CUBE SIP Trunk Outbound calls failing
Nina
We can't seem to get the outbound calls to work on our SIP Trunk. The inbound calls have no issue.
Please take a look at the trace routes, need help..
003820: *Sep 27 12:34:02.125: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:915147047479@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.248.10:5060;branch=z9hG4bK1548106ad02277
From: <sip:9056711271@192.168.248.10>;tag=13956200~a38f0a9c-d7b3-49cb-a446-3d557da7351f-20514648
To: <sip:915147047479@192.168.22.10>
Date: Wed, 27 Sep 2017 16:31:05 GMT
Call-ID: 40c13000-9cb1d249-d91a6-af8a8c0@192.168.248.10
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM11.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Session-ID: 6a53137f00105000a000009e1ede3ddc;remote=00000000000000000000000000000000
Cisco-Guid: 1086402560-0000065536-0000000103-0184068288
Session-Expires:  1800
P-Asserted-Identity: <sip:9056711271@192.168.248.10>
Remote-Party-ID: <sip:9056711271@192.168.248.10>;party=calling;screen=yes;privacy=off
Contact: <sip:9056711271@192.168.248.10:5060>;+u.sip!devicename.ccm.cisco.com="SEP009E1EDE3DDC"
Max-Forwards: 69
Content-Length: 0
003821: *Sep 27 12:34:02.128: //543583/40C130000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 27 Sep 2017 12:34:02 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.3.S4b
Content-Length: 0
003822: *Sep 27 12:34:02.131: //543584/40C130000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:15147047479@199.188.188.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bK7D7B380
From: <sip:9056711271@hgtp.com;user=phone>;tag=21B3A136-1F4E
To: <sip:15147047479@siptrunking.bell.ca>
Call-ID: 81234E75-A2D811E7-8E9C8CD2-340EA8A7@hgtp.com
Supported: 100rel,timer,resource-priority,replaces,histinfo,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S4b
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1506530042
Contact: <sip:9056711271;tgrp=3268488;trunk-context=siptrunking.bell.ca@192.168.22.10:5060>
History-Info: <sip:15147047479@199.188.188.3:5060>;index=1
Expires: 180
Max-Forwards: 68
P-Asserted-Identity: <sip:9056711271@hgtp.com;user=phone>
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 1601 6295 IN IP4 192.168.22.10
s=SIP Call
c=IN IP4 192.168.22.10
t=0 0
m=audio 13110 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
15 Replies 15
Slavik Bialik
Level 7
Level 7
Hi Nina, Please show us the full sip debug messages. You just showed us the INVITE that is outgoing to the PSTN but not the message that is returned from the PSTN.
Hello Slavik,
Here is the full sip debug message:
Received:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 0
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 68
Content-Length: 250
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
003823: *Sep 27 12:34:02.150: //543584/40C130000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 205.204.70.71;branch=z9hG4bK7D7B380;received=205.204.70.71;rport=54080
CSeq: 101 INVITE
Server: Enswitch
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Session-Expires: 1800;refresher=uas
Contact: <sip:15147047479@199.188.188.3:5060>
Content-Length: 0
003824: *Sep 27 12:34:02.185: //543584/40C130000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <sip:15147047479@siptrunking.bell.ca>;tag=as5eac6e5c
CSeq: 101 INVITE
Server: Enswitch
Require: timer
Content-Length: 237
v=0
o=root 548566970 548566970 IN IP4 199.188.188.3
s=Asterisk PBX 1.8.21.0
c=IN IP4 199.188.188.3
t=0 0
m=audio 19138 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
003825: *Sep 27 12:34:02.188: //543583/40C130000000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:915147047479@192.168.22.10>;tag=21B3A16F-2571
CSeq: 101 INVITE
Require: 100rel
RSeq: 2124
P-Asserted-Identity: <sip:15147047479@hgtp.com>
Contact: <sip:915147047479@192.168.22.10:5060>
Supported: sdp-anat
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 974 4461 IN IP4 192.168.22.10
s=SIP Call
t=0 0
m=audio 13108 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
003826: *Sep 27 12:34:02.208: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:915147047479@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.248.10:5060;branch=z9hG4bK154811322b3701
CSeq: 102 PRACK
RAck: 2124 101 INVITE
Max-Forwards: 70
Content-Length: 231
v=0
o=CiscoSystemsCCM-SIP 13956200 1 IN IP4 192.168.248.10
s=SIP Call
c=IN IP4 192.168.64.101
b=TIAS:64000
b=AS:64
t=0 0
m=audio 18568 RTP/AVP 0 101
a=fmtp:101 0-15
003827: *Sep 27 12:34:02.210: //543583/40C130000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
HOL-VG01#u a
003832: *Sep 27 12:34:05.099: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:915147047479@192.168.22.10:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Session-ID: 6a53137f00105000a000009e1ede3ddc;remote=206acbdcdf9249ea5cfd75ab13956200
Content-Length: 0
003833: *Sep 27 12:34:05.100: //543583/40C130000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 27 Sep 2017 12:34:05 GMT
CSeq: 101 CANCEL
Content-Length: 0
003834: *Sep 27 12:34:05.101: //543584/40C130000000/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:15147047479@199.188.188.3:5060 SIP/2.0
From: <sip:9056711271@199.188.188.3>;tag=21B3A136-1F4E
To: <sip:15147047479@199.188.188.3>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1506530045
Reason: Q.850;cause=16
Content-Length: 0
003835: *Sep 27 12:34:05.102: //543583/40C130000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
003836: *Sep 27 12:34:05.120: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
003837: *Sep 27 12:34:05.122: //543584/40C130000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 101 INVITE
Server: Enswitch
Content-Length: 0
003838: *Sep 27 12:34:05.123: //543584/40C130000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <sip:15147047479@199.188.188.3>;tag=as5eac6e5c
CSeq: 101 CANCEL
Server: Enswitch
Content-Length: 0
003839: *Sep 27 12:34:05.123: //543584/40C130000000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:15147047479@199.188.188.3:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Dennis Mink
can you send all debug info?
