Can not foward into voicemail from outside call on CUE and CUCM 8.6
Dear Team,
I have CUE Utility and CUCM 8.6.
I can call from local, if user busy or go out office then call will foward to voice mail.It is ok.
But when i call from outside to my phone(direct line), then call can not foward to voice mail on CUE.
Please help me some solution.
Thanks.
15 Replies 15
Gajanan Pande
Could you please provide more details about failure ?
What happens when the outside caller reaches to a point where the call should go to VM e.g. Is it dropping ? or no voice/greeting etc heard ?
What is CUE version ? Was it working earlier ?
GP.
Dear Gajanan Pande
I have one extension ex: 5388 and one more extension ex: 35205388
I call local, from other phone to my phone 5388, voicelmail work ok.
When i call from outsite to my extension 35205388, the phone ring but call not foward to my voicemail.
My CUE version 8.6.
Thanks.
Dear Team,
Anybody here, please help me,
Thanks.
Hi Nam,
Have you checked the connectivity between your voice gateway and CUE? are you able to ping the CUE from your voice gateway.
Pawan Arora
Hi Pawan Arora.
I can ping between voice-gateway and CUE.
I call from outsite to my extension 35205388, the phone ring but phone not foward to voicemail.
Thanks.
Hi nam,
A couple of things to check. Have you set the Forward Busy/No Answer "External"
on the DN config page in CUCM?
Are the calls coming in using a codec other than g.711?
Best Practices for Deploying Cisco Unity Express
• Each mailbox can be associated with a primary extension number and a primary E.164 number.
Typically, this number is the direct-inward-dial (DID) number that PSTN callers use. If the primary
E.164 number is configured to any other number, use Cisco IOS translation patterns to match either
the primary extension number or primary E.164 number so that the correct mailbox can be reached
during SRST mode.
• Each Cisco Unity Express site must be associated with a CTI route point for voicemail and one for
AA (if licensed and purchased), and you must configure the same number of CTI route points as
Cisco Unity Express ports licensed. Ensure that the number of sites with Cisco Unity Express does
not exceed the CTI scalability guidelines presented in the chapter on Call Processing, page 8-1.
• Cisco Unity Express is associated with a JTAPI user on Cisco Unified CallManager. Although a
single JTAPI user can be associated with multiple Cisco Unity Expresses in a system, Cisco
recommends associating each dedicated JTAPI user in Cisco Unified CallManager with a single
Cisco Unity Express.
• Calls into Cisco Unity Express use G.711 only. Cisco recommends using a local transcoder to
convert the G.729 calls traversing the WAN into G.711 calls. You can configure Cisco Unified
CallManager regions with the G.711 voice codec for intra-region calls and the G.729 voice codec
for inter-region calls.
• If transcoding facilities are not available at the Cisco Unity Express site, provision enough
bandwidth for the required number of G.711 voicemail calls over the WAN. Configure the Cisco
Unified CallManager regions with the G.711 voice codec for calls between the IP phones and Cisco
Unity Express devices (CTI ports and CTI route points).
• The CTI ports and CTI route points can be defined in specific locations. Cisco recommends using
location-based call admission control between Cisco Unified CallManager and Cisco Unity Express.
RSVP may also be used.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/4x/42unityx.pdf
Cheers!
Rob
"Far away from your trouble and worry
You belong somewhere you feel free" - Tom Petty
Dear Rob.
Thank you for reply.
-->On DN config, I not check into box Forward Busy/No Answer "External". I only check into box
--> I using codec g.711.
Thanks.
I am having the exact same issue after update software pack from 8.6.0 to 8.6.2. I can use my desk phone (208) and call another desk phone (201) if 201 does not answer it goes to voicemail. If I call with my cell phone to 208 and transfer to 6208 I get dead air. If I transfer 208 transfer 208 rings but if I dont pick it up I just get dead air on my cell??
Shaun
Since this started as a result of a software upgrade, that almost suggests your best bet is to downgrade back to your old software. May be a bug with this release of CUE
Please rate all useful posts
Ayodeji Okanlawon
What type of gateway do you gave? H323 or mgcp?
Can the CSS assigned for inbound calls on the gateway see the partition of your CTI route point and CTI ports?
Can you collect cucm traces and send to us
Sent from Cisco Technical Support Android App
Dear aokanlawon
--> using H323.
--> Yes
Can you help me how to collect cucm traces, type of services ?
Thanks.
Please use this link to learn how to collect cucm traces
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
As you mentioned that you have another extension 35205388. Do you mean that you set two DNs on the same phone with 4 digits and 8 digits DNs? If yes, you should set significant digit in gateway or translation in H323 for cutting 8 digits to 4 digits. Otherwise, you can try to set E164 no. as the 8 digits DN in each voicemail account from CUE.
Dear Kinman-wong
on CUCM, I only set one DN, one extension 5388 and one 3520XXXX network mask for DID.
on CUE, I set E.164 35205388.
From local lan, i call 5388, call foward to voicemail.
From outside, i call 53205388, call not foward to voicemail.
Thanks.
