12-19-2007 06:06 AM - edited 03-15-2019 07:52 AM
To install CUCM 6.0, is any server which meets minimum requirements ( 2GB RAM for example) sufficient or do we still need to go for Cisco approved servers only like in 4x versions?
12-19-2007 06:12 AM
Hey Abhijit,
How's things? It is Highly recommended to use only Cisco supported servers for CCM 6.x production builds. Here is an excellent list;
This doc shows all the supported models for the different CCM Versions ;
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
12-19-2007 09:49 AM
Hi Rob,
Will definitely check it out on Monday, currently I am on leave..Thanks as usual for your support. Wish you a very merry Christmas in advance...
Abhijit.
12-20-2007 09:33 AM
Rob:
Is there a similar matrix which outlines other applications like Unity/IPCC/MPE.
I searched a lot on cisco.com and couldnt find it.
This matrix is really helpful to determine hardware dependency
12-19-2007 06:13 AM
like before:
MCS or www.cisco.com/go/swonly
you can also check here:
for lab, you can install in a vmware.
regards
Steffen
12-19-2007 09:50 AM
Steffen,
Thanks a lot for your support. Wish you a very merry Christmas in advance.
