12-08-2011 01:38 AM - edited 03-16-2019 08:26 AM
Hi All,
Im setting up a CUCM8.5 system in the UK. for the most part, things are working well
as not to reinvent the wheel, we decided to use the GBNP (3.1.16). this is not working for some reason.
i am trying to call Australian based numbers 0061xxxxxxxxx
i have created pattern 9.@ and put into a partion call UK-LON-PSTN-PT.
this pattern points to a RL/RG > pointing to a H323 gateway.
the CSS on my phone has access to the partition.
i dial 9 (outside line), then when the first 0 is pressed, i get "your call could not be completed as dialed".
i have setup a test Pattern 9.00! and put in the same partiion as 9.@ and point to the same RL/RG. i can then make these calls without issues.
i have several instances of the 9.@ pattern, all in different partitions (for filtering of certain numbers, with route filters). these all have an "exceed Precidence level" so im sure these are not being hit.
i have enable the following debugging. but nothing is showing up at all, so it appears the call is not exiting the CUCM at all.
debug isdn q931
debug voice ccapi inout
does anyone have any ideas?
Solved! Go to Solution.
12-08-2011 04:59 AM
Just as a test - try registering a handset to the publisher and running the call again.
Usually if the @ pattern doesn't work it's an install issue on the sub (not installed, or not 'activated' by browsing to ccmadmin/call routing/dial plan installer/ directly on that subscriber).
Aaron
12-08-2011 01:48 AM
Hi.
Use 9.00! pattern.
9.@ conflict with another 9.XXXXXXX patterns like LD,PSTN and etc.
You can easy see what's going on with DNA tool.
12-08-2011 01:51 AM
Justin,
Hope this is not a stupid question.
Under the Route Pattern Configuration
Pattern 9.@
Have you selected the GBNP in the NUMBERING PLAN field
Just to let you know I have ongoing issues with TAC/Developement re
UK dial plans above Version 2-1-16 for CUCM 6.
Waiting Cisco to reolve many issues re Text relay for (Deaf & Dumb Users)
Wrong ISDN number types being sent
Versiomn 18 wont install on subs even when it is definately on the pb
etc etc.
Alex
12-08-2011 02:42 AM
I have no other 9.XXXXXXXX patterns at all and have no conflicts that i can see.
also the GBNP is definitely installed and active on the Patterns.
i have setup a cluster in Australia using the same method, e.g. AUNP and using 0.@ and i have no probs at all.
as mentioned, i didnt want to re-invent the wheel and create all the route patterns manually.
i am tempted to try a different version but 3.1.16 should be OK
DNA shows the exact same call flow, when using 9.@ and 9.00!
one thing i did notice, then when i do the DNA on my CCM in Australia, (using the 0.@) i can see my "external Phone mask applied in the DNA output", im not sure why this is not happening on the UK CUCM.
ugghhh,..may have to call TAC
12-08-2011 04:59 AM
Aaron
12-08-2011 01:27 PM
Hi Aaron,
thanks for that.
mate, the GBNP was installed on all nodes in the cluster. i uninstalled/reinstalled the dial plan on the affected node then restarted CM service.
it now works,.....Unbelievable.
thanks again
12-08-2011 01:51 PM
All's well that ends well, as we say. I can't count the number of times I've hit similar issues myself :-)
