Cisco 7960 IP Phone not registering with CME: Uploaded firmware correctly.
Anupam Singh
CIsco 7960 IP Phone was upgraded firmware from sccp to sip.  It has taken firmware correctly but not registering with CME on the local router. I configured Voice register global, voice register dn, voice register pool.  All phones are taking extention numbers configured 5000, 5001, 5002. But not registering with CME so that I can make internal calls each other. when I reload CME router, phones are not reloading itself. All phones have taken IP from DHCP pool and even extensions but not registered.
Please suggest me configuration to register phones with CME. Do I need to register it to sip registrar server to make call on other extendions on the same LAN?
Status Message On IP 7960 Phone:
W310 12 error(s) Parsing
SIPDefault.cnf
W320 5 error Parsing
SIPP0002B9AFC0F7.cnf
W360 no DNS server Active
E600 REG send failure
REGISTER
E102 MISC Error: No Time
server
W350 invalid proxy_backup
W351 invalid proxy_emergency
CME# sh voice register pool all
 Pool Tag 1
Config:
  Mac address is 0003.6B54.BCD9
  Type is 7960
  Number list 1 : DN 1
  Proxy Ip address is 0.0.0.0
  DTMF Relay is disabled
  Call Waiting is enabled
  DnD is disabled
  Video is disabled
  Camera is disabled
  Busy trigger per button value is 0
  keep-conference is enabled
  registration expires timer max is 600 and min is 60
  username redoq password redoq123
  dialplan tag is 1
  Lpcor Type is none
  blf call list is enabled
  Transport type is udp
  service-control mechanism is not supported
  Registration method: per line
  Privacy feature is not configured.
  Privacy button is disabled
  Reason for unregistered state:
   No registration request since last reboot/unregister
Dialpeers created:
Statistics:
  Active registrations  : 0
  Total SIP phones registered: 0
  Total Registration Statistics
    Registration requests  : 0
    Registration success   : 0
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   :
    Last unregister request time :
    Register success time        :
    Unregister success time      :
 Pool Tag 2
Config:
  Mac address is 0030.94C4.5009
  Type is 7960
  Number list 1 : DN 2
  DnD is disabled
  Video is disabled
  Camera is disabled
  username redoq1 password redoq123
  dialplan tag is 1
  Lpcor Type is none
Dialpeers created:
Statistics:
 Pool Tag 3
Config:
  Mac address is 0002.B9AF.C0F7
  Type is 7960
  Number list 1 : DN 3
  DnD is disabled
  Video is disabled
 --More--           Camera is disabled
  username redoq2 password redoq123
  dialplan tag is 1
  Lpcor Type is none
Dialpeers created:
Statistics:
RedoqCME(config)#voice register global
RedoqCME(config-register-global)#reset
No contact info available for pool 1.
No contact info available for pool 2.
No contact info available for pool 3.
No contact info available for pool 4.
RedoqCME(config-register-global)#^Z
RedoqCME#sh run
Building configuration...
Current configuration : 9361 bytes
! Last configuration change at 17:04:55 UTC Sat Aug 9 2014 by redoq
! NVRAM config last updated at 14:46:12 UTC Sat Aug 9 2014
version 15.1
hostname RedoqCME
boot-start-marker
boot-end-marker
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.1.1 10.10.1.10
ip dhcp excluded-address 10.15.1.1 10.15.1.10
ip dhcp pool DATA
 network 10.10.1.0 255.255.255.0
 default-router 10.10.1.1
ip dhcp pool VOICE
 network 10.15.1.0 255.255.255.0
 default-router 10.15.1.1
 option 150 ip 10.15.1.1
isdn switch-type basic-net3
trunk group ext
voice-card 0
 codec complexity high
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  h225 timeout ntf 500
  call preserve
  h245 caps mode restricted
 modem passthrough nse codec g711ulaw
 sip
  registrar server expires max 600 min 60
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
 mode cme
 source-address 10.15.1.1 port 5060
 max-dn 20
 max-pool 10
 load 7960-7940 P0S3-07-5-00
 call-forward system redirecting-expanded
 tftp-path flash:
 create profile sync 000164329254815A
 network-locale GB
 network-locale 1 GB
 network-locale 2 GB
voice register dn  1
 number 5000
 name SIP 1
 allow watch
voice register dn  2
 number 5001
 allow watch
 name SIP 2
voice register dn  3
 number 5002
 allow watch
 name SIP 3
voice register dn  4
 number 5003
 allow watch
 name SIP 4
voice register dialplan 1
 type 7940-7960-others
 pattern 1 5...
