10-14-2010 05:11 PM - edited 03-16-2019 01:21 AM
I just got the ATA187 and have them working. I need to know if there is a way to change settings via a web page? Can't find anything in the online manuals. The part I need to change is turning off the second port. A lot of times we put them next to a fax machine and don't need the second port. I don't want to waste my DLUs.
Any help?
10-14-2010 08:34 PM
I don't have access to an ATA 187 presently but can u go to
your CCM ATA page and click on its IP and provide a screen
shot of the ATA's web/gui ?
10-15-2010 05:56 AM
Unlike the ATA 186/188, the 187 can only be configured via CUCM.
Under, Cisco ATA SIP services
• Cisco ATA configuration through Cisco UCM configuration interface
The ATA configuration has been simplified and streamlined to mimick that of an IP phone. All available options are now on the CUCM page for the ATA.
-Felipe
10-15-2010 09:04 AM
My question is, How do I turn off the second port. Like the 186, it has a second mac address and that burns up my DLUs.
02-21-2011 07:53 AM
Workaround.
Turn off autoregistration and add devices manually.
cheers,
i
09-02-2011 02:11 AM
I have the exact opposite problem, I have manually configured two fax machines on the ATA187 and the 2nd line doesnt work at all. Where in the settings do you configure this?
