Make the # optional in a route pattern
Hello.
My question is simple.
I have an existing route pattern.
Can I make add the # (
that indicates end of dialing sequence) at the end as an option
The idea is to avoid copying the same route pattern and duplicate..
BR
Davi
Terry Cheema
Davi,
This can be done, if I am getting your question correctly. I have been using this for variable route patterns instead of creating duplicate route patterns, works very well.
For example:
For 9.011! Route pattern, instead of creating two route patterns 9.011! and 9.011!# - You can create one route pattern 9.011![0-9#]. This will make # as optional. If you enter # after the number it will dial the number correctly. If you dont enter the # then it will just wait for t302/interdigit timer to expire and route the pattern as per normal.
So just add [0-9#] after !. This way it will route anything ending with 0-9 or #.
Examples:
9.! -> can be created as  9.![0-9#]
9.011! ->  9.011![0-9#]
Terry
7 Replies 7
will.alvord
Level 5
Level 5
According to the docs, it's not possible.
"The question mark (?) wildcard matches zero or more occurrences of the preceding digit or wildcard value."
...but the notes for # state:
"Ensure the # character is the last character in the pattern."
Like Will said, it's not posible, you will need to duplicate the router pattern to make it work as a option.
Please rate all useful posts
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
You could do that with a route filter.
HTH,
Chris
Terry Cheema
Davi,
For example:
Examples:
Terry
I learned something new today . Terry (5).
Favor calificar todos las respuestas útiles.
Thanks Leo!
Davi - Please let us know if you have any further questions on this. If this resolves your query please mark the thread as answered.
Terry
Thank you Terry.
I have tested and it works.
Thanks for the kind help.
Cheers
