01-29-2014 09:25 AM - edited 03-16-2019 09:30 PM
Hi all,
Do you know if Cube is supported in an environment with redundant Geth ports going to separate VLANs ?
i.e.,
-------------Inbound SIP Trunks ----- GE0/1 -Cube - Ge1/0 ------- VLAN 1 |
|_Ge0/2_____________ VLAN2 | _________CUSP, CVP, UCCE,
01-29-2014 12:04 PM
It's doable, but what what be the reason for doing this?
Chris
01-29-2014 12:08 PM
Thanks Chris, The reason for this is to eliminate a Single Point of failure from the Cube to the ethernet switch. If one switch port fails, we'd have a backup.
01-29-2014 12:16 PM
If the CUBE is connecting to the same layer 2 then use Etherchannel, if separate networks then use loopback interface and utilize routing protocol.
Chris
