01-13-2017 06:34 AM - edited 03-17-2019 09:10 AM
Hello everyone!
Wanted to open up a forum to discuss your favorite and least-favorite call recording solutions that you use with your CUCM environments.
I've installed Enghouse QMS in a few places with "okay" results. It seems to work better when it's used with call-forking rather than by using a SPAN.
I was also a little disappointed when their support/sales staff told me that on-demand recording was not supported with SIP phones and that we had to purchase a separate license/application from the for a Windows desktop app. The only option was full-time recording or the users would have to login to the web GUI to initiate the recording - which would be ridiculous to ask someone to do.
After delivering these news to my client, I was able to make Enghouse QMS record on-demand using the RECORD softkey in a connected state. For them not to know that this would work is bizarre to me.
Anyhow, let's talk about your favorite solutions and their pros and cons.
01-17-2017 08:40 AM
Have you heard of Calabrio?
They seem to be the most popular solution, and I believe have been recently bought by Cisco.
We have them and have not had many issues so I would highly recommend checking them out.
01-18-2017 07:38 AM
These products seem to be aimed at recording call center environments.
My clients are primarily K12 and just need simple on demand call recording, say if someone calls the main office and says something nasty.
01-17-2017 04:23 PM
Does any part of your install involve Contact Center at all, if so I have found ZOOM to be a solid solution for recording CCE.
01-17-2017 05:31 PM
I have used Verint in the past, not a great fan of it.
01-25-2017 06:31 AM
I'd probably go with MediaSense + Calabrio, you can buy bundle directly from with Cisco and they can give you fairly good discount. And with plans to have Screen Recording with MediaSense 12 it would be complete solution in my opinion.
Or you can just do MediaSense only and buy interface from some other company, but that that depands on the features you need.
Leszek
12-14-2017 01:23 PM
Anybody have any experience with using Versdial as the third party recording vendor?
03-26-2018 03:50 PM
I know its been awhile on this post but was curious if anyone was aware of the replacement for Media Sense?
03-26-2018 06:48 PM
03-26-2018 06:02 PM
For on-demand recording, you can use the Cisco Unity Connection live recording which I believe would satisfy your requirement.
I have use CallReplay. It is simple to setup and integrate. The only problem I had was the support due to big gap in timezone.
03-27-2018 09:16 AM
I ended up going with Versdial and it was fairly straight forward to setup and works well.
05-13-2019 12:38 AM
Opening an old thread with the same question.
Any recommendation changes now in 2019?
Also, is there a way and what is the best way for recording in a secure voice solution (srtp, tls)?
05-13-2019 01:38 AM
Hi Mikhel,
There are many options for Call Recording. You can do via Cisco BiB or Cisco BiB with Secure RTP (sRTP) or SPAN/Port Mirroring OR CUBE Forking, etc.
We (CommSouth) are a solution provider for Call Recording with Cisco and many other Telephonies.
If you are interested, you can contact me at prasana@commsouth.com
Please rate if useful.
Regrds,
Prasana Kumar. P
CommSouth
Head - Business Solutions
+91-9841027006
05-13-2019 02:25 AM - edited 05-13-2019 02:25 AM
We are interested in a solution where it is possible to record both internal and external calls(so recording only on gateway is not sufficient), preferably with SRTP
All phones are newer SIP phones, cucm is 12.5
05-13-2019 03:02 AM
Hi Mihkel,
Yes, this is possible and we can do the SRTP based Call Recording.
You can visit our website www.commsouth.com for more information and can contact me at prasana@commsouth.com
Prasana Kumar.P
CommSouth
+91-9841027006
