Conference fails with software only conference bridge
PSTN is SIP TRUNK from voip.ms
MRGL has SW_MRG, HW_MRG
SW_MRG: ANN, CFB, MOH, MTP
HW_MRG: XCODE, MTP
I read the software conference bridge supports only g711ulaw. My first test was using a remote phone that had a g729 stream, so I tried from a locally registered phone to two cell phones, and same thing. RTMT shows no "MediaListExhausted" warnings. I tried restarting the voice media streaming app.
On my CUBE i'm getting isdn cause code 16 (normal call clearing).
Ayodeji Okanlawon
What is the region between the sip trunk and the phones set to. What codec is negotiated for the call? If you press the ? button on the phone what codec does it show. What is the region between  your software cfb and your phones?
Please rate all useful posts
Ayodeji Okanlawon
I fixed this by changing maximum bitrate between regions to 64kbps, which changed the call to g711, and allowed the sw conference bridge to work.
Checking the call leg on cube showed a g711ulaw call- but that was between cube and provider. Call was actually g729 and invoking a transcoder to g711 when going to provider.
