08-17-2010 04:04 AM - edited 03-16-2019 12:17 AM
How can convert .wav G.711 to G.729 ?
Solved! Go to Solution.
09-08-2010 02:35 AM
Use agcutil.exe; this is what the 'Set WAV Format' utility from Unity uses to switch it's own prompts to g729/g711.
Like so:
D:\CommServer\Utilities\SetWAVFormat>agcutil
Wave conversion utility v1.2
Usage: agcutil [-s src] [-d dest] [[-t targetDB] | [-f targetFormat]]
[-b buffersize] [-g gainThreshold] [-m minThreshold]Target formats:
g.711/uLaw = 7
g.711/aLaw = 6
g.729 = 307
pcm 16 = 1D:\CommServer\Utilities\SetWAVFormat>agcutil.exe -s "D:\origwavbackup\Stream Fil
es\aaron.harrison_SubName_000bdaab.wav" -d "d:\test.wav" -f 307Wave conversion utility v1.2
File D:\origwavbackup\Stream Files\aaron.harrison_SubName_000bdaab.wav converted
to g729a
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
08-17-2010 04:12 AM
There are different ways to achieve this. One of the "easier" ways is to run it trough the MOH translator in CUCM, then you will have four wav files. G711ulaw, G711alaw, G729 and WB.
Roger Kallberg
CCIE # 26199 (Voice)
08-17-2010 08:43 PM
How do more high volume in .wav G.729 ?
08-17-2010 11:26 PM
I don't use the MoH translater for this stuff; as the poster noted it tends to attenuate the volume.
Do you have access to a Unity server? (not CUC, or CUE, but good old fashioned Windows-based Unity)?
THere is a CLI utility on the Unity server you can use for this; it is also scriptable if you have lots of prompts.
Aaron
09-07-2010 11:54 PM
I have Unity (Windows). How can convert 711 to 729 without attenuate the volume?
09-08-2010 02:35 AM
Like so:
g.711/uLaw = 7
g.711/aLaw = 6
g.729 = 307
to g729a
Aaron
06-02-2020 06:07 PM
Can anyone tell me where I can get this "agcutil.exe" program? I find it quite ridiculous that I cant find anything to convert my 100+ UCCX g729 wav files to g711 to put into another UCCX box that is g711 only. Why is it so difficult to achieve this? I even opened a Cisco TAC case to ask them how to do this and they said to use Audacity, of which doesn't work and nether does 'ffmpeg" and then he suggested an online tool, but I have well over 100 files.
06-13-2023 04:31 AM
Hi nanosynth,
Did you ever find a way to do this? I am in the same situation where I need to convert UCCX prompts from G729 to G711. I have tried FFMPEG and various on-line converters without success
