Call drops after 75 minutes on a SIP Trunk
asharsidd
One of our customer has a SIP trunk for inbound/outbound calls.
They are having an issue with call dropping after like 75 minutes. The duration is not confirmed as sometimes it drops even before 75 minutes.
They had the same issue before when call use to drop after 30 minutes but then their provider asked them to add the following lines which kind of resolved it but now it's dropping after 75 mins (approx).
I have attached some running config and debugs. Provider says that the 'BYE' message is coming from our end (Call manager/Gateway).
Is there any setting in Call manager or gateway which is causing this issue?
CCM: System version: 7.1.3.32900-4
CUBE-10#sh ver
Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 09:15 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
CUBE-10 uptime is 27 weeks, 3 days, 44 minutes
voice-card 0
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections sip to sip
fax protocol cisco
sip
  options-ping 180
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
voice class sip-profiles 1
request INVITE sip-header Allow-Header modify ", UPDATE" ""
dial-peer voice 10 voip
description *** Outbound to Gamma - SIP Provider ***
translation-profile outgoing OUTBOUND
huntstop
destination-pattern 9T
voice-class codec 1
voice-class sip early-offer forced
voice-class sip profiles 1
session protocol sipv2
session target ipv4:10.0.222.69
dtmf-relay rtp-nte
fax-relay sg3-to-g3
no vad
gateway
timer receive-rtp 1200
sip-ua
retry invite 1
retry response 2
retry bye 2
retry cancel 1
retry options 1
timers trying 200
Debug Output:
Jul 11 12:17:54.579 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:079XXXXXXX@10.0.222.69:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.222.65:5060;branch=z9hG4bK100B17D
From: "anonymous" <sip:anonymous@10.0.222.65>;tag=B891B2E8-282
To: <sip:079XXXXXXX@10.0.222.69>;tag=3519367399-656588
Date: Mon, 11 Jul 2011 11:15:27 GMT
Call-ID: D687F817-AADB11E0-A725957A-CA524E0B@10.0.222.65
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1310383074
CSeq: 128 BYE
Reason: Q.850;cause=16
Content-Length: 0
Jul 11 12:17:54.591 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 128 BYE
Allow: INVITE, BYE, OPTIONS, CANCEL, ACK, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Contact: <sip:079XXXXXXX@10.0.222.69:5060>
Content-Leng
2 Accepted Solutions
linuxchild
Hello
I had a pb that looks like this one , but it was each 10 min , here is what I have done
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback none
h323
  session transport udp
sip
  bind media source-interface FastEthernet0/0
  sip-profiles 100
voice class sip-profiles 100
request INVITE sip-header Allow-Header modify " UPDATE, " " "
request REINVITE sip-header Allow-Header modify " UPDATE, " " "
response 200 sip-header Allow-Header modify " UPDATE, " " "
response 180 sip-header Allow-Header modify " UPDATE, " " "
phamvinhdat
Level 3
Level 3
I have similar problem in the past with version 7. Call dropped after 30 mniutes. In working with TAC, they suggest to increase the "SIP Session Expires Timer" to the max from Service Parameter ==> Call Manager Services. It did help in my case.
Dat
9 Replies 9
linuxchild
Hello
voice service voip
h323
sip
  sip-profiles 100
Thanks.
Did it resolve your issue of call drop then?
yes, this config solved my pb
Hello, sorry to bring up the old post. I had this issue and also the sip profiles fixed this for me.
But can you explain what is doing? It is fixed, but I want to better understand what we fixed. I understand that is removing the UPDATE option from the invite. But why would having the UPDATE option cause the call to drop?
Is the provider not accepting UPDATE? And if yes, what is now sent, instead of UPDATE to refresh the session?
Thank you
Ess
Ess,
First of all this is a very good question you have brought up. I have seen many people use this and I am sure most people done know why it is working. So lets try and figure it out..
The answer to this lies in a bug with some version of CUBE..
CUBE: Session refresh via sip UPDATE is consumed by CUBE
CSCty36625
Symptom:
SIP to SIP calls may disconnect on CUBE enterprise after the session refresh timer expires if the far end device attempts to do session refresh via SIP UPDATE messages instead of using a SIP re-invite.
Conditions:
This was seen on a SIP to SIP CUBE running on a 3945 with IOS version 15.1(4)M2.
Workaround:
Use SIP profiles to remove "UPDATE" from the Supported header to prevent the far end device from sending SIP updates to CUBE. For example:
voice class sip-profiles 2
request ANY sip-header Allow-Header modify "UPDATE[,]* " ""
response ANY sip-header Allow-Header modify "UPDATE[,]* " ""
dial-peer voice 1 voip
voice-class sip profiles 2
The second answer to this is that when the UPDATE method is removed, then session refresh is done via REINVITE message that contains a session refresh parameter
Looks like CUBE works better when session refresh is done with re-INVITEs rather than UPDATE
Please rate all useful posts
phamvinhdat
Level 3
Level 3
Dat
Thanks.
Let me apply these settings and test.
If anyone else has a better resolution do let us know.
I too had this issue (CUCM 7.1.5, CUBE 15.1T(3) ) and it was resolved by increasing the Service parameter in timer CCM.
asharsidd
Thanks guys.
I increased the timer and added those commands as well under the voice class.
Customer confirmed they had a call which lasted for 3 hours and it didn't drop.
Cheers all.
