Conference Station 8831 is not working on Fallback Mode
wilsonsant
Level 6
Level 6
Hi Guys,
Today in my Company We did test about fallback mode with IP Phones 8851 and 8831. 8851 worked fine in fallback mode, but, 8851 not worked. It receive call normally when is in this condition, but, to outgoing calls not worked. I putted my mobile phone when finish dialing the Station change number my mobile phone to main number, after this I hear the message: Sorry, this is not valid enter. When finish the recorder it try transfer the call to Secretary that is using the main number. Any have idea about this?
Wilson
8 Replies 8
Priyam Acharya
Hi Wilson,
This looks like a translation and dial plan issue on SRST router configuration where 8831 phone is registered as fallback.
1) Any difference in dialing from 8851 and 8831 phones?
2) Please provide entire show run from router.
3) In SRST mode get these debugs for a failed call:
debug isdn q931
debug voip ccapi inout
debug ccsip messages
Priyam Acharya
Hi Priyam,
Thanks a lot for Your contact. Answering Your questions:
1) The process to dialing 8831 is the same 8851
2) Configuration on Gateway, follow below
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.06.08 14:08:44 =~=~=~=~=~=~=~=~=~=~=~=
VGW#
VGW#sh run
Building configuration...
Current configuration : 14733 bytes
! Last configuration change at 13:18:46 GMT Sat Jun 2 2018 by us_svc_tacacs
version 15.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname VGW
boot-start-marker
boot system flash c2951-universalk9-mz.SPA.154-3.M5.bin
boot-end-marker
card type command needed for slot/vwic-slot 0/1
logging queue-limit 10000
logging buffered 10000000
ogging rate-limit 10000
enable secret 5 $1$0/Aw$87jdmndurI/UcdUNW.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authentication ppp default local
aaa authorization config-commands
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa session-id common
clock timezone GMT -3 0
no ip source-route
no ip bootp server
no ip domain lookup
ip domain name cbre.com
ip cef
no ipv6 cef
trunk group PSTN
 hunt-scheme round-robin both up
 translation-profile incoming PSTN-IN
 translation-profile outgoing PSTN-OUT
cts logging verbose
crypto pki trustpoint TP-self-signed-3920029130
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3920029130
 revocation-check none
 rsakeypair TP-self-signed-3920029130
crypto pki certificate chain TP-self-signed-3920029130
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393230 30323931 3330301E 170D3136 30353131 31373132
  32335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39323030
  32393133 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C595 709638B4 60D02B18 5FC5848C 287989CF 46D08DE6 A54BCC7E 7D6C8432
  EF9ACDB8 3D226A14 A683AC9C 6E1BDA5C 61B37807 1C1DD16A 4830B35B 115BF09A
  A74FFA33 B000CAFD 789235E5 283ADFDE F46DB0AA 593D4951 6EDFB733 3C0CD1E4
  250788E7 CE91D348 0E807E67 E3BFBDD9 FC2F28DA 04E74EA2 CAEE3915 32A85B41
  830F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 146007C8 5053DE9D C7B2CE97 52C72B9F 3E581944 95301D06
  03551D0E 04160414 6007C850 53DE9DC7 B2CE9752 C72B9F3E 58194495 300D0609
  2A864886 F70D0101 05050003 8181008A 7E102B4A 58B840FC 1004B791 3AD00BD5
  534F324F 3F2B353D 87FEA2FE D8A6888D E65C36A8 D0CEDDCE BFEBF496 B658BDD4
  5A234774 4CFDC21A BAED1371 F576D5A5 64D73BA8 3BB3B85A 47F7B8F5 F3D7B8AA
  DC0F5A7A 8EA10211 938B37BA 20B5E961 87C5669D 7A1F6B50 716C1CF7 4C6A067B
  D3F55BEF 434AD756 67320CD9 32EEDF
   quit
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service pots
 fax rate disable
voice service voip
 ip address trusted list
  ipv4 10.33.102.2
  ipv4 10.33.102.1
  ipv4 10.55.0.107
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
 modem passthrough nse codec g711ulaw
 sip
  session transport tcp
  min-se 2400 session-expires 2400
  registrar server expires max 600 min 60
  asserted-id pai
  midcall-signaling passthru
  g729 annexb-all
  sip-profiles 1
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice class sip-profiles 1
 request ANY sdp-header Audio-Attribute modify "a=inactive" "a=sendrecv"
 request REINVITE sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
 request ANY sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
voice class e164-pattern-map 1
 description Carrier DID Ranges
  e164 +776448344704
  e164 +7718711095..
  e164 +7718242485[0-4].
  e164 +7718391397[4-9].
 voice class e164-pattern-map 2
 description MEGACOM - BRA DID Ranges
  e164 711095..
  e164 421397[4-9].
  e164 84[0-4].
