02-09-2011 04:22 PM - edited 03-16-2019 03:22 AM
I have inherited a Enterprise level phone system and I am having a hard time understanding it. Here is the issue.
A call comes in to an 800 number which is associated to an extension. The call gets passed to one person, then another, and then back to the first. I have been asked to make a change so that if both are busy, the caller will hear a played message and then the call is to be disconnected. I am at a loss as what to do to accomplish this.
Solved! Go to Solution.
02-09-2011 05:12 PM
Hi Jason,
You are looking at a hunt group here that does the behaviour you explained.
What you will need to do to get the new behaviour is as follows
This should work for you, any more details you can give as to deviations from the steps mentioned will help in a better answer.
Thomas
P.S. Please rate helpful Posts
02-09-2011 05:38 PM
Hi Jason
I agree with the solution provided by Thomas.
Here is how you can proceed with the solution.
===CUCM===
Under Device-->CTI Route Point-->Add New (give the Device name and other details)-->Save
When You Save it ,You'll get an option to create a DN
Create a Dummy DN No. (E.g 9999)
Forward all to Voicemail
Under Call Routing-->Royue/Hunt ...Add this CTI Route as the third memeber in the Line Group
===Unity===
Call Management-->System Call Handlers-->Add New
Give the same extension you used in the CTI Route Point (here 9999)
Edit-->Greeting-->Standard-->record the Greeting and use My personal greeting
Call Routing-->Forwarded Routing Rules--->Add New-->Display name-->Save-->Add New-->Forwarding station-->Equals--->9999(CTI Route pint extension)
I think this should help you out :-)
Vidit
P.S Please rate helpful Posts
02-11-2011 08:29 AM
Hi Jason,
Yes, this is most possible
Call Management > Call Handlers > Greetings Page > Send Caller To
Cheers!
Rob
02-11-2011 09:08 AM
Hi Jason,
I may not have explained that properly
Find the Call Handler for 4400, then go to the Greeting
page for whichever greeting you have chosen to use. Let's just
say you are using the "Standard" Greeting. On that page you will
find the "After Greeting Action" we are looking for.
Cheers!
Rob
02-09-2011 05:12 PM
Hi Jason,
Thomas
02-09-2011 05:20 PM
Do I make these changes in the CM or in Unity? Forgive me, but I am only used to working on CME.
02-09-2011 05:32 PM
The first 2 steps in CM
and the last 2 in Unity
regards
Thomas
P.S. Please Rate Helpful Post
02-09-2011 05:38 PM
Hi Jason
===CUCM===
===Unity===
Vidit
02-10-2011 11:52 AM
Ok, maybe I am missing something. There is a DN already setup for this, but no CTI route. Is there a way for me to see exactly how the call is being routed?
02-10-2011 01:00 PM
you mean there is a DN setup in the CUCM?; what is this DN given to, if to a phone it will not help. You need to add a new dummy DN like Vidit said.
Now this new DN given to the CTI route point needs to be 3rd member of the Hunt group that currently has the other 2 phone numbers in it.
Thomas
02-10-2011 01:24 PM
The line (4400) is located on the 2nd button on both users phones. Does this all need to be ripped out and redone?
02-10-2011 01:26 PM
Thomas and Vidit,
If you configure a CTI route point with DN '9999' on the CUCM and Call Handler with extension '9999' on a Unity Connection, you do not need the 'Forward Routing Rule for extension 9999 ? The call handler will be automatically selected, when a 'CTI route point' comes in with an extension 'x' and a call handler in the unity has the same extension 'x'. I remember this is the behavior on Unity Connection.
Is it not the same with Unity ?
02-10-2011 01:54 PM
Guru, it works that way in Unity Connection, not sure about Unity; I guess Vidit would know, being the Unity expert here.... will need to try it out to be sure.. again upto Jason, gues he can easily try both out...
02-10-2011 06:29 PM
Guru,
If I understand your question, you are asking:
If I use the EXTENSION field on the Call Handler, do I need to use a ROUTING RULE in Unity?
This is the same in both Unity Connection and Unity. If you program the extension field on a Call Handler then you do not need to use a routing rule. You would configure the CTI Route Point to CFwd that DN to Unity and the extension will be matched in Unity...assuming the correct VM profile is assigned at the line level in CUCM on the CTI Route Point and so forth. I actually prefer this method vs. the use of routing rules but that's just me.
Hailey
Please rate helpful posts!
Message was edited by: David Hailey To clarify, I should say that you don't need a specific (new) routing rule just for the call handler. The default routing rules would work here.
02-11-2011 05:41 AM
Hi Jason,
Well, you've been getting some great help here from Thomas, Vidit, Guru and Hailey
and I've added my +5 for each of them
In your described scenario you could go a little more simply here. I would go ahead and create
a new Call Handler with the DN 4400 that can play the required Greeting and then use the
Hang-up or say Goodbye "after greeting" action.I would try to avoid the Hunt group and just use the
Forward no Answer and Forward Busy settings on the DN page for 4400 in CUCM to achieve the
"new" call routing you desire. If 4400 is on both phones then it's already ringing on each for Incoming calls
so you can just manipulate the Busy Trigger to route the call to Unity when both are busy by following the
Call Forward Busy setting to route to the Unity Pilot #.
Cheers!
Rob
02-11-2011 07:57 AM
Rob,
Will what you posted, play the message and then disconnect the call without giving the caller an option to leave a message? What settings need to be modified in the call handeler in Unity?
02-11-2011 08:29 AM
Hi Jason,
Cheers!
Rob
02-11-2011 08:57 AM
Cisco Unity Connection Administration
8.0.2.4.0000-12
I do not have this option.
the options I have under Call Management are:
Directory Handlers
Interview Handlers
Post Greeting Recordings
Call Routing
- Direct Routing Rules
- Forwarded Routing Rules
