05-17-2013 06:59 AM - edited 03-16-2019 05:22 PM
I have a DID that is not mapped to a user or line. I want any calls placed to that DID forwarded directly to an external number, how would do I go about doing that?
05-17-2013 07:09 AM
Hi there,
One way to create a "Dummy" or "Virtual" number in CUCM is
create it as a CTI-RP (CTI-Route Point.) When you create a
CTI-RP you will be able to set a CFWD on the DN page
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
05-17-2013 07:15 AM
Do I use the actual DID number as a CTI-RP? Or can I use any number?
05-17-2013 09:25 AM
It would depend how the call is handed off to CUCM. For ex. the DID is 212-708-1010. The call comes into the gateway from the SP as 1010. The gateways sends 1010 to CUCM. In this example you would create a CTI RP with a DN of 1010. And forwarding all to the off-net number you would like to xfer to. Make sure the partition is reachable by the gateways CSS as well. And that the CSS you use to forward all on the DN has access to off-net route patterns.
12-04-2013 01:25 AM
how do you get the CTI route point to register with the CUCM?
We have CTI-RPs for several applications and they register as soon as I connect them with the application users.
But if it's just an independent CTI-RP, configured with a forwarded DN and nothing else, how does it register??
Thanks & Regards,
Ben
12-04-2013 02:02 AM
Hi Ben, It doesn't need to be registered as it is created only to forward the calls back to external phone.
if you can set CFA (or CFUR) with the destination and correct CF CSS then it should work.
