cant make international conference call on Cisco phone by putting conference code
amralrazzaz
Level 5
Level 5
hi
i have Cisco phones at office , my problem is i received a conference call we conference code by email as invitation
i dial the international number (Holland for example) normally and then the answer machine requesting me to put the conference code , so the local answer machine (Egypt) said this number is wrong please check number .etc
why i cant put the conference code to join the call and  the local answer machine reply this number is number and the international call is already on hold waiting for conference code to join
Note: i dont have landline , im using Vodafone sim card on our ip central system because we dont have landline infra and boxes in our building
thanks
amr alrazzaz
71 Replies 71
kay now after upgrade i need to cant make international conference call on Cisco phone by putting conference code after making the call it asking me to put the conference code to join the meeting via phone but i think the phone doesnt recognize that digits are normal code not a phone number
thats why when i put the code it says from vendor this number is wrong number please try another
so how can i put numbers during the call is active and the phone recognize it as a code
amr alrazzaz
now after upgrade i need to cant make international conference call on Cisco phone by putting conference code after making the call it asking me to put the conference code to join the meeting via phone but i think the phone doesnt recognize that digits are normal code not a phone number thats why when i put the code it says from vendor this number is wrong number please try another so how can i put numbers during the call is active and the phone recognize it as a code
amr alrazzaz
Hi there
Can you add this command to your outgoing dial peers and test it
voice-class sip dtmf-relay force rtp-nte
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Hey, my suggestion would be to just stop making any more changes, upgrades etc and troubleshoot this issue. I see this has been going on way too long and you have been doing all sorts of changes, upgrades without really understanding if it is really an issue with the IOS or not. It could be your ITSP issue.
Attach the latest "show run" from the CME. I will suggest what logs to enable once I go through that.
thanks for helping me always and i hope u understood and got my point about during international call or any call i cant put digits number as answer machine telling me to put to entering the conference call (the phone should recognize that this is not a number it should be digits for conference to follow the instruction and access the conf call .... any way here u r the last show run :
Router#show run
Building configuration...
Current configuration : 13810 bytes
! Last configuration change at 15:45:59 UTC Tue Jun 12 2018 by amr
! NVRAM config last updated at 15:45:54 UTC Tue Jun 12 2018 by amr
version 15.4
hostname Router
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$l9ha$dHLj/scp8Qm8C77UcUa/K0
enable password cisco1
no aaa new-model
clock timezone UTC 2 0
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.2.207
ip dhcp pool voice
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.207
option 150 ip 192.168.2.207
dns-server 8.8.8.8 8.8.4.4
ip dhcp global-options
dns-server 163.121.128.134 163.121.128.135
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
trunk group Mobile
trunk group pstn
cts logging verbose
crypto pki trustpoint TP-self-signed-2728187941
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2728187941
revocation-check none
rsakeypair TP-self-signed-2728187941
crypto pki certificate chain TP-self-signed-2728187941
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373238 31383739 3431301E 170D3135 30333231 31333235
31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37323831
38373934 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C184 ACFFFB46 C4C5B385 CBE1A6C9 0CD5DA07 385B1D99 C8AD86D5 9CFAA109
CACAA786 2AE1D32F CC3AC285 BBA7B419 04B2482A 0B7DD955 99130F92 48B2A075
E8B170CA 230036B1 73D4F8FF 26E2B556 6FD337BE 3A8B341B 0A80C612 6737B714
96CFA520 995A0E45 993F558D 1DFC222A 3F587ABE E3E1F038 3CA3152F F0222271
00330203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14AEA7B2 0A72790D BDCE8BF7 9C2D6CF2 C1C8A393 5B301D06
03551D0E 04160414 AEA7B20A 72790DBD CE8BF79C 2D6CF2C1 C8A3935B 300D0609
2A864886 F70D0101 05050003 81810072 94945FF4 84A78DF0 CF361867 79566C0F
D6FB48FD 3ACB218F 800D5CA1 54F4F4E2 5ED04E26 4A5DC612 097EE5D0 5A26618A
80DB770F 30768D27 C5F7679A D5E81483 C3993CC4 15CFF495 39F11F9D 7EE9054D
DC5CDEEE B3E35F53 09DB553A EACEE590 D128A220 52EE5C32 FCA5A626 BDAD34D5
6DABFE4F F30D63A5 5C92E27A 7E3EE0
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
sip
registrar server
voice register global
mode cme
source-address 192.168.2.207 port 5060
max-dn 64
max-pool 58
load 7821 sip78xx.12-1-1-12.loads
timezone 25
date-format D/M/Y
tftp-path flash:
create profile sync 0165464226868525
network-locale GB
voice register dn 1
voice register dn 5
number 100
name Inas AlMahalawi
label Inas AlMahalawi
mwi
voice register dn 6
number 101
name Meeting Room A
label Meeting Room A
mwi
voice register dn 7
number 102
call-forward b2bua noan 5 timeout 20
name Walid Hifny
auto-answer
label Walid Hifny
mwi
mobility
voice register dn 8
translation-profile incoming AMR
translation-profile outgoing AMRALRAZZAZ
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
