Cisco Call Manager bridge upgrade
fgasimzade
Level 4
Level 4
Hello everyone!
A question here:
Is it possible to revert back to the previous version with a bridge upgrade?
2 Accepted Solutions
Chris Deren
Sure, if you installed the prior version first and it is present in the inactive partition.
HTH,
Chris
There is no direct upgrade from 6.1.2 to 8.5, you need to be on at least 6.1.4 per the following:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
So, if you upgrade to 6.1.5 and then 8.5, you will be able to revert back to 6.1.5.
By the way is there a reason you are going to 8.5 and not 9.1 or at least 8.6?
HTH, please rate all useful posts!
Chris
5 Replies 5
Chris Deren
HTH,
Chris
Thank you for the reply!
Yes we have 6.1.2 and going to upgrade to 8.5. So I will be able to revert back if upgrade fails?
Chris
Thank you, Chris!
No reason, just though hardware for 8.5 is cheaper than for 9.1
Hardware is the same, unless your hardware does not allow you to go to version 9.1 and you would need to buy new hardware.  If you are already buying new hardware and hopefully virtulizing the servers then the cost would be the same.
HtH,
Chris
