CUCM 11.5 - What are the call recording methods ?
khesalahmad
I am using CUCM 11.5 ver, with a total of 65 IP phones installed in a network, the client is asking to record 10 PLAR based configured Cisco IP Phone (Model CP-8841) calls.
Is there any option in CUCM that I can configure for recording without taking any third-party software or hardware?
Can anyone provide me a detailed document or tutorial material on various types of call recording methods in CUCM?
Thank you
4 Accepted Solutions
There are AFAIK no native options in CM for call recording. You’ll need to use a 3:rd party system for this.
I would recommend you to reach out to a reputable Cisco partner, with a specialisation in unified communication, for this line of question.
Response Signature
To name a few, NICE, Verba and Calabrio. There are many more, this is just the one that where top of mind.
Response Signature
To add with what @Roger Kallberg  mentioned, imagilcle is a third party application which is available on Cisco GPL and its a simple applications.
Response Signature
You need to have a VM with windows operating system.Imagilce application suite  are installed on Windows server.
Response Signature
7 Replies 7
Response Signature
Greetings
Dear Roger Kallberg,
Thank you so much for your reply, I would like to ask you for one more favor,
Can you please give me any recommendation for 3rd party system, which is approved by Cisco as well?
Response Signature
Response Signature
Dear Nithin,
Appreciate your help - Thank you so much.
So, I will need only an application, or do I need anything else in order to get recordings (like any kind of hardware)?
Response Signature
Just a pointer, you do not have to mark all the responses that you get as the solution to your question.
Response Signature