  e164 96..
  e164 91[4-9].
voice register global
 mode srst
 timeouts interdigit 5
 system message WAN Outage - Fallback Mode
 max-pool 250
voice register pool  1
 translation-profile incoming SRST-IN
 id network 10.0.0.0 mask 255.0.0.0
 dtmf-relay rtp-nte sip-notify
 voice-class codec 1
 no vad
voice translation-rule 10
 rule 1 /^\([2-5].......\)$/ /+7733\1/
 rule 2 /^\([79][6-9].......\)$/ /+7733\1/
 rule 3 /^\([1-9][1-9][2-9].......\)$/ /+77\1/
 rule 4 /^\([1-37-9][1-9][79]........\)$/ /+77\1/
 rule 5 /^\00\(.*\)$/ /+\1/
 rule 6 /^\(.*\)$/ /+\1/
voice translation-rule 20
 rule 1 /^\(97..\)$/ /+77333913\1/
 rule 2 /^\(8...\)$/ /+77332424\1/
 rule 3 /^\(39139...\)$/ /+7733\1/
 rule 4 /^\(95..\)$/ /+77332110\1/
 rule 5 /^\(211095..\)$/ /+7733\1/
voice translation-rule 30
 rule 2 /.*/ /8500/
 rule 3 /^\+.*/ /8500/
voice translation-rule 40
 rule 2 /^0\([2-9].......\)$/ /\1/
 --More--          rule 3 /^0\([79]........\)$/ /\1/
 rule 4 /^0\(19.\)$/ /\1/
 rule 5 /^0\(181\)$/ /\1/
 rule 6 /^0\(911\)$/ /\1/
 rule 7 /^0\(112\)$/ /\1/
 rule 8 /^00\([1-9][1-9][2-9].......\)$/ /071\1/
 rule 9 /^00\([1-9][1-9][2-9]........\)$/ /071\1/
 rule 10 /^00\([4-6][1-9]9[6-9].......\)$/ /071\1/
 rule 11 /^00\([1-37-9][1-9][79]........\)$/ /071\1/
 rule 12 /^00\([38]00.......\)$/ /0\1/
 rule 13 /^000\([1-9].*\)$/ /0071\1/
 rule 14 /^0\(.*\)$/ /\1/
voice translation-rule 50
 rule 1 /^\(97[4-9].\)$/ /+77333913\1/
 rule 2 /^\(329.\)$/ /+55555284\1/
 rule 3 /^\(8[78]..\)$/ /+55558526\1/
 rule 4 /^0$/ /+773339139740/
voice translation-rule 60
 rule 11 /^\+5511\([2-9].......\)/ /0\1/
 rule 12 /^\+5511\([79]........\)/ /0\1/
 rule 13 /^\+55\([1-9][1-9][2-9].......\)/ /00\1/
 --More--          rule 14 /^\+55\([1-37-9][1-9][79]........\)/ /00\1/
 rule 15 /^\+\([1-9].*\)/ /000\1/
voice translation-profile NOPLUS-IN
 translate called 60
voice translation-profile PSTN-IN
 translate calling 10
 translate called 20
voice translation-profile PSTN-OUT
 translate calling 30
 translate called 40
voice translation-profile SRST-IN
 translate called 50
license udi pid CISCO2951/K9 sn FJC2020A0PU
license accept end user agreement
license boot module c2951 technology-package uck9
hw-module pvdm 0/0
hw-module sm 1
username cbnetsvc password 7 08707D6F334B12040A
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description UPLINK TO DMZ-SW
 ip address 10.43.30.5 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description UPLINK TO SIP SERVICE
 ip address 10.76.3.250 255.255.255.252
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export destination 10.42.229.49 9996
ip access-list standard SNMP_SERVERS
 permit 10.42.240.170
 permit 10.40.18.16
 permit 10.42.104.5
 permit 10.40.18.17
 permit 10.40.18.15
 permit 10.42.241.197
 permit 10.42.223.27
 permit 10.42.226.14
 permit 10.42.240.8
 permit 10.42.240.76
 permit 10.42.241.68
 permit 10.42.241.67
 permit 10.42.198.80 0.0.0.15
 deny   any log
ip access-list extended BOX
 permit ip any 61.32.64.0 0.0.15.255
 permit ip 61.32.64.0 0.0.15.255 any
ip access-list extended DROPBOX
 permit ip any 92.21.80.0 0.0.15.255
 permit ip 92.21.80.0 0.0.15.255 any
ip access-list extended PCAP_ACL
 permit ip any any
ip access-list extended WIRELESS-DATA
 permit udp any any eq 5247
 permit udp any eq 5247 any
logging trap notifications
logging source-interface GigabitEthernet0/0
logging host 10.42.206.60
logging host 10.42.105.85
nls resp-timeout 1
cpd cr-id 1
snmp-server community h0tsauce RO SNMP_SERVERS
snmp-server community gr33n RO SNMP_SERVERS
snmp-server community ch1ll1 RW SNMP_SERVERS
snmp-server ifindex persist
snmp-server location Berrini, Brazil
snmp-server system-shutdown
snmp-server enable traps tty
snmp-server enable traps syslog
tacacs-server host 10.42.198.120
tacacs-server host 10.40.18.13
tacacs-server directed-request
tacacs-server key 7 111D1A061E1406
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.33.104.1 identifier 2 version 7.0
sccp ccm 10.33.104.2 identifier 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register BRA_BR500_CFB
 associate profile 2 register BRA_BR500_XCODE
 associate profile 3 register BR500_711U_MTP
 associate profile 4 register BR500_711A_MTP
 associate profile 5 register BR500_729R8_MTP
 keepalive retries 5
 switchover method immediate
