CME 9.0 Upgrade Registration Rejected Max Phones Exceeded
jeremy.hudgeons
Recently upgrade to CME 9.0 and after ios and phone firmware upgrade I received the error Reg Rej - Max Phones... The CME was operational prior to the upgrade, Show license all showed the license active and the EULA accepted, Telephony-service had existing max-ephones configured. Entered the max-ephone command again with same information and I was prompted for the EULA to accept and phones began to register. Just wanted to put this out there for anybody else that comes across this problem.
25 Replies 25
I am so sorry ? I now out side the office ??? but if you can we do it tomorrow ? I am so sorry again and apologize ??
Many Thanks
Rashid
Hi Aman ,
Kindly could you remote my PC ??
Teamviewer info is :
ID:
301 549 058
Password :
5400
Hi Rashid,
can u try booting the router with old IOS and check if the error is still coming or not ?
use commadn boot system flash:c2900-universalk9-mz.SPA.151-4.m3[check the name]
share output of show license detail cme-srst
regds,
aman
Hi Rashid,
any updates if your problem is resolved or pending.
regds,
aman
Hi Aman,
its still??? and I do not know what i do now??!!
Rasheed
Hi Aman,
how are you? this is the Sharing of output of show license detail cme-srst as the following :
Feature: cme-srst                        Period left: 8  weeks 3  days
Index: 1        Feature: cme-srst                          Version: 1.0
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 3  days
            Period used: 17 hours 1  minute
        License Count: 0/0  (In-use/Violation)
        License Priority: High
        Store Index: 7
        Store Name: Built-In License Storage
Hi Rashid,
Did u try booting the router with OLD IOS and then, check for show license detail cme-srst?
regds,
aman
Hi Aman
yes i do it ?? but Problem is still ??!!  and i try new version which is
c2900-universalk9-mz.SPA.154-1.T.bin  and it is the same !!??
Rashid
Hi Rashid,
I have sent you the Private message.
regds,
aman
guihua xu
Have you ever solved the problem? I have the same problem when I upgrade the CME from 7.1 to 8.6.
the version 7.1 don't support 6921.but when I upload the IOS&CME firmware,and reload.It appeared that
registration rejected max phones exceed....anyone can help me ?Thank you.
guihua xu
