CME Register to Skype Fail
rock981119
Hi All,
  I Have Create Skype sip accout, and follow some doc to configure CME to regsiter, but fail, ask for help.
Router config:
sip-ua
credentials username 99051000154290 password 7 033E6D063E210F67543A3427161303 realm sip.skype.com
authentication username 99051000154290 password 7 003E250B3C75252D1512616C08180D realm sip.skype.com
no remote-party-id
retry invite 2
retry register 10
timers connect 100
no timers hold
registrar dns:sip.skype.com expires 3600
sip-server dns:sip.skype.com
connection-reuse
host-registrar
handle-replaces
E2921#sh sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
99051000154290                   -1         51           no
debug ccsip massage was in attach, thx for guidance.
Rock.
2 Accepted Solutions
Chris Deren
As seen in your debug the connection does not get established and is not authorized:
401 Unauthorized
Are you sure you have corrent username and password in your sip-ua config?
Chris
It doesn't change the sip header directly, it just change your calling id number, for example from my extension 1306 to
99051000001534, that way when your call match your skype dial-peer, Skype will accept your call because your are using the number (example: 99051000001534) as your CLID, that is what Skype is expecting to receive.
Gabriel.
9 Replies 9
Chris Deren
401 Unauthorized
Chris
Hi Chris,
  Thx to reply, maybe credentials is not correct, I debug ccsip info saw that:
//36/000000000000/SIP/Info/sipSPIHandleAuthChallenge: Invalid Username or Password
In your opinion that config is OK without User/Pass?
I never tried connecting to Skype, but I doubt they would allow connecting without authenticating.
Chris
I read (well... scanned over half-heartedly) a document from Microsft the other day that described how to set up a connection from MS Lync to Skype.
The solution basically involved putting in an Asterisk server, which ran a custom developed interface of some sort to Skype. So call went from Lync to Asterisk, to custom code to Skype. Suggests to me that connecting to skype is a little more complex than a simple SIP trunk.
Have a read: http://www.microsoft.com/download/en/details.aspx?id=22644
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
This can work with a normal SIP trunk in your voice gateway, I configured this for two of our customers. So, first of all, can you ping sip.skype.com?..Also, can you check in your skype manager that you are using the username/password authentication method (also check if your password and SIP user is the same configure in your router).
Gabriel.
Hi Chris,
  User/Pass incorrect,  change another accout it can registered.
99051000154290@sip,skype.com, that URI i think is regular to make a call.
What if behind CBUE, has a CallManager of IP Phone something, how  can i modification the sip header make behind CUBE device can use the  regular format outside call?
Hi, you can use translation rules to change your calling number ID. I use to change this way:
voice translation-rule 1111
rule 15 /^....$/ /99051000001534/
voice translation-profile Skype
translate calling 1111
dial-peer voice 101 voip
description Skype Outgoing
translation-profile outgoing Skype
destination-pattern 9T
voice-class codec 100
session protocol sipv2
session target dns:sip.skype.com
dtmf-relay rtp-nte
no vad
So everything that comes with a 4 length digit can be converted to the SIP user number
Gabriel.
Hi Gabriel,
  Did you mean translation-rule can change the sip request header like:
"From: <>99051000154xxx@sip.skype.com>"?
  Cuz i saw some doc using "voice class sip-profile xxx", some like that pattern:
  request INVITE sip-header From modify "sip:(.*>)"  "sip:99051000154xxx@sip.skype.com>"
And use in "voice service voip" or "dial-peer".
If translation-rule can do that it will be nice, cuz i am not skillful for "voice class sip-profile"
Gabriel.