 switchback method immediate
 switchback interval 15
dspfarm profile 2 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 codec g729br8
 maximum sessions 26
 associate application SCCP
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 28
dspfarm profile 3 mtp
 codec g711ulaw
 maximum sessions software 100
dspfarm profile 4 mtp
 codec g711alaw
dspfarm profile 5 mtp
 codec g729r8
dial-peer voice 150 voip
 preference 1
 session protocol sipv2
 session target ipv4:10.33.104.2
 destination e164-pattern-map 1
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate 14400
 fax protocol pass-through g711ulaw
 no vad
dial-peer voice 250 voip
 preference 2
 session target ipv4:10.33.104.1
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate 14400
 no vad
dial-peer voice 9911 voip
 description Outbound calls to PSTN
 preference 1
 destination-pattern 0911$
 session target ipv4:10.44.0.102
 incoming called e164-pattern-map 2
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 no vad
dial-peer voice 100 pots
 tone ringback alert-no-PI
 description Inbound calls from PSTN
 incoming called-number .
 direct-inward-dial
dial-peer voice 9112 voip
 preference 1
 destination-pattern 0112$
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 9192 voip
 preference 1
 destination-pattern 019.$
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 9181 voip
 preference 1
 destination-pattern 0181$
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 1000 voip
 description Outbound calls from UCM
 translation-profile incoming NOPLUS-IN
 incoming calling e164-pattern-map 1
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 110 voip
 destination-pattern 0T
 session transport udp
 voice-class codec 1
 voice-class sip early-offer forced
 voice-class sip profiles 1
 voice-class sip profiles 1 inbound
 voice-class sip bind control source-interface GigabitEthernet0/1
 voice-class sip bind media source-interface GigabitEthernet0/1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 1001 voip
 description Inbound calls from MEGA
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
sip-ua
 retry invite 2
 timers trying 300
 g729-annexb override
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 16 gain -6
 transfer-system full-consult
 ip source-address 10.71.30.5 port 2000
 max-ephones 75
 max-dn 150 dual-line
 system message primary WAN Outage - Fallback Mode
banner login ^C
WARNING: To protect the system from unauthorized use and to ensure that the
system is functioning properly, activities on this system are monitored and
recorded and subject to audit. Use of this system is expressed consent to
such monitoring and recording. Any unauthorized access or use of this system
is prohibited and could be subject to criminal and civil penalties.
^C
line con 0
 exec-timeout 5 0
 password 7 1248343628591B1732
line aux 0
 exec-timeout 5 0
 modem InOut
 transport input all
 stopbits 1
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
 line vty 0 4
 exec-timeout 15 0
 privilege level 15
 password 7 005522273E091C1517
 transport input ssh
line vty 5 15
 exec-timeout 15 0
 privilege level 15
 password 7 055A372E1B1E591A01
 transport input ssh
scheduler allocate 20000 1000
ntp server 10.96.24.1
end
BERRINI_BR500_VGW#
3) Unfortunatelly, my profile don´t have privilege to run debug.
Wilson
Ratheesh Kumar
Hi there
Could you add this and test it out
no digit collect kpml
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Hi Ratheeshek Kumar,
I will verify with my co-worker that have access privelege to him put the command then I answer for You.
Wilson
Sounds good, let’s see how it goes
Hope this helps
Cheers
Rath!
Hi Ratheesh Kumar,
My Co-worker that have access the configuration terminal is asking for me if put this parameters in the voice register pool can not stop the anothers IP Phone models. Is it possible?
Wilson
This is a global config. I want to see any changes if we stop digit collecting using "no digit collect kpml" command. I have seen incidents where disabling digit collect works for 8831 SRST mode.
Hope this helps!
Cheers
Rath!
Hi Ratheesh Kumar,
Thanks a lot for Your return. I am waiting my co-worker to schedule the windows maitenance to do test. I will answer for You when to do test.
Wilson
