06-15-2012 05:28 AM - edited 03-16-2019 11:41 AM
When we hit directories -> Missed Calls the button layout is Dial, EditDial, Exit, more. We have to hit more in order to get to details. How can we move the details button so it's on the first softkey screen?
We are running CUCM 7.0(2)
Thanks in advance
Solved! Go to Solution.
06-15-2012 06:06 AM
Hi Greyson,
This change is not available in CUCM (any version that I know of). I've tried the same thing
myself before and just re-visited this when you posted up this question. You will see that the problem
here is that the call state of "Directories" is not available/selectable as an option to modify;
The administrator can configure softkey sets for each call state for a nonstandard softkey template. When the administrator chooses Configure Softkey Layout from the Related Links drop-down list box on the Softkey Template Configuration window and clicks Go, the Softkey Layout Configuration window displays.
The Softkey Layout Configuration window allows you to specify the softkeys and their relative order for any phone models that support downloadable softkey templates. This window lists all softkeys, even though some phone models do not support all softkeys. To determine whether your phone model supports a softkey, see the Cisco Unified IP Phone Phone Guide for your phone model. If you choose a softkey that is not supported by the phone, the softkey does not display on the phone, even if you add it to the Selected Softkeys pane.
Note Cisco recommends that a softkey remain in the same position for each call state. This provides the user with consistency and ease of use; for example, the More softkey always appears in the fourth softkey position from the left for each call state.
The Softkey Layout Configuration pane contains the following fields:
• Select a call state to configure—This drop-down list box displays the different call states of a Cisco Unified IP Phone. You cannot add, update, or delete call states. The call state that gets chosen from the drop-down list box indicates the softkeys that are available for that call state. Table 42-7 lists the call states.
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
06-15-2012 06:06 AM
Hi Greyson,
Cheers!
Rob
06-15-2012 06:12 AM
Thanks for confirming. I was looking around for a day or so trying to figure this out. Glad I didn't miss something obvious.
06-15-2012 06:36 AM
Hi Greyson,
No you aren't losing it my friend You are most welcome!
Cheers!
Rob
