â11-13-2013 05:59 AM - edited â03-16-2019 08:22 PM
Facing issue with Cisco Phone registration Message Registration rejected, Error Mismatch
Tried re adding phone
Manual Firmware
Any suggestion
â11-13-2013 06:17 AM
Make sure the phone you configured is the exact type the phone is in reality. I.e. If phone is 7945 don't build it as 7965.
Chris
â11-13-2013 06:19 AM
Phone type is correct 7942G
â01-22-2014 05:02 PM
Did you check the switch port to see if it says 10/100/1000? If so, it is not 7942G. It would be 7942G-GE
â11-13-2013 06:20 AM
Adding to Chris's suggestion, try to perfoming a Factory Reset to the phone, some Certificate issue could cause this problem too.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas Ăștiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
â11-13-2013 06:28 AM
Already done with factory reset
â11-13-2013 06:59 AM
Hi Dheeraj,
what is the CUCM version u are using?
Do u have enough licenses on CUCM to register new phone?
regds,
aman
â11-13-2013 07:03 AM
Its Call Manager 4, i am able to add other phone
â11-13-2013 07:21 AM
Hi Dheeraj,
Hope u are correctly entering the MAC address in Call manager .
can u share the snapshot and mac-address of phone ?
regds,
aman
â11-13-2013 03:16 PM
Was this phone registered to a CUCM 8 or above before being put on the CUCM 4? If so, it could be the CTL. You need to remove that through Admin mode on a 7942G, I believe.
â03-01-2018 02:07 AM
Hi !!
Yes, this solution was helpful! After adding manually framework all my phones just registered.
Thank you!
