CME - Incoming calls ring but caller gets busy signal
Davidwagman1
Level 7
Level 7
Hi Everyone,
Got the outbound SIP working with my 2851 and call manager express 8. Inbound rings at the proper extension, but the calling phone gets a busy signal. I pulled a SIP trace and it says "Internal Server Error" but I can't figure out the problem, so I'm hoping one of the experts on here can point me in the right direction.
Thanks in advance!
David
Date: Thu, 10 May 2012 13:25:26 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Content-Type: application/sdp
Content-Length: 285
v=0
o=root 7920 7920 IN IP4 74.63.41.218
s=session
c=IN IP4 74.63.41.218
t=0 0
m=audio 16466 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
May 10 09:24:55.889: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 74.63.41.218:5060;branch=z9hG4bK76b5a7c9;rport
From: "5163193019" <sip:5163193019@74.63.41.218>;tag=as0a195cd3
To: <sip:5164038959@96.250.50.2xx:5060>
Date: Thu, 10 May 2012 09:24:55 GMT
Call-ID: 21789578522fa0d02d991cd52d3b083f@74.63.41.218
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
[b]SIP/2.0 500 Internal Server Error[/b]
To: <sip:5164038959@96.250.50.2xx:5060>;tag=3EFA410-119D
CSeq: 102 INVITE
Content-Length: 0
May 10 09:24:55.897: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:5164038959@96.250.50.2xx:5060 SIP/2.0
Contact: <sip:5163193019@74.63.41.218>
CSeq: 102 ACK
User-Agent: VoIPMS/SERAST
Max-Forwards: 70
Remote-Party-ID: "5163193019" <sip:5163193019@74.63.41.218>;privacy=off;screen=no
Content-Length: 0
CONFIG:
------------------ show version ------------------
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Mar-10 01:25 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
CME uptime is 8 hours, 31 minutes
System image file is "flash:c2800nm-ipvoicek9-mz.151-1.T.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2851 (revision 53.51) with 512000K/12288K bytes of memory.
Processor board ID FTX1212A1DS
2 Gigabit Ethernet interfaces
1 terminal line
4 Voice FXO interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#       PID               SN
*0         CISCO2851             FTX1212A1DS
------------------ show running-config ------------------
Building configuration...
Current configuration : 8958 bytes
! Last configuration change at 03:45:25 UTC Fri May 11 2012 by david
version 15.1
hostname CME
boot-start-marker
boot-end-marker
enable secret 5 <removed>
enable password <removed>
no aaa new-model
no network-clock-participate slot 1
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp pool VOICE
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
   option 150 ip 172.16.1.1
ip domain name ipolawgroup.com
ip name-server 4.2.2.2
no ipv6 cef
voice rtp send-recv
voice service voip
 gcid
 clid substitute name
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 sip
  e911
  transport switch udp tcp
  asserted-id ppi
  midcall-signaling passthru
  no call service stop
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
 codec preference 3 g711alaw
voice class h323 1
  telephony-service ccm-compatible
  ccm-compatible
voice translation-rule 2
 rule 1 /105/ /5164038926/
voice translation-rule 3
 rule 1 /5164038959/ /105/
voice translation-profile INCOMING
voice-card 0
voice-card 1
license udi pid CISCO2851 sn FTX1212A1DS
archive
 log config
  hidekeys
username cisco privilege 15 password 0 <removed>
interface GigabitEthernet0/0
 description LAN_INTERFACE
 ip address 172.16.1.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
 no mop enabled
interface Service-Engine0/1
 ip address 172.16.200.1 255.255.255.252
 service-module ip address 172.16.200.2 255.255.255.252
 service-module ip default-gateway 172.16.200.1
interface GigabitEthernet0/1
 description WAN_INTERFACE
 ip address xx.xxx.xx.xxx 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
 no mop enabled
ip forward-protocol nd
ip http server
ip http access-class 10
ip http authentication local
no ip http secure-server
ip http path flash:
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 xx.xxx.xx.x
ip route 10.10.1.0 255.255.255.0 172.16.1.254
access-list 1 permit 172.16.1.0 0.0.0.255
dialer-list 1 protocol ip permit
tftp-server flash:term06.default.loads
tftp-server flash:term41.default.loads
tftp-server flash:P00308010200.bin alias P00308010200.bin
tftp-server flash:P00308010200.loads alias P00308010200.loads
tftp-server flash:P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:P00308010200.sbn alias P00308010200.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:/Ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/Ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/Ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/Ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/Ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/Ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/Ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/Ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/Ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/Ringtones/Pop.raw alias Pop.raw
tftp-server flash:/Ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/Ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/Ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/Ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/Ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/Ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/Ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/Ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/Ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/Ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Ringtones/RingList.xml alias RingList.xml
tftp-server flash:/Ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/Ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/Ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/Ringtones/Bass.raw alias Bass.raw
tftp-server flash:/Ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/Ringtones/Chime.raw alias Chime.raw
tftp-server flash:/Ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/Ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/Ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/Ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/Ringtones/Drums2.raw alias Drums2.raw
control-plane
voice-port 1/0/0
 connection plar opx 102
 caller-id enable
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
ccm-manager music-on-hold
dial-peer voice 100 voip
 description DIAL_PEER_TO_CUE
 destination-pattern 77[5-9]
 session protocol sipv2
 session target ipv4:172.16.200.2
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 10 pots
 description POTS_DIAL_PEER_OUTGOING
 destination-pattern 1[2-9]..[2-9]......
