11-23-2023 02:41 AM
Hello everyone,
Is it somehow possible to use these phones with Cisco UCM 11.5?
Could not find any precise answer on the web
11-23-2023 02:50 AM
If you have 5.1(2) installed on the phone, you can register it as a 3rd party sip device (advanced)
https://youtu.be/75018CuYzKc
11-23-2023 02:52 AM
Thank you, @b.winter, will try
11-27-2023 05:46 AM
I finally managed to get my hands on it.
Software version is sip68xx.11-3-1MES-4.loads, and the web interface does not look like the one in the video above.
The phone tries to activate something at activate.cisco.com and then I can see this error in the provisioning logs (192.168.16.4 is our cucm server)
[https://192.168.16.4:443/*]Resync Failed. Reason: Error - Certificate error
So what comes to my mind, would it be possible if we make the phone connect to our tftp server to get 5.1(2) and then follow the guide you provided or it would be just wasting of our time?
11-27-2023 05:44 AM
If you look at the Data Sheet for the 6800 Series phones and go to the "Platform support" section you will see a list of compatible systems, and CUCM is not among them. As @b.winter suggested, though, you might be able to register the phone as a 3rd party SIP device.
Maren
04-08-2024 06:29 AM
Yeah, I have about 13 of them on my CUCM. they worked on 11.5, 12.5 and 14 so far. I installed them as Third Party SIP (Advanced)
Now I am working on getting them installed as Third-party AS-SIP device with SRTP
04-08-2024 06:37 AM
Hello @RAustin70
What is the firmware you are using on these phones?
04-08-2024 06:47 AM
the one I am looking at right now is
Firmware Version: | IPDECT-V2/04.80/B0012/27-Jul-2020_16:01 |
