02-07-2012 07:58 AM - edited 03-16-2019 09:27 AM
Having some difficulty with the DND softkey not displaying any status change when it's pushed. Users do not know whether or not they have silenced their ringers. Anyone else have this issue and/or have it corrected?
Using 15.1(4)M2 / CME 8.6
Phone loads:
6921: | SCCP69xx.9-0-3-b |
6941: | SCCP69xx.9-0-3-b |
Had it on 9-11 but that broke a few things. Any suggestions or configuration thoughts?
Thanks in advance,
Chris
02-13-2012 08:47 AM
I think this my be ralted this bug CSCti00350
I suggest that you upgrade to the latest release 9.2.2.6
cmterm-69xx-sccp.9-2-2-6.zip
Alex
01-31-2013 09:17 AM
Did upgrading the phone load fix your problem. I am running into the same issue.
01-31-2013 09:39 AM
And have you updated ?
01-31-2013 09:40 AM
no not yet, I wanted to see if it fixed the issue.
01-31-2013 08:00 PM
You should update first and if still troubles, contact Cisco TAC.
02-01-2013 04:45 AM
I did update to the latest phone firmware, and I am still have a issue with the DND status showing on the phone. I am running CME 9.0 and the latest phone load for 6921.
02-01-2013 05:41 AM
Hi there,
I wouldn't be surprised if you are seeing this bug. Although it's listed
for the 6941 it seems likely that it carries over to the 6921 as well;
CSCuc75058 - HLOG and DND softkeys isn't providing status when pressed 6941
Description
Symptom:
HLOG and DND softkeys do not provide status on 6941 phones
Conditions:
Running CME and 9-3-1 ES5
Workaround:
Downgrade to 9-0-3
Details
Status:
Fixed
Last Modified:
Dec 20,2012
Product:
Cisco Unified IP Phone 6900 Series
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
02-01-2013 07:07 AM
Could this have to do with the fact that 69xx do not have a status line on display (as it is so ridiculously smal). They don't even display "system message".
02-01-2013 08:41 AM
I have had a TAC case open for this for a few weeks (For some 6945's).
Cisco said that they have confirmed the issue in their lab and are working on updated firmware.
An interesting workaround they provided: Assign DnD to a feature-button on the ephone-template, so that DND shows up as a line key... Oddly after doing this a message displays for both the line key AND the softkey...
EDIT: I should mention, even on CME9.1 with the latest available firmware for this phone the problem still occurs.
02-01-2013 02:15 PM
We are having a ton of issues with our 69xx phones and line status not updating properly (CFD ALL, etc). If we reset a phone it always comes back up with the correct status, but the displayed status never changes no matter what you do to the line until the phone resets again.