voice register dn 9
number 104
name Khaled El Garhy
label Khaled El Garhy
mwi
voice register dn 10
number 105
name Sales 2
label Sales 2
mwi
voice register dn 11
number 107
name Amr Ismail
label Amr Ismail
mwi
voice register dn 12
number 108
name Mohammed Abdella
label Mohammed Abdella
mwi
voice register dn 13
number 109
name Sales 1
label Sales 1
mwi
voice register dn 14
number 110
name Karim Habib
label Karim Habib
mwi
voice register dn 15
number 114
name Tamer Mazen
label Tamer Mazen
mwi
voice register dn 16
number 115
name Meeting Room B
label Meeting Room B
mwi
voice register dn 17
number 106
name Conference Room
label Conference Room
mwi
voice register dn 18
number 112
name Omar Mohamed
label Omar Mohamed
mwi
voice register dn 19
number 113
name Tarek Aldessouky
label Tarek Aldessouky
mwi
mobility
voice register pool 5
busy-trigger-per-button 1
id mac 5067.AE21.4E6E
type 7821
number 1 dn 5
cor incoming mobile-long default
presence call-list
dtmf-relay rtp-nte
username romani password cisco
codec g711ulaw
voice register pool 6
pin 4100
id mac 5067.AE21.4EA5
type 7821
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 7
id mac 5067.AE21.9A74
type 7821
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 8
id mac 5067.AE21.9A5A
type 7821
number 1 dn 8
no digit collect kpml
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 9
id mac 5067.AE21.99AC
type 7821
number 1 dn 9
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 10
id mac 5067.AE21.9A52
type 7821
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 11
id mac 5067.AE21.9A1D
type 7821
number 1 dn 11
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 12
id mac 5067.AE21.4F10
type 7821
number 1 dn 12
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 13
id mac 5067.AE21.4E15
type 7821
number 1 dn 13
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 14
id mac 5067.AE21.4DF7
type 7821
number 1 dn 14
presence call-list
dtmf-relay sip-kpml sip-notify
codec g711ulaw
voice register pool 15
id mac 5067.AE21.4EAD
type 7821
number 1 dn 15
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 16
id mac 5067.AE21.4E9D
type 7821
number 1 dn 16
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 17
id mac 5067.AE21.4DD6
type 7821
number 1 dn 17
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 18
id mac 5067.AE21.4F96
type 7821
number 1 dn 18
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 19
id mac 5067.AE21.4F9C
type 7821
number 1 dn 19
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
no vad
license udi pid CISCO2911/K9 sn FCZ190360AM
license accept end user agreement
hw-module pvdm 0/0
username cisco password 0 cish:
username .........secret 5 $1$5Klr$GneBF.AwmAgvMY4lW/Ylk1
username aa
username Acc
username ......privilege 15 secret 9 $9$eSfWH2ACcyEpgU$kBe69JmDRjwR01pDNDUjBF17G2JI8hOCafvoaptS8f6
redundancy
process-max-time 50
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.2.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.1.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat outside
ip rip advertise 100
ip rip receive version 2
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
router rip
network 192.168.1.0
network 192.168.2.0
ip default-gateway 192.168.2.207
ip forward-protocol nd
ip http server
ip http secure-server
ip http path flash:
ip flow-export source GigabitEthernet0/0
ip flow-export version 9
ip flow-export destination 192.168.2.195 9996
ip flow-top-talkers
top 60
sort-by packets
ip dns view default
dns forwarder 8.8.8.8
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 150 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
snmp-server community public RO
tftp-server flash:cmterm-78xx.12-1-1-12/kern78xx.12-1-1-12.sbn alias kern78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs2.78xx.12-1-1-12.sbn alias rootfs2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn alias rootfs78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot2.78xx.12-1-1-12.sbn alias sboot2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot78xx.12-1-1-12.sbn alias sboot78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sip78xx.12-1-1-12.loads alias sip78xx.12-1-1-12.loads
tftp-server flash:cmterm-78xx.12-1-1-12/kern2.78xx.12-1-1-12.sbn alias kern2.78xx.12-1-1-12.sbn
access-list 1 permit 192.168.2.0
access-list 150 permit ip any any
control-plane
voice-port 0/0/0
trunk-group Mobile
connection plar opx 100
description Configured by 2911 4 FXO-0/0/0-Custom
caller-id enable
voice-port 0/0/1
trunk-group Mobile
description Configured by 2911 4 FXO-0/0/1-Custom
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
mgcp profile -long
dial-peer cor custom
name internal
name pstn
name long
name mobile
name international
dial-peer cor list internal
member internal
dial-peer cor list mobile-long
member internal
member pstn
member long
member mobile
dial-peer cor list manager
member internal
member pstn
member long
member mobile
member international
dial-peer voice 8 pots
trunkgroup long
trunkgroup Mobile
corlist outgoing mobile-long
destination-pattern 904......T
prefix 04
dial-peer voice 9 pots
trunkgroup long
trunkgroup Mobile
destination-pattern 905......T
prefix 05
dial-peer voice 22 pots
service stcapp
port 0/0/2
dial-peer voice 10 pots
trunkgroup long
trunkgroup Mobile
trunkgroup Inter
trunkgroup international
corlist outgoing manager
description **Cairo**
destination-pattern 900T
prefix 00
dial-peer voice 2 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **shortcut No**
destination-pattern 91[16789]...
