Call forward to a especific extension depending the caller number
d.babiano
Hi to all,
I have a CUCM v.8.5.1 and I need to do a call forward to a especific extension depending the caller number. I know about other systems (such Avaya systems) which can do this. Cisco can do it?? How??
Somebody can pass me any help page about this. I'm trying to do this with the transformations patterns but isn't working and with a CUE script but I don't know how I can do to tell to the CUE what number is calling and to compare it and to forward to the correct extension.
Thanks to all.
Aaron Harrison
Hi David
See this doc:
https://supportforums.cisco.com/docs/DOC-18367
Basically it's angled towards blocking calls, but the only difference for you would be in step 8 where you use translation patterns - you would translate to the extension you want to send to, rather than selecting 'block this pattern'.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Hi David
See this doc:
Aaron
Hi Aaron,
thanks for this doc. I'll test this and I'll ell you something.
Regards.
