255.255.255
ip pim dense-mode
description == To CorpHQ-Switch
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
description == Server VLAN
encapsulation dot1Q 10
ip address 177.1.10.1 255.255.255.0
ip pim dense-mode
interface FastEthernet0/0.11
description == Voice VLAN
encapsulation dot1Q 11
ip address 177.1.11.1 255.255.255.0
ip helper-address 177.1.10.10
ip nbar protocol-discovery
ip pim dense-mode
interface FastEthernet0/0.12
description == Data VLAN
encapsulation dot1Q 12
ip address 177.1.12.1 255.255.255.0
interface FastEthernet0/0.13
description == PSTN PHONE VLAN
encapsulation dot1Q 13
ip address 177.1.13.1 255.255.255.0
description === To PSTN
ip address 177.1.19.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
no cdp enable
description == Frame-Relay Circuit to WAN
no ip address
encapsulation frame-relay
fair-queue 64 256 36
cdp enable
frame-relay lmi-type ansi
ip rsvp bandwidth
interface Serial0/1/0.1 point-to-point
description == FR To BR1
bandwidth 384
ip address 177.0.101.1 255.255.255.0
ip pim dense-mode
snmp trap link-status
frame-relay interface-dlci 101
ip rsvp bandwidth 136
interface Serial0/1/0.2 point-to-point
description == FR To BR2
ip address 177.0.201.1 255.255.255.0
frame-relay interface-dlci 102
router ospf 1
ip route 0.0.0.0 0.0.0.0 177.1.19.1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0.10
no ip http server
control-plane
voice-port 0/0/0:23
voice-port 0/3/0
voice-port 0/3/1
ccm-manager music-on-hold
sccp local Loopback0
sccp ccm 177.1.10.10 identifier 1 priority 1 version 5.0.1
sccp ccm 177.1.10.20 identifier 2 priority 2 version 5.0.1
sccp ccm 177.1.254.3 identifier 3 priority 3 version 5.0.1
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 2 priority 1
associate ccm 1 priority 2
associate ccm 3 priority 3
associate profile 1 register CorpHQ-729-MTP
associate profile 2 register CorpHQ-711-MTP
associate profile 3 register CorpHQ-HW-Xcode
dspfarm profile 3 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec ilbc
maximum sessions 2
associate application SCCP
dspfarm profile 1 mtp
codec g729ar8
codec g729r8
rsvp
maximum sessions software 10
dspfarm profile 2 mtp
codec g711ulaw
rsvp
direct-inward-dial
no digit-strip
port 0/0/0:23
port 0/0/0:23
port 0/0/0:23
forward-digits 11
port 0/0/0:23
prefix 011
voice-class codec 1
dial-peer hunt 1
sip-ua
line con 0
exec-timeout 0 0
privilege level 15
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
no login
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
ntp master 2
ntp server 177.1.254.254
end
Branch1#sh run
Current configuration : 3838 bytes
! Last configuration change at 01:19:02 CDT Thu Oct 10 2013
version 12.4
no service pad
hostname Branch1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CST -6
clock summer-time CDT recurring
dot11 syslog
ip source-route
ip cef
no ipv6 cef
ntp update-calendar
ntp server 177.1.254.1
voice-card 0
archive
log config
  hidekeys
controller T1 0/0/0
pri-group timeslots 1-3,24 service mgcp
interface Loopback0
ip address 177.1.254.2 255.255.255.255
no ip address
duplex auto
speed auto
ip address 177.2.11.1 255.255.255.0
ip helper-address 177.1.254.1
ip pim dense-mode
ip address 177.2.12.1 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
no ip address
encapsulation hdlc
isdn bind-l3 ccm-manager
isdn outgoing ie facility
isdn outgoing ie redirecting-number
no cdp enable
no ip address
fair-queue 64 256 37
cdp enable
no frame-relay inverse-arp
ip rsvp bandwidth
description == FR To HQ
ip address 177.0.101.2 255.255.255.0
ip pim dense-mode
no ip address
shutdown
clock rate 2000000
router ospf 1
no ip http server
control-plane
voice-port 0/0/0:23
