Cisco Unity Connection v. 9.1(1a) failed to install
Velin Tsekov
Hi Everyone,
I built a VM using a downloaded OVA template for CUC 9.1(0) although my CUC disk version is 9.1(1a). This OVA template is the last one uploated at cisco.com, and the installation fails with a critical stop. Please refer to the attached file for the reason of the failure.
I built this VM on a UCS C200 M2 server running ESXi 5.0. On this server I have two CUCMs that work correctly.
Any tips on how to resolve this issue? I have read a couple discussion with a similar symptoms, but for a CUCM installation on ESXi, not for CUC.
27 Replies 27
The OVA template allocated 1vCPU, and one should be in idle state which is not configured per VM. I'm using OVA template for 1K users. When I manually select 2 vCPUs I receive an issue with "CUC is not supported".
Going to the TAC...
Hi Velin,
Please do update about TAC findings and hyperthreading also.
regds,
aman
Rob Huffman
Hi Velin,
I just wanted to add this reference to the great help so far from
my friend Aman (+5 Aman )
Your install seems to fail at the spot identified in this bug;
Cisco Unity Connection  8.x/9.x - Fresh Installation fails
CSCug45097
You can open a TAC case directly from this page and the engineer with be able to see
the thread which may help your cause.
https://supportforums.cisco.com/docs/DOC-13613
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
Hi Rob, thank you for your information! It's a funny one :
Conditions:
When we use  "cucservice" as the Application username while installation.
Workaround:
Use the Application Username other than the following usernames
CCMSysUser
WDSysUser
CCMQRTSysUser
IPMASysUser
WDSecureSysUser
CCMQRTSecureSysUser
IPMASecureSysUser
TabSyncSysUser
CUCService
I have used cucadmin/cucroot.
Aman, thank you too, dude!
Hi Rob,
Thanks for sharing the Bug info and opening SR from the thread.
Never thought this could be a bug.
Hi Velin,
Did u open the case?
regds,
aman
Hi Aman, I'll open it tomorrow morning, çause I need to check the service contract #. Meantime I'll try to do the installation again...based on the "workaround" posted in the bug.
I'll keep you in touch with the TAC.
Thank you! Owe u a beer :-)
Hi Velin,
Is the problem resolved?
Please update.
regds,
aman
Hi Velin,
Curious to know whether your problem has been solved .
regds,
aman
Hi, working with the TAC. When I have some more information I'll update you.
thanks for update.
regds,
aman
Hi Velin,
regds,
aman
Dear Aman, first of all sorry for the delay in my answer, but I was on a vacation. Yes, the problem was resolved. It appeared to be a performance issue. It can happen as install and upgrade require more IOPS than normal operation. We stoped 2 of the 3 guest virtual machines running on the host server, so we can have more IOPS free when we install CUC. And that was enough to complete the installation.
Hi Velin,
thanks for updating .Just one more query : Did Cisco TAC engr. run any Command or tool to find IOPS behaviour and reached to conclusion that other VM Machines need to be stopped.
regds,
aman