 pattern 2 5000
 pattern 3 5001
 pattern 4 5002
 pattern 5 5003
voice register dialplan 2
 pattern 2 01782......
voice register pool  1
 id mac 0003.6B54.BCD9
 type 7960
 number 1 dn 1
 dialplan 1
 presence call-list
 codec g711ulaw
voice register pool  2
 id mac 0030.94C4.5009
 type 7960
 number 1 dn 2
 dialplan 1
voice register pool  3
 id mac 0002.B9AF.C0F7
 type 7960
 number 1 dn 3
 dialplan 1
voice register pool  4
 id mac 0003.6B75.A91C
 type 7960
 number 1 dn 4
 dialplan 1
voice hunt-group 1 sequential
 final 5003
 list 5000,5001,5002
 timeout 20
 pilot 5900
license udi pid CISCO2911/K9 sn xxxxxxxxxxxxxxx
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 1.1.1.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.1
 encapsulation dot1Q 1
 ip address 10.1.1.1 255.255.255.0
 ip nat inside
 interface GigabitEthernet0/1.10
 encapsulation dot1Q 10 native
 ip address 10.10.1.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.15
 encapsulation dot1Q 15
 ip address 10.15.1.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
router eigrp 100
 network 10.0.0.0
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 36000 requests 10000
ip http path flash:gui
tftp-server flash:P0S3-07-5-00.bin
tftp-server flash:P0S3-07-5-00.loads
tftp-server flash:P0S3-07-5-00.sb2
tftp-server flash:P003-07-5-00.sbn
tftp-server flash:OS79XX.TXT
control-plane
voice-port 0/0/0
 input gain 4
 compand-type a-law
 cptone GB
 timeouts call-disconnect 5
 timeouts wait-release 5
 connection plar 5900
 bearer-cap Speech
 voice-port 0/0/1
 input gain 4
 compand-type a-law
 cptone GB
 bearer-cap Speech
voice-port 0/2/0
 supervisory disconnect dualtone pre-connect
 supervisory answer dualtone sensitivity high
 no battery-reversal
 soft-offhook
 input gain 4
 cptone GB
 connection plar opx 5000
 impedance complex2
 bearer-cap Speech
 caller-id enable
mgcp profile default
presence
presence call-list
sip-ua
gatekeeper
 shutdown
line con 0
 password ********
 login
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 0 0
 privilege level 15
 password *******
 logging synchronous
 login local
 transport input all
 transport output all
scheduler allocate 20000 1000
end
18 Replies 18
j.huizinga
Level 6
Level 6
Apart from the 7960/7940 being horrible SIP phones, you could try to debug SIP and see what is happening:
debug ccsip messages
Do the phone's try to register?
What is the response from the CME?
JH
Hi JH,
following output are shown in debug: Its not even tries to register.
edoqCME#debug ccsip all
This may severely impact system performance. Continue? [confirm]
All SIP Call tracing is enabled
RedoqCME#
Aug 10 14:43:20.981: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnAgeing: Connection=0x313BDCB0, addr=192.99.44.159, port=5070, connid=2 has been aged out
Aug 10 14:43:20.981: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostCloseConnection: Posting UDP conn close for addr=192.99.44.159, port=5070, local_addr=, connid=2
Aug 10 14:43:20.981: //-1/xxxxxxxxxxxx/SIP/Transport/sipDeleteConnInstance: Deleted conn=0x313BDCB0, connid=2, addr=192.99.44.159, port=5070, local_addr=, transport=UDP
Aug 10 14:43:20.981: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x31C7DA20,addr=192.99.44.159
Aug 10 14:43:20.981: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportStopAgeingTimer: Aging timer stopped for holder=0x31C7DA20,addr=192.99.44.159
Aug 10 14:43:20.981: //-1/xxxxxxxxxxxx/SIP/Transport/sipDeleteConnHolder: Deleted holder=0x31C7DA20, addr=192.99.44.159, count=0
Aug 10 14:43:20.981: //-1/xxxxxxxxxxxx/SIP/Info/udpsock_close_connect: Socket fd: 1 closed for connid 2 with remote port: 5070.
