09-13-2013 12:05 PM - edited 03-16-2019 07:21 PM
Tried 5 different SFTP servers with no success. From the CUCM console, I entered the command: FILE GET ACTIVELOG MOHPREP/*.to retrieve all of the MOH .WAV files, however I cannot get any of the SFTP servers to work without some sort of authentication or path error. I have also tried both ports 21 & 22. Does anyone have a suggestion which SFTP server to use for Windows 7 or do you know where I can find the .WAV files for my CCIE Voice lab?
Many thanks,
Ron
09-13-2013 10:17 PM
It generally works with CoreFTP and freeFTPd. If you are facing network issues then try using a PC in the same subnet as the callmanager to rule out network issues.
Manish
09-14-2013 05:19 AM
Hi Manish:
I'm not dealing with netwok issues because the SFTP server sees the request coming through. I'm getting an error that the path is invalid.
09-14-2013 08:48 AM
Can you share the output of
file list activelog mohprep/*
and
file get activelog mohprep/*
until the point where it fails
Manish
09-14-2013 02:23 PM
If you are running CUCM 7 or earlier you should be able to open the TAR files created by DRS and find the wav files within.
This will not work for CUCM 8 or later as the backups are encrypted (I wish this could be turned off as it is a useful way of getting stuff from the servers ).
Re: SFTP servers I normally use the free Solarwinds one.
I would test the server by using it to upload software (firmware, locale, dial-plan etc.) to CUCM. If this works then the server should be ok for downloads from CUCM.
09-14-2013 03:07 PM
Hi Ron.
Using a Macbook, I usually use my native scp server.
A few minutes ago a tried to install freeftpd from this site
http://www.freesshd.com/?ctt=download and istalled on windows7
A couple of minute of setup and all was working fine.
here my logs
admin:file get activelog mohprep/*.xml
Please wait while the system is gathering files info ...done.
Sub-directories were not traversed.
Number of files affected: 5
Total size in Bytes: 5431
Total size in Kbytes: 5.303711
Would you like to proceed [y/n]? y
SFTP server IP: 10.120.121.15
SFTP server port [22]:
User ID: carlo
Password: ********
Download directory: / (this will store downloaded files on /Users/username windows folder)
The authenticity of host '10.120.121.15 (10.120.121.15)' can't be established.
RSA key fingerprint is 0a:b0:1c:ef:dd:d0:19:db:90:b0:8e:0b:3d:ad:cf:0f.
Are you sure you want to continue connecting (yes/no)? yes
Transfer completed.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-15-2013 06:39 AM
Thanks Carlo. I'll give it a try and get back to you..
Ron
09-15-2013 06:37 AM
I couldn't get Solarwinds to work because I didn't have the authorization to start the SFTP server. I tried to install it as Administrator but I didn't give me that option. Also, my firewall is disabled...
Ron
09-15-2013 08:56 AM
If you have tried five different SFTP servers and non of them work then I would try testing using a different PC.
