Cisco Jabber 11.7.0 advanced settings link
Greetings!
It looks like after installing jabber 11.7 on Win 7, the starting screen of the application doesn't have the "advanced settings" link. So it's impossible to manually indicate CUCM or IM&P IP addresses.
Win 10 or Win 8 users don't have such a problem. Could you please advise what the reason for that can be?
Mohammed Khan
On Jabber 11.7"Advanced Settings" option is disbaled when UPN is enabled was made as an enhancement request for this version; so it is 'working as designed'
Disabled UPN Discovery through MSI: msiexec.exe /I CiscoJabberSetup.msi CLEAR=1 UPN_DISCOVERY_ENABLED=false
5 Replies 5
Mohammed Khan
Still a problem with 11.8.2 and 11.8.3.  More importantly.  I can only get the Advanced settings to appear once on the initial screen when you need to do loginid@domainname.tld and it has the continue button.  IT's shown the momment you click continue while it's contemplating it's connection, the option is shown.  Once the screen change to prompt for password it's gone.
What a PITA.
charles.elliott
Is this only on Win 7?
ronupcdef
So a super easy way to fix this is to install an earlier version; make your settings in Jabber; then upgrade to the newest version.  Works great!
Not a viable solution when you have 500 employees and have to tell them to do that if you make changes in the environment that requires a change.
