07-05-2011 12:16 PM - edited 03-16-2019 05:47 AM
I have setup a VG204 for one of our departments to use for their credit card machine and a postage machine, there is aslo a fax machine and a cordless phone on this device and they work okay. when they try and process a credit card or add postage the call initiates but eventually fail. I have the voice-port timeouts set to 60 (initial and interdigit) and timeouts ringing infinity. Is there any special settings on the call manager or on the gateway?
Randy
07-05-2011 03:20 PM
Can you connect a phone to the line and make calls? I would imagine that the ATM and Postage Machine need tone set unlike your analog fax line to properly pass tones for card processing. Could you post the 204 configuration for all 4 lines?
07-05-2011 04:48 PM
How are the calls getting to the PSTN? Is it POTS lines, PRI, SIP, or something else?
If SIP, the codec could be the issue.
07-06-2011 06:37 AM
We are using a PRI.
07-06-2011 07:03 AM
Yes I can hook up a regular phone and it works just fine.
here is the config:
no aaa new-model
ip source-route
ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
voice service voip
h323
voice-card 0
archive
log config
hidekeys
interface FastEthernet0/0
ip address 10.10.X.X 255.255.255.0
speed auto
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 10.10.X.X
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.X.X
no ip http server
control-plane
voice-port 0/0
timeouts initial 60
timeouts interdigit 60
voice-port 0/1
timeouts initial 60
voice-port 0/2
timeouts initial 60
voice-port 0/3
timeouts initial 60
ccm-manager fax protocol cisco
ccm-manager config server 10.10.X.X
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
sccp ccm 10.10.X.X identifier 1 version 4.1
sccp ccm 10.10.X.X identifier 2 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
dial-peer voice 999000 pots
service stcapp
port 0/0
dial-peer voice 999001 pots
service stcapp
port 0/1
dial-peer voice 999002 pots
service stcapp
port 0/2
dial-peer voice 999003 pots
service stcapp
port 0/3
no aaa new-model
ip source-route
ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
voice service voip
h323
voice-card 0
archive
log config
hidekeys
speed auto
full-duplex
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
voice-port 0/0
timeouts initial 60
voice-port 0/1
timeouts initial 60
voice-port 0/2
timeouts initial 60
voice-port 0/3
timeouts initial 60
ccm-manager config
ccm-manager sccp
sccp
sccp ccm group 1
service stcapp
port 0/0
service stcapp
port 0/1
service stcapp
port 0/2
service stcapp
port 0/3
07-06-2011 07:22 AM
Hi Randy
Common cause of this kind of failure is clock slips on your PRI. Check the status of the controller and see it is reporting any slips. Voice isn't impacted by this kind of thing, however modem / fax is.
HTH. Barry
07-06-2011 08:24 AM
Thanks for the info I checked the controller and it is showing that it is up and has 0 slips secs.
09-06-2012 10:21 AM
I am experiencing something similar and looking for a way to fix it. The credit card machine at my location works sometimes but occasionally times out.
The output of "sh controller T1" command shows:
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (446 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
22 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 3 Path Code Violations,
3864 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Is there something I can do to fix the problem? Any advice is greatly appreciated!
Lisa
09-06-2012 10:48 AM
This is often asked
network-clock-select 1 t1 0/0/0
09-06-2012 11:07 AM
Thank you Paolo. I just added that command to my configuration and cleared the counters (I was showing lots of "slips"). I'll monitor the VG for errors and have someone run another credit card payment.
I very much appreciate your very quick response!
09-06-2012 11:10 AM
You're welcome, please remember to rate useful posts clicking on the stars below.
