cant make international conference call on Cisco phone by putting conference code
amralrazzaz
Level 5
Level 5
hi
i have Cisco phones at office , my problem is i received a conference call we conference code by email as invitation
i dial the international number (Holland for example) normally and then the answer machine requesting me to put the conference code , so the local answer machine (Egypt) said this number is wrong please check number .etc
why i cant put the conference code to join the call and  the local answer machine reply this number is number and the international call is already on hold waiting for conference code to join
Note: i dont have landline , im using Vodafone sim card on our ip central system because we dont have landline infra and boxes in our building
thanks
amr alrazzaz
71 Replies 71
thanks for clarification but need more explain
1- i cant upgrade only one phone for testing (using tftp alternative)
2- if i upgrade the cisco phone to new firmware on router using tftp , what about the old one which       already installed on router ? it will over write ? and which time should i upgrade ? during working hours ? so users doesnt effected with normal internet connection ?
3- also it will not erase any of my router configuration ? just need to make sure
4- about the latest firmware of cp 7821 with cmterm-78xx.12-1-1-12 i dont have the XMLDefault.cnf.xml included with the same model inside the file ?
5- last things need steps of how to upgrade on router 2911 ?
thanks alot for great helping
amr alrazzaz
can i ask u about the XMLDefault.cnf.XML file is it created after i extraxt and upload it on router
or this file i should have to be able to upload the firmware to router ?
another thing : i u tell me the steps to extract and upload the firmware 7821 12-1-1-12 on flash (router )
need steps to follow and hope it will not effect on the router configurations
thanks
amr alrazzaz
im have cme 10.5 , so can i upgrade the cisco phone 7821 firmware to sip78xx.12-1-1-12 ?
cme supporting the new firmware of cisco phone 7821 ?
Router#show telephony-service
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 192.168.2.207 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 58
max-dn 64
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 24
date-format dd-mm-yy
timezone 25 Egypt Standard/Daylight Time
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name romani password cisco
web admin customer name romani1 password cisco
edit DN through Web: enabled.
edit TIME through web: enabled.
background save interval 10 minutes
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 May 22 2018 14:27:27
transfer-system full-consult dss
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Router#
amr alrazzaz
dear during upgrading cisco phone it show me the following :
Router#archive tar /xtract tftp://192.168.2.254/cmterm-78xx.12-1-1-12.tar ?
WORD Dir to extract files into
Router#archive tar /xtract tftp://192.168.2.254/cmterm-78xx.12-1-1-12.tar fl
Router#archive tar /xtract tftp://192.168.2.254/cmterm-78xx.12-1-1-12.tar flash
Loading cmterm-78xx.12-1-1-12.tar from 192.168.2.254 (via GigabitEthernet0/0): !
cmterm-78xx.12-1-1-12/ (directory)
extracting cmterm-78xx.12-1-1-12/kern2.78xx.12-1-1-12.sbn (2507470 bytes)!!!!!!!!!
extracting cmterm-78xx.12-1-1-12/kern78xx.12-1-1-12.sbn (3091752 bytes)!!!!!!!!!!!!
extracting cmterm-78xx.12-1-1-12/rootfs2.78xx.12-1-1-12.sbn (39715156 bytes)O!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
extracting cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn (41419088 bytes)
%Error writing flash/cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn (Not enough space on device)
Router#sh run
Building configuration...