forward-digits 5
dial-peer voice 3 pots
trunkgroup long
trunkgroup PSTN
description ** Services **
destination-pattern 91[1245].
forward-digits 3
prefix 013
dial-peer voice 7 pots
trunkgroup long
trunkgroup Mobile
description **Alex**
destination-pattern 903......T
prefix 03
dial-peer voice 15 pots
dial-peer voice 2000 voip
description ** Sedestination-pattern 9013.T
destination-pattern 402
b2bua
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
trunkgroup pstn
trunkgroup Mobile
description ** Inside Cairo **
destination-pattern 902.......T
no digit-strip
forward-digits 8
prefix 02
no register e164
dial-peer voice 4 pots
trunkgroup Mobile
description ** Mobile **
destination-pattern 901[012]........
forward-digits 11
dial-peer voice 6 pots
trunkgroup long
trunkgroup Mobile
description **Kaluobia**
prefix 013
dial-peer voice 11 pots
trunkgroup long
trunkgroup Mobile
prefix 00
dial-peer voice 12 pots
prefix 00
dial-peer voice 21 pots
service stcapp
port 0/0/1
dial-peer voice 13 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **Vodafone**
destination-pattern 92[47].
forward-digits 3
dial-peer voice 5 pots
trunkgroup long
trunkgroup Mobile
description **sharm alsheikh**
destination-pattern 9069......T
prefix 069
presence
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 64
ip source-address 192.168.2.207 port 2000
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 25
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name .......password .....
web admin customer name ......password ......
dn-webedit
time-webedit
transfer-system full-consult dss
create cnf-files version-stamp 7960 Jun 03 2018 17:11:36
ephone-dn 1 dual-line
number 111 no-reg primary
label 111
description Mr. Amr Ismaeil
name Mr. Amr Ismaeil
ephone 1
video
mac-address 1CE8.5DC8.D374
username "aa"
paging-dn 1
type 7945
button 1:1
pin 4100
ephone 2
ephone 5
line con 0
password ........
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
amr alrazzaz
Thanks for sharing the config. Enable the following and then test -
debug voice ccapi inout
debug ccsip message
debug ccsip error
debug voip vtsp all
debug vpm signal
debug voip rtp session name
debug voip rtp session dtmf
Share the logs along with the calling/called numbers and the DTMF digits pressed.
