Cisco IP Phone 8945 not present in cucm version: 7.1.5
Souley Diaby
I am trying to add a Cisco ip phone type 8945 to a CUCM version version: 7.1.5.33900-10
The phone type 8945 does not show up in the drop down window in my Callmanger.
I am trying to find out if i need to add the new firmware for 8945 and the device package ? or only the firmware will do the job ?
Suley
2 Accepted Solutions
Rob Huffman
Hi Souley,
When you are trying to add a new model/device type you will need
to use the Device Pack
Like the latest for 7.1.5
cmterm-devicepack7.1.5.36121-2.cop.sgn
From;
http://www.cisco.com/web/software/282074299/102827/cmterm-devicepack-7_1_5_36121-2_Readme.pdf
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
HI5 for Rob for excellent answer , Just add one more thing, you can refer the IP Phone Feature and CUCM Device Pack Compatibility Matrix.
accordingly you can download the device pack for the respective phones which are supported for CUCM 7.1.5 version
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Rob Huffman
Hi Souley,
From;
Cheers!
Rob
- Springsteen
Br,
Nadeem
