Cisco CUAC Advanced "Your extension XXXX is out of service. You will not be able to make or receive calls."
jigar_mandalia
Facing issue with the Cisco CUAC Advanced operator console. Once operator logs in, a pop-up is observed with message "Your extension XXXX is out of service. You will not be able to make or receive calls."
Cisco Unified CM Administration System version: 11.5.1.13900-52
CUAC version: Cisco Unified Attendant Console Advanced V11.0.2.20
Please help for the same.
Sorry this turned out to be issue with Cisco TSP configuration. Incorrect username password in Cisco TSP led to this issue. This has been corrected. Thanks @Jaime Valencia @piyush aghera for your reply though. Many thanks.
piyush aghera
This is now solved. It turned out to be an incorrect credentials issue while configuring TSP on server.
