02-11-2015 01:27 AM - edited 03-17-2019 01:55 AM
Hello! Could you please give a piece of advice on my problem?
CUCM can't complete the backup process with the following error:
Feature : UCM
Component : TFTP
Time Completed: ***************
Result Code : 1-Unknown TFTP Error
Result String : ERROR
Free space on /common/drf = 3191432 KB, required space = 3987084 KB
Not enough space for backup
----> BEGIN Standard Output
----> END Standard Output
----> BEGIN Standard Error
----> END Standard Error
The sftp server where the backup to be placed has enough dissk space.
I tried restarting the local/master DRF services on the CUCM - didn't help.
Am I right thinking that I need to clean up /common/drf directory? How can I do so?
Thanks a lot!
Solved! Go to Solution.
02-11-2015 02:24 AM
Seems like common partition of specific server is full. execute the command "show status", "show diskusage common sort" and check the disk usage if disk usage of inactive/logging is around 80-90% then we got to free up some space there.
admin:show status
Total Free Used
Disk/active 14652904K 1821348K 12682688K (88%)
Disk/inactive 14652904K 13741144K 167416K (2%)
Disk/logging 50986188K 30910692K 17485544K (37%)
In order to free up the try the following
++ Install ciscocm.free_common_space_<lastest version>..cop.sgn.cop to clean inactive partition
++ Delete traces, and set the tracing to default.
++ Try rebooting specific server.
HTH,
Mohammed Noor
03-02-2015 07:07 AM
Hi Dmitry,
In addition to what Noor has asked, can u look into the bug
02-11-2015 01:36 AM
try changing the path of sftp on PC where u are taking backup.Create a separate folder and in sftp software point to this new path.
regds,
aman
02-11-2015 02:15 AM
I've changed the destination path for sftp... the problem persists unfortunately.
02-11-2015 02:28 AM
Try to use an another sftp server in your laptop to eliminate any other issues.
you can use a coreftp(free) and executable.
http://www.coreftp.com/server/download/msftpsrvr.exe
02-11-2015 02:24 AM
admin:show status
Total Free Used
HTH,
Mohammed Noor
03-02-2015 05:29 AM
Hi Mohammed,
thanks a lot for your response! I have installed and run ciscocm.free_common_space utility as you advised. As a result /common/drf directory indeed seems to have enough free space. This error message disappeared, but unfortunately another problem has risen:
Result Code : 116-SFTP transfer failed during Backup. Either there is not enough disk space or network transfer failed due to interuption while transferring data to configured SFTP Server
Free space on /common/drf = 16823664 KB, required space = 6844280 KB
Ready for backup
.............list of files
tar: -: Wrote only 6144 of 10240 bytes
tar: Error is not recoverable: exiting now
Backup failed
error writing output file
gzip: stdout: Broken pipe
It's strange because sftp server has plenty of free disk space. The communication between CUCM and SFTP server seems to be OK - at least I'm able to update device firmware using it.
thanks beforehand for any ideas on the problem!
03-02-2015 05:35 AM
Hi Dmitry,
Can you which sftp server your using.
Mohammed Noor
03-02-2015 07:07 AM
Hi Dmitry,
03-02-2015 09:12 AM
+5 Aman
03-04-2015 03:20 AM
Hi Aman and Mohammed!
thanks a lot for your comments. It looks like I'm really affected by CSCul38509.
It is interesting that if I issue DIR and then DIR /R commands the backup process finishes correctly! If I don't do that the backup fails as usual.
So I think I'll have to use the workarounds suggested.
03-04-2015 04:51 AM
thanks for update[+5].
regds,
aman
03-04-2015 05:24 AM
Hi Dmitry,
Refer below link covers common issues in DRS. I had published few day back
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117725-probsol-cucm-00.html
HTH,
Mohammed Noor
03-25-2020 08:24 AM
HI
I have the same problem that does not allow me to Backup in CUCM v10.5.2.
I already deleted trace from RTMT
Install the COP
Restart the server however not under Active / Inactive disk space.
Any other suggestions??
Total Free Used
Disk/active 14643120K 1799756K 12694600K (88%)
Disk/inactive 14643056K 1887540K 12606752K (87%)
Disk/logging 174846672K 144477044K 21494448K (13%)