please check attached file
amr alrazzaz
dear sir please check the out call test during calling attached
amr alrazzaz
I see the digits correctly coming from the phone which is good -
Jun 21 09:12:29.356: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x313F timestamp 0x6D0BF6C5
Jun 21 09:12:29.356: <<<Rcv> Pt:101 Evt:4 Pkt:09 00 00
Jun 21 09:12:29.376: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3141 timestamp 0x6D0BF6C5
Jun 21 09:12:29.376: <<<Rcv> Pt:101 Evt:4 Pkt:09 00 A0
Jun 21 09:12:29.396: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3142 timestamp 0x6D0BF6C5
Jun 21 09:12:29.396: <<<Rcv> Pt:101 Evt:4 Pkt:09 01 40
Jun 21 09:12:29.416: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3144 timestamp 0x6D0BF6C5
Jun 21 09:12:29.416: <<<Rcv> Pt:101 Evt:4 Pkt:89 01 E0
Jun 21 09:12:29.416: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3145 timestamp 0x6D0BF6C5
Jun 21 09:12:29.416: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3146 timestamp 0x6D0BF6C5
Jun 21 09:12:29.856: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x314B timestamp 0x6D0C0665
Jun 21 09:12:29.856: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 00
Jun 21 09:12:29.876: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x314D timestamp 0x6D0C0665
Jun 21 09:12:29.876: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 A0
Jun 21 09:12:29.896: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x314E timestamp 0x6D0C0665
Jun 21 09:12:29.896: <<<Rcv> Pt:101 Evt:0 Pkt:09 01 40
Jun 21 09:12:29.916: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3150 timestamp 0x6D0C0665
Jun 21 09:12:29.916: <<<Rcv> Pt:101 Evt:0 Pkt:89 01 E0
Jun 21 09:12:29.916: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3151 timestamp 0x6D0C0665
Jun 21 09:12:29.916: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3152 timestamp 0x6D0C0665
Jun 21 09:12:31.264: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3159 timestamp 0x6D0C3275
Jun 21 09:12:31.264: <<<Rcv> Pt:101 Evt:7 Pkt:09 00 00
Jun 21 09:12:31.284: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x315B timestamp 0x6D0C3275
Jun 21 09:12:31.284: <<<Rcv> Pt:101 Evt:7 Pkt:09 00 A0
Jun 21 09:12:31.304: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x315C timestamp 0x6D0C3275
Jun 21 09:12:31.304: <<<Rcv> Pt:101 Evt:7 Pkt:09 01 40
Jun 21 09:12:31.328: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x315D timestamp 0x6D0C3275
Jun 21 09:12:31.328: <<<Rcv> Pt:101 Evt:7 Pkt:89 01 E0
Jun 21 09:12:31.328: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x315E timestamp 0x6D0C3275
Jun 21 09:12:31.328: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x315F timestamp 0x6D0C3275
Jun 21 09:12:31.496: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3165 timestamp 0x6D0C39A5
Jun 21 09:12:31.496: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 00
Jun 21 09:12:31.516: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3166 timestamp 0x6D0C39A5
Jun 21 09:12:31.516: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 A0
Jun 21 09:12:31.536: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3167 timestamp 0x6D0C39A5
Jun 21 09:12:31.536: <<<Rcv> Pt:101 Evt:0 Pkt:09 01 40
Jun 21 09:12:31.556: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3169 timestamp 0x6D0C39A5
Jun 21 09:12:31.556: <<<Rcv> Pt:101 Evt:0 Pkt:89 01 E0
Jun 21 09:12:31.556: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x316A timestamp 0x6D0C39A5
Jun 21 09:12:31.556: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x316B timestamp 0x6D0C39A5
Jun 21 09:12:33.776: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3183 timestamp 0x6D0C80E5
Jun 21 09:12:33.776: <<<Rcv> Pt:101 Evt:5 Pkt:09 00 00
Jun 21 09:12:33.796: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3184 timestamp 0x6D0C80E5
Jun 21 09:12:33.796: <<<Rcv> Pt:101 Evt:5 Pkt:09 00 A0
Jun 21 09:12:33.816: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3185 timestamp 0x6D0C80E5
Jun 21 09:12:33.816: <<<Rcv> Pt:101 Evt:5 Pkt:09 01 40
Jun 21 09:12:33.836: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3186 timestamp 0x6D0C80E5
Jun 21 09:12:33.836: <<<Rcv> Pt:101 Evt:5 Pkt:89 01 E0
Jun 21 09:12:33.836: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3187 timestamp 0x6D0C80E5
Jun 21 09:12:33.836: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3188 timestamp 0x6D0C80E5
