02-18-2010 05:06 AM - edited 03-15-2019 09:28 PM
I am looking to do an upgrade of our version of CUE on a 2821 NME. The current CUE (3.0.4) is currently working fine, however I want to update the version of CME running on my router. The problem is I cannot get into the service-module session. When I try it is saying connection refused by host... I have tried to clear the line via the service-module integ-service-engine 1/0 session clear and by clearing the tty line that shows in the service-module integ-service-engine 1/0 status (via clear line tty 66). I have tried shutting down the module and restarting it with no avail. I am at a loss as to what to do to get into the cli for the CUE. Any ideas?
Solved! Go to Solution.
02-23-2010 04:20 AM
02-18-2010 05:10 AM
Do you have a copy of the configuration? Can you web to the CUE?
cheers
Mark
02-18-2010 07:22 AM
The web gui is working fantastically.
interface Loopback0
ip address 172.16.5.2 255.255.255.252
02-18-2010 08:22 AM
Can't seem to see a problem, what command are you using to access the cli?
Mark
02-18-2010 01:09 PM
#service-module integrated-Service-Engine 1/0 session
Trying 172.16.5.2, 2066 ...
% Connection refused by remote host
02-19-2010 08:38 AM
very strange , can't see what the issue is.The fact that you can use the CUE and web to it must mean that routing is fine.i can only assume that it maybe a bug in the IOS.what version are you running.I have checked the unity express for bugs regarding this but there is nothing obvious
02-23-2010 04:11 AM
IOS version 12.4(11)XW9
CUE version 3.0.4
02-23-2010 04:20 AM
Under line 66
no exec
transport input all
02-10-2019 01:37 PM
Thanks a lot
02-10-2019 01:38 PM
thanks a lot
02-23-2010 07:06 AM
What authentication are you using for the module?
02-23-2010 07:15 AM
Note: Problem has been solved and checkmarked as such .