Current configuration : 13324 bytes
! Last configuration change at 13:38:24 UTC Sun Jun 3 2018 by amr
! NVRAM config last updated at 14:08:22 UTC Sun Jun 3 2018 by amr
what should i do ?
amr alrazzaz
dear which one should i have on router
File Information
Release Date
Size
7811, 7821, 7841 and 7861 SIP IP Phone load signed COP file - Compatible CUCM Versions: 9.1(2)+
cmterm-78xx.12-1-1-12.k3.cop.sgn
21-MAR-2018
66.74 MB
7811, 7821, 7841 and 7861 SIP IP Phone firmware files only - Compatible CUCM Versions: 9.1(2)+
cmterm-78xx.12-1-1-12.zip
21-MAR-2018
66.73 MB
amr alrazzaz
Hi there
cmterm-78xx.12-1-1-12.k3.cop.sgn is for CUCM. For CME you can use cmterm-78xx.12-1-1-12.zip. As its a zip file you have to extract it and manually upload to the router flash and point it in the configuration.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
dear i did it but the phones not taking the new firmware and here u are the confi:
Router#show run
Current configuration : 13776 bytes
! Last configuration change at 17:28:12 UTC Sun Jun 3 2018 by amr
! NVRAM config last updated at 16:47:43 UTC Sun Jun 3 2018 by amr
version 15.4
hostname Router
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$l9ha$dHLj/scp8Qm8C77UcUa/K0
enable password cisco1
no aaa new-model
clock timezone UTC 2 0
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.2.207
ip dhcp pool voice
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.207
option 150 ip 192.168.2.207
dns-server 8.8.8.8 8.8.4.4
ip dhcp global-options
dns-server 163.121.128.134 163.121.128.135
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
trunk group Mobile
trunk group pstn
cts logging verbose
crypto pki trustpoint TP-self-signed-2728187941
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2728187941
revocation-check none
rsakeypair TP-self-signed-2728187941
crypto pki certificate chain TP-self-signed-2728187941
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373238 31383739 3431301E 170D3135 30333231 31333235
31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37323831
38373934 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C184 ACFFFB46 C4C5B385 CBE1A6C9 0CD5DA07 385B1D99 C8AD86D5 9CFAA109
CACAA786 2AE1D32F CC3AC285 BBA7B419 04B2482A 0B7DD955 99130F92 48B2A075
E8B170CA 230036B1 73D4F8FF 26E2B556 6FD337BE 3A8B341B 0A80C612 6737B714
96CFA520 995A0E45 993F558D 1DFC222A 3F587ABE E3E1F038 3CA3152F F0222271
00330203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14AEA7B2 0A72790D BDCE8BF7 9C2D6CF2 C1C8A393 5B301D06
03551D0E 04160414 AEA7B20A 72790DBD CE8BF79C 2D6CF2C1 C8A3935B 300D0609
2A864886 F70D0101 05050003 81810072 94945FF4 84A78DF0 CF361867 79566C0F
D6FB48FD 3ACB218F 800D5CA1 54F4F4E2 5ED04E26 4A5DC612 097EE5D0 5A26618A
80DB770F 30768D27 C5F7679A D5E81483 C3993CC4 15CFF495 39F11F9D 7EE9054D
DC5CDEEE B3E35F53 09DB553A EACEE590 D128A220 52EE5C32 FCA5A626 BDAD34D5
6DABFE4F F30D63A5 5C92E27A 7E3EE0
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
sip
registrar server
voice register global
mode cme
source-address 192.168.2.207 port 5060
max-dn 64
max-pool 58
load 7821 sip78xx.12-1-1-12
timezone 25
date-format D/M/Y
tftp-path flash:
create profile sync 0165464226868529
network-locale GB
voice register dn 1
voice register dn 5
number 100
name Inas AlMahalawi
label Inas AlMahalawi
mwi
voice register dn 6
number 101
name Meeting Room A
label Meeting Room A
mwi
voice register dn 7
number 102
call-forward b2bua noan 5 timeout 20
name Walid Hifny
auto-answer
label Walid Hifny
mwi
mobility
voice register dn 8
translation-profile incoming AMR
translation-profile outgoing AMRALRAZZAZ
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
voice register dn 9
number 104
name Khaled Elgarhy
label Khaled Elgarhy
mwi
voice register dn 10
number 105
name Sales 2
label Sales 2
mwi
voice register dn 11
number 107
name Amr Ismail
label Amr Ismail
mwi
voice register dn 12
number 108
name Mohammed Abdella
label Mohammed Abdella
mwi
voice register dn 13
number 109
name Sales 1
label Sales 1
mwi
voice register dn 14
number 110
name Karim Habib
label Karim Habib
mwi
voice register dn 15
number 114
name Tamer Mazen
label Tamer Mazen
mwi
voice register dn 16
number 115
name Meeting Room B
label Meeting Room B
mwi
voice register dn 17
number 106
name Conference Room
label Conference Room
mwi
voice register dn 18
number 112
name Omar Mohamed
label Omar Mohamed
mwi
voice register dn 19
number 113
name Tarek Aldessouky
label Tarek Aldessouky
mwi
mobility
