call forward not working with the uccx agent
Hello Experts ,
I have very Strang behavior that if the call forward from ccx agent IP phone , customer hear MOH and call not establish
but if the call forward from the same IP Phone directly works normally
Call Flow that CFA works ,
VG >>> CUCM >> IP phone ( CFA to mobile line ) it works fine
but Call flow doesn't work
VG >>> CUCM >> UCCX  >> Agent IP phone (CFA to mobile line)
  a strange behavior Customer hear MOH and mobile not ringing
but all the sudden, if the number of mobile is the same as CFW it works normally
CUCM Logs , VG logs attached
please I need urgent help
CUCM version : System version: 10.5.2.12901-1
2 Accepted Solutions
From what I know call forward on CCX agent lines are not intended to work.
Response Signature
Jonathan Schulenberg
Neither Call Forwarding or iDivert are supported on agent IPCC DNs. The release notes says these features are not supported. Don’t do this; it may trigger a memory leak on CCX (not joking). It also risks undermining historical reports if that CCDR is left in an inconsistent state. I create a dedicated softkey template for call center agents that removes all unsupported actions (eg park, pickup, iDivert, barge, CFA, etc).
Response Signature
@Roger Kallberg  , I thought that Roger, since the CTI port couldn't be the caller even if it takes all the correct CSS but there's no document from cisco telling that, .. let us check if someone has the solution or any workaround.
As per my memories CFA on agent phone was simply ignored when call center connected a call to the agent. Now if CFA is set on agent phone, the "connect" operation fails.
Did it change at some point or my memory fails me and it never worked?