Jun 21 09:12:33.996: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x318D timestamp 0x6D0C87C5
Jun 21 09:12:33.996: <<<Rcv> Pt:101 Evt:6 Pkt:09 00 00
Jun 21 09:12:34.016: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x318F timestamp 0x6D0C87C5
Jun 21 09:12:34.016: <<<Rcv> Pt:101 Evt:6 Pkt:09 00 A0
Jun 21 09:12:34.036: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3191 timestamp 0x6D0C87C5
Jun 21 09:12:34.036: <<<Rcv> Pt:101 Evt:6 Pkt:09 01 40
Jun 21 09:12:34.056: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3192 timestamp 0x6D0C87C5
Jun 21 09:12:34.056: <<<Rcv> Pt:101 Evt:6 Pkt:89 01 E0
Jun 21 09:12:34.056: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3193 timestamp 0x6D0C87C5
Jun 21 09:12:34.056: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3194 timestamp 0x6D0C87C5
Jun 21 09:12:35.596: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x319C timestamp 0x6D0CB9C5
Jun 21 09:12:35.596: <<<Rcv> Pt:101 Evt:4 Pkt:09 00 00
Jun 21 09:12:35.616: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x319E timestamp 0x6D0CB9C5
Jun 21 09:12:35.616: <<<Rcv> Pt:101 Evt:4 Pkt:09 00 A0
Jun 21 09:12:35.636: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31A0 timestamp 0x6D0CB9C5
Jun 21 09:12:35.636: <<<Rcv> Pt:101 Evt:4 Pkt:09 01 40
Jun 21 09:12:35.656: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31A1 timestamp 0x6D0CB9C5
Jun 21 09:12:35.656: <<<Rcv> Pt:101 Evt:4 Pkt:89 01 E0
Jun 21 09:12:35.656: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31A2 timestamp 0x6D0CB9C5
Jun 21 09:12:35.656: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31A3 timestamp 0x6D0CB9C5
Jun 21 09:12:38.096: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31AB timestamp 0x6D0D07E5
Jun 21 09:12:38.096: <<<Rcv> Pt:101 Evt:8 Pkt:09 00 00
Jun 21 09:12:38.116: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31AC timestamp 0x6D0D07E5
Jun 21 09:12:38.116: <<<Rcv> Pt:101 Evt:8 Pkt:09 00 A0
Jun 21 09:12:38.136: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31AE timestamp 0x6D0D07E5
Jun 21 09:12:38.136: <<<Rcv> Pt:101 Evt:8 Pkt:09 01 40
Jun 21 09:12:38.156: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31B0 timestamp 0x6D0D07E5
Jun 21 09:12:38.156: <<<Rcv> Pt:101 Evt:8 Pkt:89 01 E0
Jun 21 09:12:38.156: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31B1 timestamp 0x6D0D07E5
Jun 21 09:12:38.156: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31B2 timestamp 0x6D0D07E5
Jun 21 09:12:40.056: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31BE timestamp 0x6D0D4525
Jun 21 09:12:40.056: <<<Rcv> Pt:101 Evt:3 Pkt:09 00 00
Jun 21 09:12:40.076: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31BF timestamp 0x6D0D4525
Jun 21 09:12:40.076: <<<Rcv> Pt:101 Evt:3 Pkt:09 00 A0
Jun 21 09:12:40.096: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31C0 timestamp 0x6D0D4525
Jun 21 09:12:40.096: <<<Rcv> Pt:101 Evt:3 Pkt:09 01 40
Jun 21 09:12:40.116: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31C2 timestamp 0x6D0D4525
Jun 21 09:12:40.116: <<<Rcv> Pt:101 Evt:3 Pkt:09 01 E0
Jun 21 09:12:40.136: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31C3 timestamp 0x6D0D4525
Jun 21 09:12:40.136: <<<Rcv> Pt:101 Evt:3 Pkt:89 02 80
Jun 21 09:12:40.136: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31C4 timestamp 0x6D0D4525
Jun 21 09:12:40.136: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31C5 timestamp 0x6D0D4525
Jun 21 09:12:40.344: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31CC timestamp 0x6D0D4E35
Jun 21 09:12:40.344: <<<Rcv> Pt:101 Evt:2 Pkt:09 00 00
Jun 21 09:12:40.364: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31CD timestamp 0x6D0D4E35
Jun 21 09:12:40.364: <<<Rcv> Pt:101 Evt:2 Pkt:09 00 A0
Jun 21 09:12:40.384: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31CF timestamp 0x6D0D4E35
Jun 21 09:12:40.384: <<<Rcv> Pt:101 Evt:2 Pkt:09 01 40
Jun 21 09:12:40.404: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31D0 timestamp 0x6D0D4E35
Jun 21 09:12:40.404: <<<Rcv> Pt:101 Evt:2 Pkt:89 01 E0
Jun 21 09:12:40.404: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31D1 timestamp 0x6D0D4E35
Jun 21 09:12:40.404: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31D2 timestamp 0x6D0D4E35