Content-Length: 0
Aug 10 16:25:34.233: //21260/BE352700A9F5/SIP/Error/act_disconnecting_wait_ack: Out of retries
Aug 10 16:25:34.233: //21260/BE352700A9F5/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:9419916 ConnTime 0
Aug 10 16:25:34.233: //21260/BE352700A9F5/SIP/State/sipSPIChangeState: 0x319C0C20 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Aug 10 16:25:34.233: //21260/BE352700A9F5/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x319C0C20
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 1213
Called Number            : 972592253743
Source IP Address (Sig  ): 86.183.210.11
Destn SIP Req Addr:Port  : 23.95.82.42:5077
Destn SIP Resp Addr:Port : 23.95.82.42:5077
Destination Name         : 23.95.82.42
Just a suggestion:
try binding control and source interface of sip to whatever you have configured for voice register global
Voice service voip
sip
bind all <source interface>
and add option 150 in Data VLan also.
by the what do you see in status message on the phone.
on the phone it will be under
setting-->status-->status messages
you can also do "debug voice register events" and "debug voice register errors" to capture the registration process. (dont forget to do term mon)
regards
Chintan
Hi Chintan,
Thanks for you suggeation. Fing attached image file for status message on IP phone. its behaving same way.
voice service voip
 h323
  call preserve
 sip
  bind control source-interface GigabitEthernet0/1.15
  bind media source-interface GigabitEthernet0/1.15
  registrar server
voice class codec 1
voice class h323 1
sh voice register global output after the configuration metioned by you.
CME#sh voice register global
CONFIG [Version=8.6]
  Version 8.6
  Mode is cme
  Max-pool is 10
  Max-dn is 20
  Outbound-proxy is enabled and will use global configured value
  Security Policy: DEVICE-DEFAULT
  Forced Authorization Code Refer is enabled
  Source-address is 10.15.1.1 port 5060
  Load 7960-40 is P0S3-07-5-00
  Time-format is 12
  Date-format is M/D/Y
  Time-zone is 5
  Hold-alert is disabled
  Mwi stutter is disabled
  Mwi registration for full E.164 is disabled
  Forwarding local is enabled
  Video is disabled
  Camera is disabled
  Privacy is enabled
  Privacy-on-hold is disabled
  Dst auto adjust is enabled
    start at Apr week 1 day Sun time 02:00
    stop  at Oct week 8 day Sun time 02:00
  Call List BLF is enabled
  Max redirect number is 5
  IP QoS DSCP:
    ef (the MS 6 bits, 46, in ToS, 0xB8) for media
    cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
    af41 (the MS 6 bits, 34, in ToS, 0x88) for video
    default (the MS 6 bits, 0, in ToS, 0x0) for service
  Telnet Level: 0
  Tftp path is flash:
  Generate text file is disabled
  Tftp files are created, current syncinfo 0001643292548154
  OS79XX.TXT is not created
  timeout interdigit 10
  network-locale[0] GB    (This is the default network locale for this box)
  network-locale[1] GB
  network-locale[2] GB
  network-locale[3] US
  network-locale[4] US
  user-locale[0] US    (This is the default user locale for this box)
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US   Active registrations  : 0
looks like your phone is not able to parse SIP config file and that is why it not able to find CME.
are you runnig mix of both SCCP and SIP phones or only SIP phones?
if you are running only SIP phones, you can Try below.
i see "OS79XX.TXT is not created" in your configuration, to solve this
create OS79XX.txt file, and put it on tftp server.
the OS79XX contents should be single line, that is phone firmware.
create a text file:
put content as firmware that phone shoud use, in your case it will be
P0S3-07-5-00
save file as OS79XX.txt
put the saved file on any tftp server.
copy the file into routers flash
"copy tftp flash" and then give tftp server address and file name.
after succesfully fetching the file in your flash, make it avalable for CME s tftp server
(config)#tftp-server flash:OS79XX.txt
after that, issue comand create profile, and upgrade in Voice register global
#create profile
#upgrade
after all this if you issue "sh voice register global", you should see OS79XX.txt Created.
once all this done, do hard reset of IP phone and see if it is registering or not.
regards
Chintan
i am running only sip right now. I have done all that but still not registering
RedoqCME#
Aug 10 21:38:27.635: %SYS-5-CONFIG_I: Configured from console by console
RedoqCME#sh voice register global
  Version 8.6
  Mode is cme
  Max-pool is 10
  Max-dn is 20
  Time-format is 12
  Time-zone is 5
  Video is disabled
  Camera is disabled
  Privacy is enabled
  IP QoS DSCP:
  Telnet Level: 0
  Tftp path is flash:
  Tftp files are created, current syncinfo 0001643292548159
  OS79XX.TXT is created.
