Cisco 8845 Touch Screen Feature
kick534
Hello team,
Please i need to know Cisco 8845 IP phone have touch screen feature ???
which Cisco IP phone have touch screen  feature ???
7 Replies 7
b.winter
If you wanna know the features and capabilities of a phone type, just look up the datasheets in the internet.
The forum isn't here to do the google search for you. It's here to help with technical issues.
@b.winter  Dear I already go through with datasheets i didn't find the option, just i need professional advise ...
If the datasheet doesn't say anything about touch screen, then it doesn't have any. Simple as that.
For what do you need a "professional advise" then?
No it does not have a touchscreen. Not sure if Cisco has any models with that. Your best option is to look at the data sheets as @b.winter wrote.
Response Signature
@Roger Kallberg Thanks & Noted
TomMar1
Level 3
Level 3
9971 has touch soft button keys
It is end of sale since 2016.
Response Signature