voice register pool 5
busy-trigger-per-button 1
id mac 5067.AE21.4E6E
type 7821
number 1 dn 5
cor incoming mobile-long default
presence call-list
dtmf-relay rtp-nte
username romani password cisco
codec g711ulaw
voice register pool 6
pin 4100
id mac 5067.AE21.4EA5
type 7821
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 7
id mac 5067.AE21.9A74
type 7821
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 8
id mac 5067.AE21.9A5A
type 7821
number 1 dn 8
no digit collect kpml
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 9
id mac 5067.AE21.99AC
type 7821
number 1 dn 9
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 10
id mac 5067.AE21.9A52
type 7821
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 11
id mac 5067.AE21.9A1D
type 7821
number 1 dn 11
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 12
id mac 5067.AE21.4F10
type 7821
number 1 dn 12
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 13
id mac 5067.AE21.4E15
type 7821
number 1 dn 13
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 14
id mac 5067.AE21.4DF7
type 7821
number 1 dn 14
presence call-list
dtmf-relay sip-kpml sip-notify
codec g711ulaw
voice register pool 15
id mac 5067.AE21.4EAD
type 7821
number 1 dn 15
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 16
id mac 5067.AE21.4E9D
type 7821
number 1 dn 16
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 17
id mac 5067.AE21.4DD6
type 7821
number 1 dn 17
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 18
id mac 5067.AE21.4F96
type 7821
number 1 dn 18
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 19
id mac 5067.AE21.4F9C
type 7821
number 1 dn 19
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
no vad
license udi pid CISCO2911/K9 sn FCZ190360AM
license accept end user agreement
hw-module pvdm 0/0
username cisco password 0 cish:
username romani secret 5 $1$5Klr$GneBF.AwmAgvMY4lW/Ylk1
username aa
username Acc
username amr privilege 15 secret 9 $9$eSfWH2ACcyEpgU$kBe69JmDRjwR01pDNDUjBF17G2JI8hOCafvoaptS8f6
redundancy
process-max-time 50
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.2.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.1.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat outside
ip rip advertise 100
ip rip receive version 2
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
router rip
network 192.168.1.0
network 192.168.2.0
ip default-gateway 192.168.2.207
ip forward-protocol nd
ip http server
ip http secure-server
ip http path flash:
ip flow-export source GigabitEthernet0/0
ip flow-export version 9
ip flow-export destination 192.168.2.195 9996
ip flow-top-talkers
top 60
sort-by packets
ip dns view default
dns forwarder 8.8.8.8
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 150 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
snmp-server community public RO
tftp-server flash:kern78xx.12-1-1-12.sbn
tftp-server flash:rootfs2.78xx.12-1-1-12.sbn
tftp-server flash:rootfs78xx.12-1-1-12.sbn
tftp-server flash:sboot2.78xx.12-1-1-12.sbn
tftp-server flash:sboot78xx.12-1-1-12.sbn
tftp-server flash:sip78xx.12-1-1-12.loads
tftp-server flash:cmterm-78xx.12-1-1-12/kern78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sip78xx.12-1-1-12.loads
access-list 1 permit 192.168.2.0
access-list 150 permit ip any any
control-plane
voice-port 0/0/0
trunk-group Mobile
connection plar opx 100
description Configured by 2911 4 FXO-0/0/0-Custom
caller-id enable
voice-port 0/0/1
trunk-group Mobile
description Configured by 2911 4 FXO-0/0/1-Custom
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
mgcp profile -long
dial-peer cor custom
name internal
name pstn
name long
name mobile
name international
dial-peer cor list internal
member internal
dial-peer cor list mobile-long
member internal
member pstn
member long
member mobile
dial-peer cor list manager
member internal
member pstn
member long
member mobile
member international
dial-peer voice 8 pots
trunkgroup long
trunkgroup Mobile
corlist outgoing mobile-long
destination-pattern 904......T
prefix 04
dial-peer voice 9 pots
trunkgroup long
trunkgroup Mobile
destination-pattern 905......T
prefix 05
dial-peer voice 22 pots
service stcapp
port 0/0/2
dial-peer voice 10 pots
trunkgroup long
trunkgroup Mobile
trunkgroup Inter
trunkgroup international
corlist outgoing manager
description **Cairo**
destination-pattern 900T
prefix 00
dial-peer voice 2 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **shortcut No**
destination-pattern 91[16789]...
