Configure Cisco ISR 4321 to block specific incoming phone numbers
Circle
Greetings,
I am looking for information on blocking incoming phone numbers within our CUCM voice gateway Cisco ISR 4321.
Any examples or documentation would be greatly appreciated.
Thank you!
7 Replies 7
The internet is abundant with resources on this subject. The link provided by @b.winter  includes a detailed session on Call Blocking Configuration Examples
Response Signature
Daniel Bosch
Here's a specific example I pulled from my journal to block inbound calls on POTS lines.  In my case, I translated any matching number I wanted to block to '0' since there would be no matching outbound peer.  You could use any pattern that doesn't match any outbound peer and get the desired result. This might work on ISDN PRI too but might the translation-profile might be applied to something different.
voice-port 0/1/2
 trunk-group POTS
 connection plar 13180184800
 bearer-cap Speech
 caller-id enable
voice translation-rule 9999
 rule 1 /.*/ /0/ <-- 0 does not match any outbound peer.
voice translation-profile CallBLOCK
 translate called 9999
dial-peer voice 9990 pots
 description ### Block inbound from 512.465.1883 ###
 translation-profile incoming CallBLOCK
 translation-profile outgoing CallBLOCK  <-- Probably not required but doesn't hurt
 huntstop <-- Probably not required either but doesn't hurt
 answer-address 5124651883  <-- Matches calling number you want to block
 direct-inward-dial
Results:
debug vpm signal
debug voice translations
debug voip dialpeer inout
Apr 24 14:36:54.191 CDT: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=26176 systime=128176282
Apr 24 14:36:54.192 CDT: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Apr 24 14:36:54.192 CDT: htsp_timer - 125 msec
Apr 24 14:36:54.317 CDT: htsp_process_event: [0/1/2, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Apr 24 14:36:54.317 CDT: htsp_timer - 10000 msec
Apr 24 14:36:54.317 CDT: htsp_timer3 - 5600 msec
Apr 24 14:36:54.317 CDT: [0/1/2] htsp_start_caller_id_rx:Mode BELLCORE. Alerting 0x1
Apr 24 14:36:54.317 CDT: htsp_start_caller_id_rx create dsp_stream_manager
Apr 24 14:36:54.318 CDT: [0/1/2] htsp_dsm_create_success  returns 1
Apr 24 14:36:56.258 CDT: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=28245 systime=128176488
Apr 24 14:36:56.258 CDT: htsp_process_event: [0/1/2, FXOLS_RINGING, E_DSP_SIG_0100]
Apr 24 14:36:56.258 CDT: fxols_ringing_not
Apr 24 14:36:56.258 CDT: htsp_timer_stop
Apr 24 14:36:56.258 CDT: htsp_timer - 10000 msec
Apr 24 14:36:57.274 CDT: [0/1/2] htsp_dsm_feature_notify_cb  returns 2 id=DSM_FEATURE_SM_CALLERID_RX
Apr 24 14:36:57.274 CDT: htsp_process_event: [0/1/2, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
Apr 24 14:36:57.274 CDT: fxols_callerid_done: stop caller ID
Apr 24 14:36:57.274 CDT: [0/1/2] htsp_stop_caller_id_rx. message length 32
Apr 24 14:36:57.274 CDT: htsp_timer_stop3
Apr 24 14:36:57.274 CDT: htsp_timer3 - 20 msec
Apr 24 14:36:57.276 CDT: [0/1/2] htsp_dsm_close_done
Apr 24 14:36:57.294 CDT: htsp_process_event: [0/1/2, FXOLS_STOP_CALLERID_DELAY, E_HTSP_EVENT_TIMER3]
Apr 24 14:36:57.294 CDT: htsp_timer_stop
Apr 24 14:36:57.294 CDT: htsp_timer_stop3 htsp_setup_ind
Apr 24 14:36:57.294 CDT: [0/1/2] get_fxo_caller_id:Caller ID received. Message type=128 length=31 checksum=82
Apr 24 14:36:57.295 CDT: [0/1/2] Caller ID String 80 1C 01 08 30 34 32 34 31 34 33 36 02 0A 35 31 32 34 36 35 31 38 38 33 07 04 46 43 42 54 82
Apr 24 14:36:57.296 CDT: [0/1/2] get_fxo_caller_id calling num=5124651883 calling name=FCBT calling time=04/24 14:36
Apr 24 14:36:57.296 CDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=5124651883, Called Number=, Voice-Interface=0x7F6AA453C028,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ANSWER; Incoming Dial-peer=9990
Apr 24 14:36:57.296 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Apr 24 14:36:57.296 CDT: fxols_callerid_done: call being answered
Apr 24 14:36:57.298 CDT: //-1/27F563598529/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x7F6AA9752FA0; count=1
Apr 24 14:36:57.298 CDT: //-1/27F563598529/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x7F6AA9599D48
