Cisco RTMT for Windows 10
BoBo1
I have tried downloading and install RTMT from CUCM, but it will not install onto my computer. There is no error's or anything, the progress bar for unpacking hits 100% and then nothing else happens.
Is there an updated version of this tool somewhere?
10 Replies 10
Jaime Valencia
No, the RTMT version you need to use, is the one you download from your CUCM.
A newer release of RTMT would only be available if you upgrade your CUCM.
Refer to the RTMT administration guide for your RTMT version for OS compatibility.
java
if this helps, please rate
Stephanie Knoop
Maybe try running the installer as administrator?
Response Signature
I have already tried this, and it produced the same results.
Which  CUCM version you use ?
As per the admin guide, win 10 shows supported from 12.5SU(4). But I have RTMT running on my windows 10 downloaded from 12.0.
Try using windows compatibility option during the installation.
https://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-callmanager/products-maintenance-guides-list.html
Response Signature
We are currently on v11.5 of CUCM.
Do you have Oracle (Sun) Java installed on your computer? RTMT requires that to run and install if I’m not wrong.
Response Signature
Yes I do
Robert Greaves
Did you resolve this? I am having the same issue. I tried all of the earlier suggestions. Thanks for any tips.
-Robert
Hi Robert,
Which version of CUCM are you running?
Try to install in Windows 7 compatibility mode and administrator rights.
Please let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