Jun 21 09:12:40.676: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31D7 timestamp 0x6D0D5885
Jun 21 09:12:40.676: <<<Rcv> Pt:101 Evt:11 Pkt:09 00 00
Jun 21 09:12:40.696: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31D8 timestamp 0x6D0D5885
Jun 21 09:12:40.696: <<<Rcv> Pt:101 Evt:11 Pkt:09 00 A0
Jun 21 09:12:40.716: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31D9 timestamp 0x6D0D5885
Jun 21 09:12:40.716: <<<Rcv> Pt:101 Evt:11 Pkt:09 01 40
Jun 21 09:12:40.736: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31DB timestamp 0x6D0D5885
Jun 21 09:12:40.736: <<<Rcv> Pt:101 Evt:11 Pkt:09 01 E0
Jun 21 09:12:40.756: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31DC timestamp 0x6D0D5885
Jun 21 09:12:40.756: <<<Rcv> Pt:101 Evt:11 Pkt:89 02 80
Jun 21 09:12:40.756: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31DD timestamp 0x6D0D5885
Jun 21 09:12:40.756: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x31DE timestamp 0x6D0D5885
Jun 21 09:13:16.404: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32BA timestamp 0x6D11B515
Jun 21 09:13:16.404: <<<Rcv> Pt:101 Evt:4 Pkt:09 00 00
Jun 21 09:13:16.424: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32BB timestamp 0x6D11B515
Jun 21 09:13:16.424: <<<Rcv> Pt:101 Evt:4 Pkt:09 00 A0
Jun 21 09:13:16.444: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32BC timestamp 0x6D11B515
Jun 21 09:13:16.444: <<<Rcv> Pt:101 Evt:4 Pkt:09 01 40
Jun 21 09:13:16.464: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32BE timestamp 0x6D11B515
Jun 21 09:13:16.464: <<<Rcv> Pt:101 Evt:4 Pkt:89 01 E0
Jun 21 09:13:16.464: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32BF timestamp 0x6D11B515
Jun 21 09:13:16.464: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32C0 timestamp 0x6D11B515
Jun 21 09:13:16.468: <<<Rcv> Pt:101 Evt:4 Pkt:89 01 E0
Jun 21 09:13:18.364: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32CE timestamp 0x6D11F255
Jun 21 09:13:18.364: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 00
Jun 21 09:13:18.384: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32CF timestamp 0x6D11F255
Jun 21 09:13:18.384: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 A0
Jun 21 09:13:18.404: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32D1 timestamp 0x6D11F255
Jun 21 09:13:18.404: <<<Rcv> Pt:101 Evt:0 Pkt:09 01 40
Jun 21 09:13:18.424: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32D2 timestamp 0x6D11F255
Jun 21 09:13:18.424: <<<Rcv> Pt:101 Evt:0 Pkt:09 01 E0
Jun 21 09:13:18.444: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32D3 timestamp 0x6D11F255
Jun 21 09:13:18.444: <<<Rcv> Pt:101 Evt:0 Pkt:89 02 80
Jun 21 09:13:18.444: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32D4 timestamp 0x6D11F255
Jun 21 09:13:18.444: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32D5 timestamp 0x6D11F255
Jun 21 09:13:18.704: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32DA timestamp 0x6D11FCF5
Jun 21 09:13:18.704: <<<Rcv> Pt:101 Evt:7 Pkt:09 00 00
Jun 21 09:13:18.724: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32DB timestamp 0x6D11FCF5
Jun 21 09:13:18.724: <<<Rcv> Pt:101 Evt:7 Pkt:09 00 A0
Jun 21 09:13:18.744: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32DC timestamp 0x6D11FCF5
Jun 21 09:13:18.744: <<<Rcv> Pt:101 Evt:7 Pkt:09 01 40
Jun 21 09:13:18.764: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32DD timestamp 0x6D11FCF5
Jun 21 09:13:18.764: <<<Rcv> Pt:101 Evt:7 Pkt:09 01 E0
Jun 21 09:13:18.784: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32DE timestamp 0x6D11FCF5
Jun 21 09:13:18.784: <<<Rcv> Pt:101 Evt:7 Pkt:09 02 80
Jun 21 09:13:18.808: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32DF timestamp 0x6D11FCF5
Jun 21 09:13:18.808: <<<Rcv> Pt:101 Evt:7 Pkt:89 03 20
Jun 21 09:13:18.808: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32E0 timestamp 0x6D11FCF5
Jun 21 09:13:18.808: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32E1 timestamp 0x6D11FCF5
Jun 21 09:13:19.284: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32E6 timestamp 0x6D120F15
Jun 21 09:13:19.284: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 00
Jun 21 09:13:19.304: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32E7 timestamp 0x6D120F15
Jun 21 09:13:19.304: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 A0
