Call Manager 8.5 image upload issue
tiger_401
Dear All,
I am trying to upload call manager version 8.5 image through sFTP server. sFTP is configured properly.
But i dont know due what reason whenever i am trying to upload the image it is giving this error
No valid upgrade options were found
Please find attached screenshoot as well.
Kindly gudie me what could be the possible reasons for this error.
Malik.
7 Accepted Solutions
Hi Malik,
Please do on SUB .
Please share the output of command show bersion active and show version inactive from PUB.
regds,
aman
Hi Malik,
Please proceed with PUB.
regds,
aman
Aman Soi
Hi Malik,
Please mark this as answered since you have already rated the POST.
We can still continue to work
regds,
aman
Hi Malik,
You can generate the license file now before migrating to 8.5.
You can either write to Cisco Licensing team or go to www.cisco.com/go/license with PAK and MAC address of Pub.
regds,
aman
Rob Huffman
Hi Malik,
The error that is being displayed indicates the need for the
CUCM 8.x license and in particular the "8.x software feature license"
Without that license the Callmanager service will NOT start and thus
the phones will not register.
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
Rob Huffman
Hi Malik,
Reverting to a previous version can be problematic
Have you tried uploading your new 8.x license(s)? Have you
tried contacting Cisco licensing to secure the required licenses @
licensing@cisco.com
If you must rollback follow these steps and watch for this serious caveat;
Note
If  you downgrade a cluster to a nonsecure previous release of Cisco  Unified Communications Manager (relases prior to Release 8.0), you must  prepare the cluster for rollback before you switch versions. If you do  not prepare the cluster for rollback before you revert to a previous  release, you will have to manually delete the ITL file on each Cisco  Unified IP Phone in the system. For more information, see Chapter 2,  "Security by Default," in the
Cisco Unified Communications Manager Security Guide
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/8_5_1/cucos/iptpch7.html#wp1053899
Cheers!
Rob
- Stones
34 Replies 34
Aman Soi
Hi Malik,
Please let us know the running exact call manager version  along with exact version u are trying to upgrade.
regds,
aman
Hi Aman,
Thanks a lot for your response.
Please find below the required information:
1) Current Running Version-----------6.1.5.12900-7
2) Version to be uploaded  -----------UCSInstall_UCOS_UNRST_8.5.1.15900-4.sgn
Malik.
Hi Malik,
Please refer the Software compatibility matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
You need to install COP file ciscocm.allow_upgrades_to_unrestricted.cop.sgn before u proceed with upgrdae.
regds,
aman
Hi Aman,
Thanks a lot for your prompt response.
is this the correct file
should i go ahead and download it
Just to inform you that i have three nodes in my network
1 publisher
and
2 subscriber
so first of all i should upload this cop file to publisher then to other subscriber node or just to the publisher
Please guide me if i am wrong
i really appreciate your support
Malik
Hi Malik,
You need to upload the file in PUB abd SUB separately.
regds,
aman
Hi Aman,
Once i install the cop file to pub
Kindly can you please tell me what could be the next step
i mean do i need to restart the pub before i proceed
Malik.
Hi Malik,
Most probably, restart message does not come.
After u install the COP file in PUB, if restart message comes, go ahead else install the COP on SUB as well.
After restart of both , install UCSInstall_UCOS_UNRST_8.5.1.15900-4.sgn
If no restart message appears, please install patch  UCSInstall_UCOS_UNRST_8.5.1.15900-4.sgn
regds,
aman
Ok great Aman
Thanks a lot for your support
now i am at this stage on pub then i will move to both the subs
then i will upload the real image 8.5
Hi Aman,
Should i proceed to subscriber.
i am done with pub
please find attachec screenshoot
Malik
Hi Malik,
Please do on SUB .
regds,
aman
Hi Aman,
Please find required information.
Malik
Hi Aman,
I have uploaded the cop files to all the three nodes 1 pub and 2 subs
so should i proceed to upload the real image 8.5 to the pub
thanks a lot for your repsponse.
Malik
Hi Malik,
regds,
aman
