CUCM 9.x compatibility with VMware vSphere ESXi 5.1
alexandre.r
I have a customer who want to migrate from CUCM 8.5 on MCS to CUCM 9.x on UCS.
But he absolutly want to use VMware vSphere ESXi 5.1.
Question: is CUCM 9.x supported on VMware vSphere ESXi 5.1?
If not, what is the timing or the roadmap for that support ?
Many thanks for your response,
A. Richard
7 Replies 7
Jaime Valencia
It'll be supported when it's posted here:
  Supported Versions of  VMware vSphere ESXi
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#Supported_Versions_of_VMware_vSphere_ESXi
Roadmap questions cannot be answered here, if you need that info, engage your SE/AM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Javalenc,
About Cisco Prime Collaboration 9.0 (CUCMS), the concept is the same? I read the any documentations and informed that to version 9.0 have support to VM 4.1 and 5.0. aren´t there support to version ESXi 5.1?
Wilson
why esxi 5.1 ?
ESXi 5.1 is now supported just fine.
HTH,
Chris
Hi Wilson,
Supported Major/Minor Versions of VMware vSphere ESXi
See the preceding section on this page for support of ESXi Maintenance versions, patches and updates.
VMware vSphere ESXi Version Support for Call Processing and System Management Applications
Application
VMware vSphere ESXi 4.0 VMware vSphere ESXi 4.1
Cisco UC Virt. Foundation 4.1*
VMware vSphere ESXi 5.0
Cisco UC Virt. Foundation 5.0*
Cisco UC Virt. Foundation 5.1*
Unified Communications Manager (Unified CM) See Virtualization for Cisco Unified Communications Manager (CUCM)
Cisco Paging Server for Unified CM See Virtualization for Cisco Paging Server
Unified CM IM & Presence Service See Virtualization for Unified CM IM and Presence
Cisco Business Edition 6000 See Cisco Business Edition 6000
Cisco Emergency Responder (CER) See Virtualization for Cisco Emergency Responder
Session Manager Edition (SME) See Virtualization for Cisco Unified CM - Session Management Edition
Unified Attendant Consoles See Virtualization for Cisco Unified Attendant Consoles
Cisco Intercompany Media Engine (CIME) See Virtualization for Cisco Intercompany Media Engine
Cisco UC Management Suite
  • (Cisco UPM, UOM, USM, USSM)
Cisco Prime UC Management Suite
  • (Prime UPM, Prime UOM, Prime USM)
8.0 and later 8.0 and later 8.6 and later UPM: 8.6 and later
UOM/USM/USSM:Not supported
Prime Collaboration Manager Not supported Not supported 1.2 and later Not supported
Prime Collaboration Provisioning (PCP)
Prime Collaboration Assurance (PCA)
9.x
9.x 9.x 9.x
* For applications that are allowed "on-box" with Cisco Business  Edition 6000, this also includes version compatibility with Cisco UC  Virtualization Hypervisor which is only supported for use with Cisco  Business Edition 6000.
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Hi Chris,
In the really I used the same post to ask about Cisco Prime Collaboration 9.0 Manager (CUCMS) not CUCM. But, anyway thank you for your attention and your help. There is not support for this product only Prime Collaboration Provisioning (PCP) and
Thanks a lot,
Wilson
Thanks a lot Rob,
Wilson