Jun 21 09:13:19.324: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32E8 timestamp 0x6D120F15
Jun 21 09:13:19.324: <<<Rcv> Pt:101 Evt:0 Pkt:09 01 40
Jun 21 09:13:19.344: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32E9 timestamp 0x6D120F15
Jun 21 09:13:19.344: <<<Rcv> Pt:101 Evt:0 Pkt:09 01 E0
Jun 21 09:13:19.364: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32EA timestamp 0x6D120F15
Jun 21 09:13:19.364: <<<Rcv> Pt:101 Evt:0 Pkt:89 02 80
Jun 21 09:13:19.364: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32EB timestamp 0x6D120F15
Jun 21 09:13:19.368: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32EC timestamp 0x6D120F15
Jun 21 09:13:19.368: <<<Rcv> Pt:101 Evt:0 Pkt:89 02 80
Jun 21 09:13:20.116: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32F7 timestamp 0x6D122905
Jun 21 09:13:20.116: <<<Rcv> Pt:101 Evt:5 Pkt:09 00 00
Jun 21 09:13:20.136: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32F8 timestamp 0x6D122905
Jun 21 09:13:20.136: <<<Rcv> Pt:101 Evt:5 Pkt:09 00 A0
Jun 21 09:13:20.156: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32F9 timestamp 0x6D122905
Jun 21 09:13:20.156: <<<Rcv> Pt:101 Evt:5 Pkt:09 01 40
Jun 21 09:13:20.176: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32FA timestamp 0x6D122905
Jun 21 09:13:20.176: <<<Rcv> Pt:101 Evt:5 Pkt:09 01 E0
Jun 21 09:13:20.196: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32FB timestamp 0x6D122905
Jun 21 09:13:20.196: <<<Rcv> Pt:101 Evt:5 Pkt:89 02 80
Jun 21 09:13:20.196: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32FC timestamp 0x6D122905
Jun 21 09:13:20.196: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x32FD timestamp 0x6D122905
Jun 21 09:13:21.444: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3305 timestamp 0x6D125295
Jun 21 09:13:21.444: <<<Rcv> Pt:101 Evt:6 Pkt:09 00 00
Jun 21 09:13:21.464: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3307 timestamp 0x6D125295
Jun 21 09:13:21.464: <<<Rcv> Pt:101 Evt:6 Pkt:09 00 A0
Jun 21 09:13:21.484: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3308 timestamp 0x6D125295
Jun 21 09:13:21.484: <<<Rcv> Pt:101 Evt:6 Pkt:09 01 40
Jun 21 09:13:21.504: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x330A timestamp 0x6D125295
Jun 21 09:13:21.504: <<<Rcv> Pt:101 Evt:6 Pkt:09 01 E0
Jun 21 09:13:21.524: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x330B timestamp 0x6D125295
Jun 21 09:13:21.524: <<<Rcv> Pt:101 Evt:6 Pkt:09 02 80
Jun 21 09:13:21.548: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x330C timestamp 0x6D125295
Jun 21 09:13:21.548: <<<Rcv> Pt:101 Evt:6 Pkt:89 03 20
Jun 21 09:13:21.548: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x330D timestamp 0x6D125295
Jun 21 09:13:21.548: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x330E timestamp 0x6D125295
Jun 21 09:13:21.916: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3314 timestamp 0x6D126145
Jun 21 09:13:21.916: <<<Rcv> Pt:101 Evt:4 Pkt:09 00 00
Jun 21 09:13:21.936: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3315 timestamp 0x6D126145
Jun 21 09:13:21.936: <<<Rcv> Pt:101 Evt:4 Pkt:09 00 A0
Jun 21 09:13:21.956: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3316 timestamp 0x6D126145
Jun 21 09:13:21.956: <<<Rcv> Pt:101 Evt:4 Pkt:09 01 40
Jun 21 09:13:21.976: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3317 timestamp 0x6D126145
Jun 21 09:13:21.976: <<<Rcv> Pt:101 Evt:4 Pkt:09 01 E0
Jun 21 09:13:21.996: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3318 timestamp 0x6D126145
Jun 21 09:13:21.996: <<<Rcv> Pt:101 Evt:4 Pkt:89 02 80
Jun 21 09:13:21.996: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3319 timestamp 0x6D126145
Jun 21 09:13:21.996: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x331A timestamp 0x6D126145
Jun 21 09:13:23.336: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x331E timestamp 0x6D128DA5
Jun 21 09:13:23.336: <<<Rcv> Pt:101 Evt:8 Pkt:09 00 00
Jun 21 09:13:23.356: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x331F timestamp 0x6D128DA5
Jun 21 09:13:23.356: <<<Rcv> Pt:101 Evt:8 Pkt:09 00 A0
Jun 21 09:13:23.376: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3320 timestamp 0x6D128DA5
Jun 21 09:13:23.376: <<<Rcv> Pt:101 Evt:8 Pkt:09 01 40
Jun 21 09:13:23.396: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3321 timestamp 0x6D128DA5