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
ok, can you check your phone and see what firmware its running. i am suspecting firmware has not been updted correctly.it would be probaly there in settings.
aslo please share full set of status message what you are seeing on phone when it is booting up and registering.
also form your CME, please previde output of below.
more flash:SIPDefault.cnf
regards,
Chintan
The following steps are taken when phone boots up
1. Configuring vlan
2. Configuring IP
3. TFTP P0S3-07-5-00.loads
4. Configuring vlan (again)
5. Configuring IP (again)
6. Requsting Configuration
7. Get extention number  (done)
Find attachment for few status on phone.
Its not registering with that is why there is no message from CME.
SHOW FLAH:
65      10800 Nov 19 2012 22:51:18 +00:00 ringtones/Sax1.raw
166      14160 Nov 19 2012 22:51:20 +00:00 ringtones/Sax2.raw
167      16080 Nov 19 2012 22:51:20 +00:00 ringtones/Vibe.raw
169        461 Aug 5 2014 09:48:44 +00:00 P0S3-07-5-00.loads
170     689278 Aug 5 2014 09:47:38 +00:00 P0S3-07-5-00.bin
171     689682 Aug 5 2014 09:49:46 +00:00 P0S3-07-5-00.sb2
172         69 Aug 10 2014 21:48:56 +00:00 syncinfo.xml
173       1142 Dec 6 2012 11:19:58 +00:00
174       4866 Dec 5 2013 00:15:48 +00:00 cdr.RedoqCME.12_04_2013_01_15_49.967
175      14429 Dec 6 2013 00:15:50 +00:00 cdr.RedoqCME.12_05_2013_01_15_50.229
176       4843 Dec 7 2013 00:15:50 +00:00 cdr.RedoqCME.12_06_2013_01_15_50.459
177       8769 Dec 8 2013 00:15:50 +00:00 cdr.RedoqCME.12_07_2013_01_15_50.789
178       6231 Dec 9 2013 00:15:50 +00:00 cdr.RedoqCME.12_08_2013_01_15_51.119
179        204 Dec 9 2013 17:15:50 +00:00 cdr.RedoqCME.12_09_2013_01_15_51.345
180       2004 Aug 10 2014 21:48:58 +00:00 SIPDefault.cnf
181       4342 Aug 10 2014 21:48:58 +00:00 softkeyDefault_kpml.xml
182       4376 Aug 10 2014 21:49:00 +00:00 softkeyDefault.xml
183       4342 Aug 8 2014 08:10:44 +00:00 softkey1_kpml.xml
184       4376 Aug 8 2014 08:10:44 +00:00 softkey1.xml
185        327 Aug 10 2014 21:49:00 +00:00 cme_dialplan_1.xml
186         12 Aug 10 2014 21:02:04 +00:00 OS79XX.txt
187     129292 Aug 5 2014 09:50:44 +00:00 P003-07-5-00.sbn
188        134 Aug 10 2014 21:49:02 +00:00 cme_dialplan_2.xml
189        825 Aug 10 2014 21:49:02 +00:00 featurePolicyDefault.xml
190        825 Aug 8 2014 08:10:46 +00:00 featurePolicy1.xml
191       1331 Aug 10 2014 21:49:02 +00:00 SIP00036B54BCD9.cnf
192       1329 Aug 10 2014 21:49:02 +00:00 SIP003094C45009.cnf
193       1329 Aug 10 2014 21:49:04 +00:00 SIP0002B9AFC0F7.cnf
194       1315 Aug 10 2014 21:49:04 +00:00 SIP00036B75A91C.cnf
Thank You
i am getting clueless :)
lets give one more try:
can share out put of below commands
"sh voice register tftp-bind"
"more flash:/SIPDefault.cnf"
regards
Chintan
I appreciate your efforts. I think that I sould start configuring CME router to register with SIP registrar server. Once I configure SIP channels ( username and password authentication) it may start working.