 also what I noticed, and what could cause issues, is the fact that CUC>CUBE  uses SIP delayed offer and from CUBE>Provider uses Early offer.
Please remember to rate useful posts, by clicking on the stars below.
Also does your ITSP require any sort of validation to place calls to the PSTN?
MM
What is happening when you attempt to place an outbound call? Is this a new implementation, or did this just start happening?
This is a new implementation, the call cannot be completed, the message is  "The number you dialed does not exist".
Can you post your SIP Dial Peers and any translation profiles/rules that you have configured on your CUBE?
Here are the dial-peer and the translation I'm using for the outbound to SIP Trunk. However, it's more the sip-profiles (see below) I think is not properly configured.
voice translation-rule 3
 rule 1 /^9\(.*\)/ /\1/
voice translation-profile STRIP_9
translate called 3
dial-peer voice 101 voip
 description WAN Outgoing to SIP Trunk
 translation-profile outgoing STRIP_9
 destination-pattern 9[2-9]..[2-9]......
 session protocol sipv2
 session target ipv4:199.188.189.3
 voice-class sip profiles 101
 voice-class sip options-keepalive down-interval 20
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 102 voip
 destination-pattern 91[2-9]..[2-9]......
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
voice class sip-profiles 101
 request INVITE sip-header SIP-Req-URI modify "@.*:" "199.188.189.3"
 request INVITE sip-header Diversion modify "(@.*)>" "@205.204.70.71>"
 request INVITE sip-header Contact modify "@" ";tgrp=3268488;trunk-context=199.188.189.3@"
 request INVITE sip-header From modify "(@.*)>" "@205.204.70.71>"
 request INVITE sip-header P-Asserted-Identity modify "(@.*)>" "@205.204.70.71;user=phone>"
 request INVITE sip-header To modify "@.*>" "@199.188.189.3>"
 request INVITE sip-header Diversion modify "reason=unconditional" ""
 request INVITE sip-header Diversion modify "reason=user-busy" ""
 request INVITE sip-header Diversion modify "reason=no-answer" ""
 request REINVITE sip-header From modify "(@.*)>" "@205.204.70.71>"
 request REINVITE sip-header P-Asserted-Identity modify "(@.*)>" "@205.204.70.71;user=phone>"
 request REINVITE sip-header Diversion modify "(@.*)>" "@205.204.70.71>"
Do you know how many digits your carrier is expecting to recieve from you? Are you using an E.164 dial plan?
For testing, I'd strip down your dial-peers and get rid of the sip profiles, digit strip, etc. Here is sample config from my lab which is working, if this is in a lab enviroment for you try to paste these dial-peers and test.
dial-peer voice 200 voip
description outbound dial-peer to SP
session target ipv4 sip-server
codec g711ulaw
dtmf-relay rtp-nte
no vad
dial-peer voice 201 voip
codec g711ulaw
dtmf-relay rtp-nte
no vad
The carrier receives 10 digits
Didn't work
see attached trace
What are the chances that your ITSP require SIP registration before sending SIP INVITEs to him? If so, you'll have to add the relevant commands for it.
Anyway, did you try to reach your ITSP? Maybe the issue is on their end.
I'm experiencing the exact issue..did you get a workaround?
The issue was solved it was the customer's phone system.
the CUCM was sending a PAI field in his invite but asterisk didn't not recognize it. It was removed and all worked fine.