forward-digits 5
dial-peer voice 3 pots
trunkgroup long
trunkgroup PSTN
description ** Services **
destination-pattern 91[1245].
forward-digits 3
prefix 013
dial-peer voice 7 pots
trunkgroup long
trunkgroup Mobile
description **Alex**
destination-pattern 903......T
prefix 03
dial-peer voice 15 pots
dial-peer voice 2000 voip
description ** Sedestination-pattern 9013.T
destination-pattern 402
b2bua
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
trunkgroup pstn
trunkgroup Mobile
description ** Inside Cairo **
destination-pattern 902.......T
no digit-strip
forward-digits 8
prefix 02
no register e164
dial-peer voice 4 pots
trunkgroup Mobile
description ** Mobile **
destination-pattern 901[012]........
forward-digits 11
dial-peer voice 6 pots
trunkgroup long
trunkgroup Mobile
description **Kaluobia**
prefix 013
dial-peer voice 11 pots
trunkgroup long
trunkgroup Mobile
prefix 00
dial-peer voice 12 pots
prefix 00
dial-peer voice 21 pots
service stcapp
port 0/0/1
dial-peer voice 13 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **Vodafone**
destination-pattern 92[47].
forward-digits 3
dial-peer voice 5 pots
trunkgroup long
trunkgroup Mobile
description **sharm alsheikh**
destination-pattern 9069......T
prefix 069
presence
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 64
time-zone 25
time-format 24
dn-webedit
time-webedit
create cnf-files version-stamp 7960 Jun 03 2018 17:11:36
ephone-dn 1 dual-line
number 111 no-reg primary
label 111
description Mr. Amr Ismaeil
name Mr. Amr Ismaeil
ephone 1
video
mac-address 1CE8.5DC8.D374
username "aa"
paging-dn 1
type 7945
button 1:1
pin 4100
ephone 2
ephone 5
line con 0
password cisco
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
here is the error :
Router(config-register-global)#create profile
%Error deleting flash:/its/jabber-config.xml (File not found)
also on sip cisco phone showing to me :   inactive load: sip78xx.12-1-1-12
amr alrazzaz
The error is for jabber-config.xml. Since you dont have IMP, thats fine.
Can you try reset the device to factory and boot up.
Step 1   Unplug the phone:
  • If using PoE, unplug the LAN cable.
  • If using the power cube, unplug the power cube.
Step 2   Wait 5 seconds.
Step 3   Press and hold # and plug the phone back in.
Step 4   When the light on the Mute button and handset light strip turns off and all other lights (Line button, Headset button, Speakerphone button, and Select button) stay green, press 123456789*0# in sequence.
When you press 1, the lights on the line buttons turn red. The light on the Select button flashes when a button is pressed.
After you press these buttons, the phone goes through the factory reset process.
