Configuring a Hunt Group with Unity Connection
Pedro Silva
I have been having some fun configuring a hunt group and Unity system call handler over the last couple of days. I think I am nearly there but I am puzzled by some unexpected behaviour.
The scenario is as follows:
Hunt Pilot DN 421 -> Hunt List - >Line Group
Hunt List set to "For Voice Mail Usage" enabled
Line Group set to Longest Idle - Hunt Options set to Try next member, but do not go to next group
Unity System Call Handler configured with extension DN 421
Standard Transfer Rule set to Greeting
Standard Greeting set to "My Personal Recording"
Standard Greeting - After Greeting - Call Action -set to Hangup
Scenario 1. - working as intended
Call Hunt pilot -> rings extension in hunt group -> extension declines -> Unity announcement plays then hangs up
Scenario 2. - not working as intended
Call Hunt pilot -> rings extension in hunt group -> extension does not answer -> call drops without passing to Unity
I know I had this working earlier but can't work out how I have broken it.
Pedro
Chris Deren
First of all do not check ""For Voice Mail Usage" on this hunt list as that is meant only for hunt groups used for SCCP integration to Unity, not for actual hunt lists routing to phones.
You need to setup call forward no answer/busy on the hunt pilot with destination of voicemail, typically by pointing to CTI Route Point set to forward all to VM where the DN of the CTI RP matches the call handler DN.
Ratheesh Kumar
Hi there
I have seen cases, just try deleting the hunt group and hunt list for the non-working and start again.
Any codec/region issues with these phones. Is that the calls from hunt only breaks.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
HARIS_HUSSAIN
======> The Decline Button on IPhone forwards the call to Unity connection. I believe this is what happening in this case.
======> for this you need to set the No Aswer option on Hunt Pilot Page
