09-27-2012 08:40 AM - edited 03-16-2019 01:25 PM
A few of our overseas sites are supported by a Mitel 3300 MXE IPT system, but there is interest in using the Cisco 7937 conference phone at them. Has anyone attempted this? If so, what were the results? What was necessary to have the 7937 register with the Mitel server and operate properly? Any performance issues?
Thanks, all...Steve
Solved! Go to Solution.
09-27-2012 11:07 AM
Hi Steve,
The 7937 is really a re-branded Polycom, so maybe this model might
be a better fit
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
09-27-2012 08:51 AM
7937 is SCCP phone only which is Cisco proprietary, so I don't see a way to get it to work with any other PBX.
HTH,
Chris
09-27-2012 10:42 AM
You can connect the 7937 over VPN to your HQ Cisco UC.
09-27-2012 11:07 AM
Hi Steve,
be a better fit
Cheers!
Rob
09-27-2012 11:51 AM
Good answers, all. I'd forgotten about the SCCP issue. Rob, the Polycom suggestion seems like the best approach. Thanks much...Steve
09-27-2012 12:19 PM
Great. Remember to rate all useful posts!
Chris