If you press the buttons out of sequence, the phone powers on normally
Hope this Helps
Cheers
Rath!
sorry is this way for cp 7821 ? and if u have another way to fix and phone take the late firmware just please share
thanks alot
amr alrazzaz
it doesnot work with me any how i reset all setting already from the phone it self , now why the phone is not taking the new firmware (it said upgrade faild sip78xx.12-1-1-12.loads inactive load)
do i have any problem with my configurations below:
Router#show flash
-#- --length-- -----date/time------ path
1 104102656 Jan 14 2015 09:13:04 +02:00 c2900-universalk9-mz.SPA.154-3.M1.bin
2 3064 Jan 14 2015 09:25:14 +02:00 cpconfig-29xx.cfg
3 0 Mar 19 2015 16:43:14 +02:00 its
4 3899 Jun 4 2018 12:58:26 +02:00 its/SEP5067AE214F9C.cnf.xml
5 3894 Jun 4 2018 12:58:26 +02:00 its/SEP5067AE214F96.cnf.xml
6 3901 Jun 4 2018 12:58:26 +02:00 its/SEP5067AE214DD6.cnf.xml
7 3899 Jun 4 2018 12:58:24 +02:00 its/SEP5067AE214E9D.cnf.xml
8 3893 Jun 4 2018 12:58:24 +02:00 its/SEP5067AE214EAD.cnf.xml
9 3892 Jun 4 2018 12:58:24 +02:00 its/SEP5067AE214DF7.cnf.xml
10 3885 Jun 4 2018 12:58:24 +02:00 its/SEP5067AE214E15.cnf.xml
11 3902 Jun 4 2018 12:58:22 +02:00 its/SEP5067AE214F10.cnf.xml
12 3890 Jun 4 2018 12:58:22 +02:00 its/SEP5067AE219A1D.cnf.xml
13 3885 Jun 4 2018 12:58:22 +02:00 its/SEP5067AE219A52.cnf.xml
14 3898 Jun 4 2018 12:58:22 +02:00 its/SEP5067AE2199AC.cnf.xml
15 3891 Jun 4 2018 12:58:20 +02:00 its/SEP5067AE219A5A.cnf.xml
16 3893 Jun 4 2018 12:58:20 +02:00 its/SEP5067AE219A74.cnf.xml
17 3899 Jun 4 2018 12:58:20 +02:00 its/SEP5067AE214EA5.cnf.xml
18 3923 Jun 4 2018 12:58:20 +02:00 its/SEP5067AE214E6E.cnf.xml
19 824 Jun 4 2018 12:58:18 +02:00 its/featurePolicyDefault.xml
20 4748 Jun 4 2018 12:58:18 +02:00 its/softkeyDefault_kpml.xml
21 4782 Jun 4 2018 12:58:18 +02:00 its/softkeyDefault.xml
22 69 Jun 4 2018 12:58:16 +02:00 its/syncinfo.xml
23 1948 Jun 4 2018 12:58:18 +02:00 its/SIPDefault.cnf
266 2507470 Jun 3 2018 16:12:54 +02:00 cmterm-78xx.12-1-1-12/kern2.78xx.12-1-1-12.sbn
267 0 Jun 3 2018 15:57:16 +02:00 cmterm-78xx.12-1-1-12
268 3086432 Mar 21 2015 14:43:36 +02:00 kern78xx.10-1-1-9.sbn
269 36438352 Mar 21 2015 14:45:14 +02:00 rootfs78xx.10-1-1-9.sbn
270 347180 Mar 21 2015 14:45:26 +02:00 sboot78xx.10-1-1-9.sbn
271 985 Mar 21 2015 14:45:42 +02:00 sip78xx.10-1-1-9.loads
272 2413855 Mar 21 2015 17:44:56 +02:00 po-locale-ar_EG-10.2.2.1000-1.cop.sgn
273 92250 Mar 9 2017 21:00:22 +02:00 001_Conf
274 12248 Mar 10 2017 19:03:10 +02:00 0710_3_10_2017.log
275 0 Jun 3 2018 14:23:22 +02:00 flash
276 0 Jun 3 2018 14:23:22 +02:00 flash/cmterm-78xx.12-1-1-12
277 3091752 Jun 3 2018 15:57:48 +02:00 cmterm-78xx.12-1-1-12/kern78xx.12-1-1-12.sbn
278 39715156 Jun 3 2018 16:01:22 +02:00 cmterm-78xx.12-1-1-12/rootfs2.78xx.12-1-1-12.sbn
279 41419088 Jun 3 2018 16:05:02 +02:00 cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn
280 596840 Jun 3 2018 16:05:06 +02:00 cmterm-78xx.12-1-1-12/sboot2.78xx.12-1-1-12.sbn
281 370284 Jun 3 2018 16:05:10 +02:00 cmterm-78xx.12-1-1-12/sboot78xx.12-1-1-12.sbn