Jun 21 09:13:23.396: <<<Rcv> Pt:101 Evt:8 Pkt:09 01 E0
Jun 21 09:13:23.416: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3322 timestamp 0x6D128DA5
Jun 21 09:13:23.416: <<<Rcv> Pt:101 Evt:8 Pkt:09 02 80
Jun 21 09:13:23.436: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3324 timestamp 0x6D128DA5
Jun 21 09:13:23.436: <<<Rcv> Pt:101 Evt:8 Pkt:89 03 20
Jun 21 09:13:23.436: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3325 timestamp 0x6D128DA5
Jun 21 09:13:23.436: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3326 timestamp 0x6D128DA5
Jun 21 09:13:23.716: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3329 timestamp 0x6D129985
Jun 21 09:13:23.716: <<<Rcv> Pt:101 Evt:3 Pkt:09 00 00
Jun 21 09:13:23.736: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x332B timestamp 0x6D129985
Jun 21 09:13:23.736: <<<Rcv> Pt:101 Evt:3 Pkt:09 00 A0
Jun 21 09:13:23.756: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x332C timestamp 0x6D129985
Jun 21 09:13:23.756: <<<Rcv> Pt:101 Evt:3 Pkt:09 01 40
Jun 21 09:13:23.776: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x332E timestamp 0x6D129985
Jun 21 09:13:23.776: <<<Rcv> Pt:101 Evt:3 Pkt:09 01 E0
Jun 21 09:13:23.796: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x332F timestamp 0x6D129985
Jun 21 09:13:23.796: <<<Rcv> Pt:101 Evt:3 Pkt:09 02 80
Jun 21 09:13:23.816: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3330 timestamp 0x6D129985
Jun 21 09:13:23.816: <<<Rcv> Pt:101 Evt:3 Pkt:89 03 20
Jun 21 09:13:23.816: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3331 timestamp 0x6D129985
Jun 21 09:13:23.816: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3332 timestamp 0x6D129985
Jun 21 09:13:23.944: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3337 timestamp 0x6D12A0B5
Jun 21 09:13:23.944: <<<Rcv> Pt:101 Evt:2 Pkt:09 00 00
Jun 21 09:13:23.964: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3338 timestamp 0x6D12A0B5
Jun 21 09:13:23.964: <<<Rcv> Pt:101 Evt:2 Pkt:09 00 A0
Jun 21 09:13:23.984: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3339 timestamp 0x6D12A0B5
Jun 21 09:13:23.984: <<<Rcv> Pt:101 Evt:2 Pkt:09 01 40
Jun 21 09:13:24.004: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x333B timestamp 0x6D12A0B5
Jun 21 09:13:24.004: <<<Rcv> Pt:101 Evt:2 Pkt:89 01 E0
Jun 21 09:13:24.004: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x333C timestamp 0x6D12A0B5
Jun 21 09:13:24.004: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x333D timestamp 0x6D12A0B5
Jun 21 09:13:24.008: <<<Rcv> Pt:101 Evt:2 Pkt:89 01 E0
Jun 21 09:13:24.244: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3343 timestamp 0x6D12AA15
Jun 21 09:13:24.244: <<<Rcv> Pt:101 Evt:11 Pkt:09 00 00
Jun 21 09:13:24.264: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3344 timestamp 0x6D12AA15
Jun 21 09:13:24.264: <<<Rcv> Pt:101 Evt:11 Pkt:09 00 A0
Jun 21 09:13:24.284: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3345 timestamp 0x6D12AA15
Jun 21 09:13:24.284: <<<Rcv> Pt:101 Evt:11 Pkt:09 01 40
Jun 21 09:13:24.304: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3347 timestamp 0x6D12AA15
Jun 21 09:13:24.304: <<<Rcv> Pt:101 Evt:11 Pkt:09 01 E0
Jun 21 09:13:24.328: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3348 timestamp 0x6D12AA15
Jun 21 09:13:24.328: <<<Rcv> Pt:101 Evt:11 Pkt:89 02 80
Jun 21 09:13:24.328: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x3349 timestamp 0x6D12AA15
Jun 21 09:13:24.328: s=VoIP d=DSP payload 0x65 ssrc 0x4E7C5F2C sequence 0x334A timestamp 0x6D12AA15
However, I did not see these on the CCAPI/VTSP layer which is strange.
Can you add the following debugs to the previous ones and take another set please ?
debug voip hpi all
debug voip dspapi all
Don't take these as "terminal monitor". Capture them in a buffer.
sorry for that how to capture buffer on this commands without enable the term mon , becuase there is no output appear during call ?
i put the following :
Router#debug voip hpi all
voip hpi all debugging is ON
Router#debug voip dspapi all
voip dspapi all debugging is ON
but how to capture buffer ?
thanks
amr alrazzaz
check attached file maybe can help
thanks
amr alrazzaz
please check attached may can help
amr alrazzaz
amr alrazzaz
any update :)
thanks in advance
amr alrazzaz
HI SIR U FORGOT ME :)
amr alrazzaz