Apr 24 14:36:57.298 CDT: htsp_process_event: [0/1/2, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Apr 24 14:36:57.298 CDT: fxols_wait_setup_ack:
Apr 24 14:36:57.299 CDT: [0/1/2] nim_set_sig_state: ABCD=12, timestamp=0, sys_time=128176592
Apr 24 14:36:57.299 CDT: [0/1/2] set signal state = 0xC timestamp = 0fxols_check_auto_call
Apr 24 14:36:57.299 CDT: //-1/27F563598529/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x7F6AA9752FA0; count=1
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_profile_translate_internal: number=5124651883 type=unknown plan=unknown numbertype=calling
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_profile_translate_internal: No match: number=5124651883 type=unknown plan=unknown
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_profile_translate_internal: number=13180184800 type=unknown plan=unknown numbertype=called
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 9999
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/sed_subst: Successful substitution; pattern=13180184800 matchPattern=.* replacePattern=0 replaced pattern=0
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
Apr 24 14:36:57.300 CDT: //-1/27F563598529/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
Apr 24 14:36:57.301 CDT: //-1/27F563598529/RXRULE/regxrule_profile_translate_internal: xlt_number=0 xlt_type=unknown xlt_plan=unknown
Apr 24 14:36:57.301 CDT: //-1/27F563598529/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=0
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Apr 24 14:36:57.301 CDT: //-1/27F563598529/DPM/dpMatchSafModulePlugin:
   dialstring=0, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
Apr 24 14:36:57.301 CDT: //-1/27F563598529/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Apr 24 14:36:57.302 CDT: //-1/27F563598529/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Apr 24 14:36:57.302 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=0, Called Number=0, Peer Info Type=DIALPEER_INFO_SPEECH
Apr 24 14:36:57.302 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 24 14:36:57.302 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Apr 24 14:36:57.302 CDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=0, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Apr 24 14:36:57.303 CDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Apr 24 14:36:57.303 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 24 14:36:57.303 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Apr 24 14:36:57.304 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Apr 24 14:36:57.304 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Apr 24 14:36:57.304 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Apr 24 14:36:57.304 CDT: //-1/27F563598529/DPM/dpMatchPeersCore:
Apr 24 14:36:57.304 CDT: //-1/27F563598529/DPM/dpMatchSafModulePlugin:
   dialstring=0, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
Apr 24 14:36:57.305 CDT: //-1/27F563598529/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Apr 24 14:36:57.305 CDT: htsp_process_event: [0/1/2, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
Apr 24 14:36:57.305 CDT: htsp_timer - 120000 msec
Apr 24 14:36:57.305 CDT: htsp_pre_connect_disconnect, cdb = 7F6AA94A9358 cause = 1
Apr 24 14:36:57.305 CDT: htsp_process_event: [0/1/2, FXOLS_PROCEEDING, E_HTSP_PRE_CONN_DISC]
Apr 24 14:36:57.588 CDT: htsp_dsp_message: SEND_SIG_STATUS: state=0x6 timestamp=29573 systime=128176621
Apr 24 14:36:57.588 CDT: htsp_process_event: [0/1/2, FXOLS_OFFHOOK, E_DSP_SIG_0110]
Apr 24 14:36:57.588 CDT: htsp_timer_stop2 fxols_offhook_rvs_battery
What your doing in your example here is not really what the documentation for blocking calls says. Your example is for sure not letting the call to go through, but it's doing so by no route for the called number after the translation. To do call blocking as outlined in the referenced documentation you would do this.
voice translation-rule 1
 rule 1 reject /5124651883/ ! The calling number you wand to block
voice translation-profile call_block
 translate calling 1
dial-peer voice 100 pots ! Incoming dial-peer, can be pots or voip, it doesn't matter
 call-block translation-profile incoming call_block
 call-block disconnect-cause incoming call-reject
Response Signature
Thanks, Roger.