282 1308 Jun 3 2018 16:05:10 +02:00 cmterm-78xx.12-1-1-12/sip78xx.12-1-1-12.loads
Router#show run
ip dhcp pool voice
import all
ip cef
no ipv6 cef
quit
voice-card 0
voice service voip
h323
sip
registrar server
mode cme
max-dn 64
max-pool 58
timezone 25
date-format D/M/Y
tftp-path flash:
create profile sync 0165464226868527
network-locale GB
voice register dn 1
voice register dn 5
number 100
mwi
voice register dn 6
number 101
name Meeting Room A
mwi
type 7821
number 1 dn 5
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
pin 4100
type 7821
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
tftp-server flash:cmterm-78xx.12-1-1-12/kern2.78xx.12-1-1-12.sbn
tftp-server flash:kern2.78xx.12-1-1-12.sbn
Router(config)#voice register global
Router(config-register-global)#upgr
Router(config-register-global)#upgrade
%Error deleting flash:/its/OS79XX.TXT (File not found)
amr alrazzaz
Hi there
Could you try the commands with tftp alias
tftp-server flash:cmterm-78xx.12-1-1-12/kern78xx.12-1-1-12.sbn alias kern78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs2.78xx.12-1-1-12.sbn alias rootfs2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn alias rootfs78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot2.78xx.12-1-1-12.sbn alias sboot2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot78xx.12-1-1-12.sbn alias sboot78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sip78xx.12-1-1-12.loads alias sip78xx.12-1-1-12.loads
tftp-server flash:cmterm-78xx.12-1-1-12/kern2.78xx.12-1-1-12.sbn alias kern2.78xx.12-1-1-12.sbn
Create profile and reboot the phone
Hope this Helps
Cheers
Rath!
dear thanks for helping me always
now whats the new features on this firmware ?also can i change the codec from g711 to g722 for example so the voice quality and sound level will be more better ?
now can i make conference call after upgrade i mean my i can put the conference code after calling the international number or what ever number ???
amr alrazzaz
another question :
i have exmaple of 2 of  phone config with two different codec
type 7821
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
type 7821
number 1 dn 11
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
i need to know which better code should i use
Router(config)#voice register pool 8
Router(config-register-pool)#codec ?
g711alaw Use G.711 Alaw
g711ulaw Use G.711 ulaw
g722-64K Use G722-64K 64000 bps
g729r8 Use G.729
ilbc Use iLBC 13330 or 15200 bps
note : i tried to use g722-64K and make a call but giving me busy tone so i cant make a call (ip cisco phone 7821)
amr alrazzaz
amr alrazzaz
okay now after upgrade i need to cant make international conference call on Cisco phone by putting conference code after making the call it asking me to put the conference code to join the meeting via phone but i think the phone doesnt recognize that digits are normal code not a phone number
thats why when i put the code it says from vendor this number is wrong number please try another
so how can i put numbers during the call is active and the phone recognize it as a code
amr alrazzaz