ccm-manager fallback-mgcp
ccm-manager redundant-host 177.1.10.10
ccm-manager mgcp
no ccm-manager fax protocol cisco
mgcp
mgcp call-agent 177.1.10.20 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp fax t38 ecm
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
sccp
sccp ccm group 1
associate profile 3 register Br1-HW-Xcode
associate profile 1 register Br1-729-MTP
associate profile 2 register Br1-711-MTP
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
codec g729ar8
codec g729r8
rsvp
codec g711ulaw
rsvp
line con 0
exec-timeout 0 0
privilege level 15
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
no login
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
end
Branch2#sh run
Current configuration : 5789 bytes
version 12.4
no service pad
hostname Branch2
boot-start-marker
boot system flash:c2800nm-advipservicesk9-mz.124-24.T7.bin
boot system flash:
boot-end-marker
card type e1 0 0
no aaa new-model
clock timezone CEST 1
clock summer-time CEDT recurring
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice service voip
no supplementary-service h225-notify cid-update
fax protocol cisco
voice class codec 1
voice class custom-cptone JOIN-TONE
dualtone conference
  frequency 300 3600
  cadence 150 100 500
voice class custom-cptone LEAVE-TONE
dualtone conference
  frequency 300 3600
  cadence 500 100 150
rule 1 /^7033...$/ /020&/
rule 1 /^0/ /0&/
voice translation-rule 200
rule 1 /^206501...$/ /1&/
voice translation-profile 7DigitDNIS-to-10Digit
translate called 1
voice translation-profile Prefix0_InFrom_CUCM
translate called 10
voice translation-profile Prefix1-toCorpHQ-ANI
translate calling 200
voice-card 0
archive
log config
  hidekeys
controller E1 0/0/0
controller E1 0/0/1
interface Loopback0
ip address 177.1.254.3 255.255.255.255
h323-gateway voip bind srcaddr 177.1.254.3
no ip address
duplex auto
speed auto
ip address 177.3.11.1 255.255.255.0
ip address 177.3.12.1 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
no ip address
encapsulation hdlc
isdn bchan-number-order ascending
no cdp enable
no ip address
cdp enable
ip rsvp bandwidth
ip address 177.0.201.2 255.255.255.0
no ip address
shutdown
clock rate 2000000
interface Service-Engine1/0
no ip address
shutdown
router ospf 1
ip http server
ip http path flash:
control-plane
voice-port 0/0/0:15
translation-profile incoming 7DigitDNIS-to-10Digit
sccp
sccp ccm group 1
associate profile 4 register Br2-HW-Conf
associate profile 3 register Br2-HW-Xcode
associate profile 2 register Br2-711-MTP
associate profile 1 register Br2-729-MTP
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dspfarm profile 4 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
conference-join custom-cptone JOIN-TONE
conference-leave custom-cptone LEAVE-TONE
codec g729ar8
codec g729r8
rsvp
codec g711ulaw
rsvp
direct-inward-dial
destination-pattern 112
no digit-strip
port 0/0/0:15
destination-pattern 00[1-9]T
port 0/0/0:15
prefix 0
translation-profile outgoing Prefix1-toCorpHQ-ANI
destination-pattern 000T
port 0/0/0:15
prefix 00
description == Inbound/Outbound H323 PSTN GW From/To GK and CUCM Pub
translation-profile incoming Prefix0_InFrom_CUCM
destination-pattern 0207033...$
voice-class codec 1
dial-peer voice 101 voip
description == Outbound H323 PSTN GW To CUCM Sub
voice-class codec 1
session target ipv4:177.1.10.20
dial-peer hunt 1
telephony-service
max-ephones 1
max-dn 1
ip source-address 177.1.254.3 port 2000
moh test.au
multicast moh 239.2.1.1 port 16384 route 177.1.254.3 177.3.11.1
create cnf-files version-stamp 7960 Sep 13 2013 18:55:27
line con 0
exec-timeout 0 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
ntp update-calendar
end
