05-31-2018 02:05 AM - edited 03-17-2019 12:56 PM
Hello all,
If i press and hold SELECT button for few seconds voice feedback is turning on.
Is their any way to disable this option permanently from phone or CUCM?
CUCM version -11.5
8865 firmware-12.1.1.
Nadeem
11-19-2018 04:47 AM
Have you solved the issue. I am having the same issue with the same versions. If you solved it please let us know.
Muaaz Elkamali
11-19-2018 03:31 PM
Just confirmed with TAC that there is NOT a global CUCM setting to disable this feature in any current version of CUCM. It must be done per device manually.
11-21-2018 06:51 AM
Even if you disabled from the phone and the users press SELECT and hold it will turn on again.
Muaaz
12-04-2019 09:47 AM
Can you please tell how you do it manually on the phone?
02-13-2020 01:17 PM
To turn off, Settings > 3 accessibility > if voice feedback is on, quickly double press the Off softkey in the display.