Please find output below:
CME#more flash:/SIPDefault.cnf
image_version: "P0S3-07-5-00";
call_manager1_addr: "10.15.1.1";
call_manager2_addr: "";
call_manager3_addr: "";
call_manager4_addr: "";
call_manager1_sip_port: "5060";
call_manager2_sip_port: "";
call_manager3_sip_port: "";
call_manager4_sip_port: "";
proxy1_address: "USECALLMANAGER";
proxy2_address: "";
proxy3_address: "";
proxy4_address: "";
proxy5_address: "";
proxy6_address: "";
proxy1_port: "5060";
proxy2_port: "";
proxy3_port: "";
proxy4_port: "";
proxy5_port: "";
proxy6_port: "";
proxy_register: "1";
time_zone: "PST";
dst_auto_adjust: "1";
dst_start_month: "April";
dst_start_day: "";
dst_start_day_of_week: "Sun";
dst_start_week_of_month: "1";
dst_start_time: "02:00";
dst_stop_month: "October";
dst_stop_day: "";
dst_stop_day_of_week: "Sun";
dst_stop_week_of_month: "8";
dst_stop_time: "02:00";
date_format: "M/D/Y";
time_format_24hr: "0";
local_cfwd_enable: "1";
directory_url: "";
messages_uri: "";
services_url: "http://10.15.1.1:80/CMEserverForPhone/serviceurl";
logo_url: "";
stutter_msg_waiting: "0";
sync: "0001643292548153";
telnet_level: "0";
autocomplete: "1";
call_stats: "0";
Domain_Name: "";
dtmf_avt_payload: "101";
dtmf_db_level: "3";
dtmf_inband: "1";
dtmf_outofband: "avt";
dyn_dns_addr_1: "";
dyn_dns_addr_2: "";
dyn_tftp_addr: "";
end_media_port: "32766";
http_proxy_addr: "";
http_proxy_port: "80";
nat_address: "";
nat_enable: "0";
nat_received_processing: "0";
network_port2_type: "Hub/Switch";
outbound_proxy: "";
outbound_proxy_port: "5060";
proxy_backup: "USECALLMANAGER";
proxy_backup_port: "5060";
proxy_emergency: "USECALLMANAGER";
proxy_emergency_port: "5060";
remote_party_id: "0";
sip_invite_retx: "6";
sip_retx: "10";
sntp_mode: "directedbroadcast";
sntp_server: "0.0.0.0";
start_media_port: "16384";
tftp_cfg_dir: "";
timer_invite_expires: "180";
timer_register_delta: "5";
timer_register_expires: "3600";
timer_t1: "500";
timer_t2: "4000";
dscpForAudio : 184;
dscpVideo : 136;
dscpForSCCPPhoneServices : 0;
dscpForCm2Dvce : 96;
voip_control_port: "5060";
CME#show voice register tftp-bind
tftp-server syncinfo.xml url flash:/syncinfo.xml
tftp-server SIPDefault.cnf url flash:/SIPDefault.cnf
tftp-server softkeyDefault_kpml.xml url flash:/softkeyDefault_kpml.xml
tftp-server softkeyDefault.xml url flash:/softkeyDefault.xml
tftp-server cme_dialplan_1.xml url flash:/cme_dialplan_1.xml
tftp-server cme_dialplan_2.xml url flash:/cme_dialplan_2.xml
tftp-server featurePolicyDefault.xml url flash:/featurePolicyDefault.xml
tftp-server SIP00036B54BCD9.cnf url flash:/SIP00036B54BCD9.cnf
tftp-server SIP003094C45009.cnf url flash:/SIP003094C45009.cnf
tftp-server SIP0002B9AFC0F7.cnf url flash:/SIP0002B9AFC0F7.cnf
tftp-server SIP00036B75A91C.cnf url flash:/SIP00036B75A91C.cnf
Thank You.
i dont any clue now :-), but i feel that your phone is not able to understand SIP cnf files. and all configuration looks correct.
lets see some one else here can help you.
regards
Chintan
Chintan,Thanks for your well try.
Can Anyone save my hair pleaseeee!!
Can you try one thing..
Apply below commands under sip register global
authenticate register
authenticate realm all
create profile
If no success, then try to factory reset one of the phone.
Suresh