If I recall correctly, I wasn't having luck with what I found in documentation at the time.  I may have been doing something wrong or was encountering a bug and didn't know it.  I deposited your solution in my journal too, along with my 'workaround' solution.  If I ever have to do this again, I'll try it the right way first.
Daniel Bosch
And here's an example I used with a SIP carrier.  Hope this is helpful.
 rule 1 reject /2144447848/
 rule 2 reject /5124651883/ <-- Calling number in this example.
voice translation-profile callBlock
 translate calling 999
dial-peer voice 100 voip
 description *** Inbound from ITSP ***
 translation-profile incoming ITSPin
 call-block translation-profile incoming callBlock
 session protocol sipv2
 session target sip-server
 incoming called-number [2-9].........$
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte
 codec g711ulaw
 fax-relay ecm disable
 fax-relay sg3-to-g3
 fax rate 14400
 fax protocol pass-through g711ulaw
 no vad
Results:
debug ccsip message
Sep 19 15:13:05.444 CDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4302053263@X.X.X.X:5060 SIP/2.0
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK+89ede4f43d98507d3ee982da1c05be701+sip+1+b8e9c7c4
From: "FCBT" <sip:5124651883@7007612002.siptrunking.com>;tag=205.196.170.135+1+1a0516f8+cd16e293
To: <sip:4302053263@7007612002.siptrunking.com>
CSeq: 1059759216 INVITE
Expires: 180
Content-Length: 270
Call-Info: <sip:X.X.X.X:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Supported: resource-priority,siprec, 100rel
Contact: <sip:83749c3abcca9d67c22b6a55bd81f109@X.X.X.X:5060>
Content-Type: application/sdp
Allow-Events: message-summary, refer, dialog, line-seize, presence, call-info, as-feature-event, calling-name, ua-profile
Call-ID: 0gQAAC8WAAACBAAALxYAAEoaddHDiLCnDkAO5nxe+WJZ6cy6VGNmL/h7KQa+uCT8@X.X.X.XOrganization: Metaswitch Networks
Max-Forwards: 67
P-Asserted-Identity: "FCBT" <sip:5124651883@X.X.X.X>
Accept: application/sdp
v=0
o=- 62136702725358 62136702725358 IN IP4 X.X.X.X
s=-
c=IN IP4 X.X.X.X
t=0 0
m=audio 17818 RTP/AVP 0 18 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:101 telephone-event/8000
a=rtpmap:8 PCMA/8000
a=fmtp:18 annexb=no
a=ptime:20
Sep 19 15:13:05.445 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=4302053263, Called Number=4302053263, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4302053263
   Result=Success(0) after DP_MATCH_DEST
Sep 19 15:13:05.446 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=4302053263, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Sep 19 15:13:05.446 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=15
Sep 19 15:13:05.446 CDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=5124651883, Called Number=, Voice-Interface=0x0,
Sep 19 15:13:05.447 CDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 19 15:13:05.447 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sep 19 15:13:05.448 CDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 19 15:13:05.448 CDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sep 19 15:13:05.448 CDT: //-1/B969841AB5D2/DPM/dpAssociateIncomingPeerCore:
   Calling Number=5124651883, Called Number=4302053263, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=100
Sep 19 15:13:05.448 CDT: //-1/B969841AB5D2/DPM/dpMatchSafModulePlugin:
Sep 19 15:13:05.449 CDT: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
   Tag=100
   Result=0 Bitmap=0x0
Sep 19 15:13:05.452 CDT: //753028/B969841AB5D2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
From: "FCBT" <sip:5124651883@7007612002.siptrunking.com>;tag=X.X.X.X+1+1a0516f8+cd16e293
Date: Thu, 19 Sep 2019 20:13:05 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.6.5
Session-ID: 00000000000000000000000000000000;remote=1553f14053ee5a51a1b3180fbbb9d22b
Content-Length: 0
Sent:
SIP/2.0 403 Forbidden
To: <sip:4302053263@7007612002.siptrunking.com>;tag=607CD168-479
Reason: Q.850;cause=21  <-- 'Call Rejected'
Session-ID: 1553f14053ee5a51a1b3180fbbb9d22b;remote=830c175ae5435b928cdee270c28bb7ec
Content-Length: 0
Circle
Thank's for all the information!