 port 1/0/0
dial-peer voice 1 voip
 incoming called-number 51640389..
 voice-class sip asserted-id ppi
 no voice-class sip block 180
 no voice-class sip block 183
 no voice-class sip block 181
 voice-class sip pass-thru headers unsupp
 voice-class sip pass-thru content unsupp
 voice-class sip pass-thru content sdp
 dtmf-relay rtp-nte
dial-peer voice 2 voip
 destination-pattern [2-9]..[2-9]......
 session target ipv4:74.63.41.218
 session transport udp
 dtmf-relay rtp-nte
 codec g711ulaw
telephony-service
 authentication credential cisco cisco
 max-ephones 30
 max-dn 45
 ip source-address 172.16.1.1 port 2000
 system message IPO Law Group
 url services http://172.16.200.2/voiceview/common/login.do
 url authentication http://172.16.200.1/CCMCIP/authenticate.asp
 cnf-file location flash:
 load 7960-7940 P00308010200
 load 7941 term41.default.loads
 load 7942 term42.default.loads
 load 7945 term70.default.loads
 load 7961 term06.default.loads
 load 7962 term62.default.loads
 load 7965 term71.default.loads
 max-conferences 4 gain -6
 moh flash:music-on-hold.au
 multicast moh 239.1.1.1 port 2000
 web admin system name cisco password <removed>
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
 number 101
 call-forward noan 777 timeout 16
ephone-dn  2  dual-line
 number 102
 call-forward busy 777
ephone-dn  3  dual-line
 number 103
ephone-dn  4  dual-line
 number 104
ephone-dn  5  dual-line
 number 5164038959
 description DID 1 VOIPMS
ephone-dn  6  dual-line
 number 106
ephone-dn  7  dual-line
 number 107
ephone-dn  8  dual-line
 number 108
ephone-dn  9  dual-line
 number 109
ephone-dn  10  dual-line
 number 110
ephone-dn  11  dual-line
 number 111
ephone-dn  12  dual-line
 number 112
ephone-dn  13  dual-line
 number 113
ephone-dn  14  dual-line
 number 114
ephone-dn  15  dual-line
 number 115
ephone-dn  16  dual-line
 number 116
ephone-dn  17  dual-line
 number 117
ephone-dn  18  dual-line
 number 118
ephone-dn  19  dual-line
 number 119
ephone-dn  20  dual-line
 number 120
ephone-dn  21  dual-line
 number 121
ephone-dn  22  dual-line
 number 122
ephone-dn  23  dual-line
 number 123
ephone-dn  24  dual-line
 number 124
ephone-dn  25  dual-line
 number 125
ephone-dn  26  dual-line
 number 126
ephone-dn  27  dual-line
 number 127
ephone-dn  28  dual-line
 number 128
ephone-dn  29  dual-line
 number 129
ephone-dn  30  dual-line
 number 130
ephone  2
 mac-address 0013.60B5.26F1
 username "user2"
 type 7960
 button  1:2
ephone  3
 mac-address 000E.D759.515C
 type 7940
 button  1:3 2:5
line con 0
line aux 0
line 258
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
 password <removed>
 login local
 transport input ssh
scheduler allocate 20000 1000
end
33 Replies 33
You are the BEST!
I removed those 3 from dial-peer 1 and sure enough, no more dial tone, and incoming calling works!!
Thanks! (and sleep well)
I am glad it worked..Those configurations were causing wrong codecs to be used. Please dont forget to rate the posts!
Please rate all useful posts
Rob Huffman
Hey Deji,
Great work here my friend I've given you a +10 for this outstanding
support! It's help like this that makes CSC so great!
Cheers!
Rob
"Everything is broken" - Bob Dylan
Rob,
This is so encouraging from you! Thank you very much. It brings a lot of joy to put smiles on faces, especially when that's the last thing you do before going to bed
Let me say once again, you have been tremendous on this forum.
