05-16-2013 11:14 AM - edited 03-16-2019 05:21 PM
So as the title states, I am running CUCM 8.5 and am providing analog FXS over a VG224. I have an IP phone with a DN that is shared with an analog device connected to the loud bell. When I call the DN I hear a partial ring from both devices, then the analog device goes off hook and then the call is disconnected. Any advice?
05-16-2013 11:30 AM
The VG may be unable to provide enough ring current for oth devices device. You might try another loud bell, or there are SIP based ones that do not need FXS an all.
05-16-2013 11:34 AM
Yeah, this loud bell was working with the Mitel phone system that I replaced. There is another loud bell that is having the same issue. If this is a power issue do you think a ring amplifier could fix the issue?
05-16-2013 11:37 AM
You could try that as well, but a different loud bell could cost about the same.
05-16-2013 11:50 AM
Whats the config? might be way out there but i remembered i had to configure my dial-peers and set forward digits none to have something SLIGHTLY simliar function.
05-16-2013 11:52 AM
Forward-digits should not have any effect on ring current.
Beside, OP could be using SCCP hence no dial-peers at all.
05-16-2013 11:55 AM
Here's the config for the port in question:
stcapp supplementary-services
port 2/13
fallback-dn 8072
voice-port 2/13
ren 2
disconnect-ack
no pulse-digit-detection
signal groundStart
no vad
no comfort-noise
timeouts ringing infinity
dial-peer voice 213 pots
service stcapp
port 2/13
I am using SCCP for this gateway. Just to reiterate, the loud bell is sounding a partial ring before it takes the line off hook and then disconnects it. does this still point to a power issue?
05-16-2013 12:16 PM
Hi Jacob,
I'm curious about the Groundstart portion of the config....
have you tried Loopstart at all?
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
05-16-2013 12:21 PM
My friend Rob is, of course, correct. Should be loopstart.
05-16-2013 12:24 PM
All these items in the config have been added/changed because of testing.
ren 2
disconnect-ack
signal groundStart
no vad
no comfort-noise
So, yes, I have tried loopstart.
